The BIOS in the system is not fully ACPI compliant. I want to updated BIOS. How can I do?
    President:
  • 2,351 Answers
Hi meangmoeurn, what makes you think your bios is not ACPI complaint?
Enter your bios & disable ACPI. The reason for this is windows must be fully updated. One windows has been fully updated you can turn on ACPI. Its a software issue.
Read through this Microsoft link;
http://support.microsoft.com/kb/314088
Update for ACPI, (Windows update);
http://www.microsoft.com/downloads/details.aspx?familyid=B0FF829D-C427-4F40-BC56-F481837EFFBE&displaylang=en
The above update should be included with other updates. This is why I suggested the above.
If you still feel you need to update your bios,
(Flash Utility software). I'll need the motherboard model number & manufacture's name.
Good luck meangmoeurn!
Feel free to correct me on this issue.
Thank you for using fixya.
Mike
Posted on Jan 11, 2009
Bios is not ACPI complaint
It's possible that the BIOS setup has been accidentally set to non ACPI mode. Check in the setup to ensure ACPI is enabled.Other possible causes are memory expansion, overclocking and incompatible driver software. Check out what you have recently installed or updated on your computer.This can occur if Windows has detected that the BIOS in the computer is not fully compliant with Advanced Configuration and Power Interface (ACPI). To correct this problem, contact the manufacturer of your computer to obtain a BIOS update that is fully ACPI compliant. (If your PC is an older model, a BIOS update may not be available). There are third party companies that will write a BIOS update for your computer for a fee which may make it more cost effective to replace your computer.You may also find help on this Microsoft Support Site.
Apr 09, 2013 | Computers & Internet
BIOS Acpi Not Compliant
You will need to go to the website for the motherboard manufacturer and download the updated drivers for that motherboard. This is common with all the changes that windows goes through in a life cycle.
Nov 23, 2011 | Computers & Internet
Dell 8300 not loading xp home with the blue screen of death
To resolve this behavior, contact the manufacturer of your computer to obtain a BIOS that is fully ACPI compliant.
To work around this behavior, manually install the Standard PC hardware abstraction layer (HAL):
  1. Restart the computer to restart Setup.
  2. When Setup starts again, press F7 (not F6) when you see the "Press F6 if you need to install a third-party SCSI or RAID driver" screen.
Windows automatically disables the installation of the ACPI HAL and installs the Standard PC HAL.
Dec 30, 2009 | Dell Dimension 8300 PC Desktop
ACPI is not a compliant
Enter you bios & disable ACPI. Restart the system. Than update your windows. There should be an update for ACPI through Microsoft update service. Once installed restart your system & enter into your bios. Now enable ACPI. Save & exit the bios.
If this does not help you can try the work around found on Microsoft's web site. See the link provided;
http://support.microsoft.com/kb/314830
Cheers
Mike
Jun 01, 2009 | MSI Computers & Internet
Dell Inspiron 1100 Bios and ACPI
Please contact your system vendor for an updated bios. If you are unable to obtain an updated bios or the latest bios supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable ACPI and allow you to continue your installation."
RESOLUTION
Manually install the Standard PC hardware abstraction layer (HAL):
1. Reboot the computer to restart Setup.
2. When Setup starts again, press F7 when you see the "Press F6 if you need to install a third-party SCSI or RAID driver" screen.
Windows automatically disables the installation of the ACPI HAL and installs the Standard PC HAL. You should also contact the manufacturer of your computer to obtain a BIOS that is fully ACPI compliant
Mar 16, 2009 | Dell Inspiron 1100 Notebook
How to install Windows Vista On IBM NetVista 830331G
newer os like xp and vista have many new power management feautures like acpi-advanced configuration power interface.. when booting your pc press DEL or f2 to enter bios and check if your bios supports this feature.. i have not used ibm pcs but still check with this..
Feb 10, 2009 | IBM Netvista Intel Pentium 4 2.4GHz /...
Acpi complaint - reg
I have located some info on this board. it was released as a "Medion" board
there is some BIOS and driver stuff available HERE
http://www.medionusa.com/ and select customer care.. you need the exat model no or the serial no of the PC to continue though.
Also http://www.treiber.de/ may me of assistance as I think they are the real manufacturer but as I cannot read German I cant really be sure. they have the link to Medion on their webpage...
HIH and please post back results
Jun 23, 2008 | Intel Motherboard
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
41
Jan 17, 2008 | Intel Motherboard
Problem istalling windows 2000 professional on a pc with intel d945gcnl motherboard
try to make bios settings default and make a proper installation
The bios in this system is not fully ACPI compliant. Please contact your system vendor for an updated bios. If you are unable to obtain an updated bios or the latest bios supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable ACPI and allow you to continue your installation."
Dec 04, 2007 | Microsoft Windows 2000 Professional for PC
Computers & Internet Logo
730 people viewed this question
David Payne
David Payne
