Question about Toshiba Satellite A305-S6859 Notebook
Toshiba Laptop Dead no bios
Just plain dead. No boot to bios. no lights come on. Nothing. Removed battery. Held power button down for 30 secs+. Retried and still nothing. Not AC power supply because I tried a new one and still nothing. Replaced AC plug inside laptop that connects external AC power supply to laptop. How do I know if motherboard is shot? Don't want to dump laptop yet. Sincerely, Chuck
    Problem Solver:
  • 16 Answers
Most of laptops batteries have electronics inside them wich test and transmit info about the battery itself. Maybe the fail is there and not in the laptop. Try with another battery befor dumping it.
Posted on Dec 01, 2012
5 Suggested Answers
  • 5 Answers
SOURCE: toshiba laptop wont boot
Sounds like a back light problem
Posted on Apr 14, 2009
RescueTechLA
  • 2653 Answers
SOURCE: Laptop Toshiba Satellite A200 Model No. PSAF6A-02C01N fail boot
Try removing / swapping / reseating the memory.
Try booting with one stick only, if the top slot doesn't work, try booting the bottom slot. Try both sticks.
Let me know what happens.
Posted on Apr 04, 2010
Testimonial: "First step in a series to diagnose. On the journey. Useful thanks."
SOURCE: toshiba a105, wont power up, clicking sound
I seem to have the same problem. I have an a105-4134. Ive had since June of 2006 and ive kept it clean and have replaced several components throughout its life.
I was working on it few days ago until it just shut off. Confused, I press the power button thinking maybe the power adapter wasn't plugged all the way in and the battery depleted and it shut off. So now the computer will now power on. It lights up but shuts off within 1 second. Keeps doing this over and over.
My first thought was the dc jack as ive read it is common to be faulty after long use. I ordered a new one and unfortunately it was not the culprit. I then suspected the cheap aftermarket power adapter which replaced the dead oem power adapter. Bought a new one and experienced the exact same symptoms yet again.
Now I'm digging deep removing all components one by one. With each one I remove, I gain a few seconds of time that it will stay on before shutting off on its own. I powered it on with only the motherboard and cpu and it does the same thing.
From the original problem in this post, the cpu and motherboard were swapped out and same symptoms still occurred. This being the case, the only component left undiagnosed is the power board itself.
This is where I noticed that the computer will power up and run on battery power. The adapter plugged in will charge the battery but not power the computer while running. With this discovery it means that it cannot be any of the main components causing the problem.
Back to the power board, an obvious problem area seeing how this is tied in with power components. From the looks of it, it seems like a simple switch board but i may be wrong. My next step is to order a new power board. I will let you all know how it turns out.
Posted on Apr 13, 2010
  • 3278 Answers
SOURCE: Toshiba laptop power failure after yanking power cord
Hello.
Sounds like you already determined it, but if you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
Hope this helps.
Posted on May 09, 2010
Toshiba l875d-7332
try doing the hard reset; remove battery and ac adaptor and press the power button for 30 sec; after that reseat the battery and the adaptor and power up the laptop.
let me know if that is working for or not.
Feb 08, 2014 | Toshiba Satellite L875ds7332 Notebook...
I own a Toshiba C655-S5140 Laptop. I was using it yesterday (everything was perfectly fine) and the low battery warning came on. I closed my laptop. When I hooked up the adapter to the laptop nothing...
You may have corrupted your hard drive, try and get a Linux system disc and boot from that. You may be able to restore the hard drive using Linux. You may need to press F2, F10 to get in to the boot menu to change the option to boot from CD/DVD.
Aug 31, 2013 | Toshiba Satellite Computers & Internet
Toshiba Satellite laptop will not boot. Shows power from outlet and battery but no indicator light is present for the last two in the five light sequence.
Its an old trick that got my Dell laptop working
Unplug the laptop remove the battery press the power button,...nothing will happen, wait a few seconds put battery back in laptop plug it in hold upside down press power button until it boots
If that doesn't work it could be a bad/loose/dead bios battery What is the model of the laptop?
May 11, 2011 | Toshiba Computers & Internet
Bios Faile
bios is always risky update, and toshiba is very well known to stuff up they bios...
first advice, never, ever, update bios from inside of your operating system...
as your computer is already dead, try this method, i cannot recall if you have phoenix or amibios but should work on both:
1. remove power and battery from dead laptop
2. download again bios and unfold it, remember the folder, do not run it!
3. go to this folder and find file with suffix *.rom, rename it to amiboot.rom
4. copy amiboot.rom to usb drive
5. plug usb drive into usb port
6. press and hold fn+b, plug in power cord and press power button
7. if after few seconds you see screen flashing and toshiba logo then returns, you just saved your laptop and few dollars...
8. allow it to boot, switch off, re-insert the battery and use as before.
if this do not work, i am afraid tha tyou need to find some toshiba centre which will flash and re-program bios for your. do not get conned into replacing motherboard! there are non-toshiba repairers which charge between $30 and $100 to flash "dead" bios, toshiba for replacement motherboard want over $300.00
if you find my advice helpful, plese do not hesitate to leave comment and vote 4 fo rme, thanx!
Aug 01, 2010 | Toshiba Satellite P205D-S8804 Laptop
About an hour ago, done a Toshiba Tempro BIOS upda...
Oh dear that's the worst thing that can happen during a bios update. the bios chip is probably now useless rendering the laptop useless. You will need a new motherboard I am afraid to say.
Jul 25, 2017 | Toshiba Satellite Pro L300D-EZ1002X...
Ibm thinkpad t41 does not boot up...just black screen...fan works
hehe...I used to have some problems
and then came up with the solution to install other OS such as linux, lindows or anything else
and then reinstal it with windows booting...and then it works, u can try it
Jun 21, 2009 | IBM ThinkPad T40 2373 Notebook
Satellite a135-s2356 aill not boot up
a friend had same issue , i dissembled laptop and found a burnt diode chip beneath where power button sits on top cover panel there are two clips under power button , one of the clips shorted the diode , only orange power button would lit up on front edge of lower case
Apr 25, 2009 | Toshiba Satellite A135-S2356 Notebook
Troubleshooting Toshiba Satellite P205-S6267
is the laptop getting extremely hot on the bottom.
Could be thermal shut down (keeps the cpu from meltdown temperatures)
Robert
Aug 18, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Blank Screen and blinking light
I was using my laptop when it suddenly froze. Tried ctl/alt/del but nothing happened. So I powered down. When I tried to power it back up, the power light comes on, the lock lights blink twice, the fan powers up then down, and the dvd drive clicks on and off. Then nothing--black screen. My laptop battery is nearly dead, so I am always plugged in.
This seems like a common thing with the Inspirons, and here are some of the suggestions I tried:
I removed all power sources, held down power button for 30 sec to reset system and tried to boot up again--same issue
I unplugged the screen closed sensor, thinking the unit might be thinking it was asleep (lid closed), because that what it acts like. No luck.
Removed memory--and reset--nothing.
Replaced button battery on motherboard, now same problem.
Dec 11, 2007 | Computers & Internet
Toshiba Satellite A305-S6859 Notebook Logo
76 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
