Question about Vizio Tablet VTAB1008
Microphone not picking up sound
My vtab1008 gets my voice about 1% of time. i restored factory settings and still have problem
  • destiny9099
    destiny9099 Dec 03, 2012
    could you explain more?
    Master:
  • 368 Answers
MY dear Your Phone Mic Default So Please change mic
And Mic Sound Problem will solved
Posted on Dec 02, 2012
  • destiny9099
    could u tell me how to change settings on tablet for this. cant find one searched everywhere.
Im using lenovoG450, I installed windows 7 a few days back and now my microphone is not picking up my voice. I can hear sound but no one can here me. Please suggest something
Hi ,
ok , in the control panel you will find speech icon , click on that icon and it will ask you to set up your sound , mic , go ahead and do that and see what happens , i will advise futher Good Luck Roy
Nov 11, 2011 | Lenovo G450 Notebook
How can i disable HP 6910 Integrated Microphone. I do not want the mic picking up sound automatically.
Hi there!
You will have to go to Start - > Control Panel - > Sound and Audio Devices, then click the Voice tab, then click the on the Voice Recording section, you can modify the Volume of the Microphone to your liking.
Best regards!
May 02, 2011 | HP Pavilion dv6000z Notebook
Hello I'm Having Difficulties Setting Up My AT2020 Cardioid Condenser Microphone It's Not Picking Up My Voice At All And I've Looked Through All The Settings And Audio Properties And Everything Is In Order...
Your microphone needs a phantom power supply. Sorry for asking but you don't mentioned anything about any mic-preamplifier or other device. In case you connect the mic direct at the sound card of the PC, this is your problem. Please clarify me your set up in order to make you suggestions.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Feb 10, 2011 | Audio Technica Audio-Technica AT2020...
I have my webcam set on the monitor about 60cm from me and I can't get the microphone to pick my voice
actually the the webcam microphone have some limitation to pick up the sound signal from that much distance. better use new seperate microphone . try it, It will work, thats all........... kpfrlewajveq0aaaaasuvork5cyii%3d
Feb 03, 2010 | Microsoft LifeCam VX-1000 Webcam
Whenever i use software like sype to make internet calls it keeps telling me my microphone volume is low. i then ran the test hardware wizard for my sound and the microphone does not pick up any sound....
Try adjusting the volume settings in your mic.
Go to Start->Control Panel->Sounds and Audio Devices-> Click on Voice Tab->Voice Recording ->Then adjust volume
Oct 30, 2009 | HP Pavilion dv1000 Notebook
I have just purchased Logitech QuickCam E3100 - is there a microphone in this or do I need to purchase a seperate microphone or replace for a combined Web Cam and microphone?
Get a separate microphone, do not get a combo. This way you can position your camera at an ideal position and your mic as a perfect position to pick up your voice. combo units are nice because its one less thing but you will be unhappy with the results
Oct 04, 2009 | Logitech Webcam
IT DOES NOT WORK ECM-MS907 Professional...
Just in case you have having the same problem as me....
The reason why my microphone was giving mixed results was because I was using the wrong setting. The microphone slider says "90 degrees" and "120 degrees." I assumed that these angles refered to the area that the microphone picked up. So for a single narrow sound source, like my voice, the narrower, 90 degrees setting seemed appropriate.
Now that I have looked at the manual I see it is the reverse (weird but true. Perhaps the angles refer to the angles that the microphone ignores completely under each setting?).
I have been recording my voice. I noticed that sometimes the sound was good and other times the sound level was too low. I think that the reason is because sometimes I inadvertantly set the microphone to the 120 degree setting, which picks up my voice well, while at other times I set the mic to the 90 degree setting which attempts to pick up sound from a wider area, giving the central source less prominence.Setting the microphone to the 120 degree setting cured my problem. I hope it cures your problem too.
The manual is here:
http://www.docs.sony.com/release/ECMMS907.pdf
Aug 24, 2008 | Sony ECM-MS907 Professional Microphone
Tascam us 144 computer won't pick up microphone
OS? Try restoring to an earlier time if you're running XP, Vista, or 2000. Answer this and I'll try to get a fix for you...accordianman
Jan 05, 2008 | Tascam US-144 Sound Card
Microphone does not pick up voice
I am sorry to say but I think that perhaps your Microphone is faulty? These headset leads are notorious for breaking. If you know how to use a meter, perhaps you could check the circuit, and "see" if there is a Microphone attached? Could you "Test" it on another PC? But if this isn't the case below are some helpful links.. I "Googled" this --->troubleshooting microphone problems xp? http://support.plato.com/kb/tip.asp?psid=26055 www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/speech_setup_microphone.mspx
Aug 20, 2007 | Logitech Internet Chat Consumer Headset
Vizio Tablet VTAB1008 Logo
155 people viewed this question
Top Vizio Cell Phones Experts
Computer Repairing
Computer Repairing
ray gallant
Joe Ball
Joe Ball
Are you a Vizio Cell Phone Expert? Answer questions, earn points and help others
