Question about Hitachi 42HDS69 42 in. Plasma Television
Vertical lines on screen
Hitachi 42" plasma started a week ago with 1 faint red vertical line on the TV screen and now has 6 vertical lines. If we watch the TV or DVD movies, the lines are still present
  • Anonymous Mar 26, 2014
    pix good faint vert lines across screen
  • 3 Answers
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Posted on Jan 13, 2009
  • Brian innes
    Brian innes Nov 16, 2013
    I have a 50inch lg plasma and I have green lines down right and left off my screen one know how to fix this
Goodmans 32 inch flat screen, green verticle lines
Posted on May 11, 2012
    New Friend:
  • 11 Answers
On my 32" Plasma I found capacitors bulging on the Power Supply board in the HDTV. Replaced the capacitors and the lines went away. It was under $12 in parts. I have a 32" Plasma Vizio VP322.
Posted on Dec 01, 2011
SOURCE:
Have red vertical lines in center of screen from top to bottom
iam also facing same problum,that problum wont start immedietly,when we r watching after 1 hr it will start
Oct 21, 2012 | Hitachi 42HDS69 42 in. Plasma Television
Red fuzy screen
You had not fixed all connector properly.
Jan 23, 2010 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Random 3'' vertical red line on 42'' Hitachi Plasma TV
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.////
Sep 04, 2017 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi 42HDS69 Blue Vertical Lines
I think that you have dry solder joints on either the vertical scan board, the focus board, the line output stage, or the chroma panel. Hope this helps.
Sep 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi 42HDS69 42 in. Plasma with red lines
I think you have dry solder joints on the tv. Either on the chroma board, the vertical scan board, the line output board, or on the focus board. If you are going to do this yourself please take all necessary precautions against electric shock and discharge all capacitors that you can as a stray spark from one can cause damage to your tv and yourself. If you are not able to do this find a competant technician. Good luck.
Sep 03, 2008 | Hitachi 42HDS69 42 in. Plasma Television
42 plasma tv
same problem here with my panasonic 42"? less than a month old and started about a week ago
Jan 09, 2008 | LG 42PX5D 42 in. Plasma HDTV
Red line on screen
I had the same problem -red, vertical bars along the right side of my Samsung 42" Plasma- and this is what fixed it: Removed unterminated cable.
I had hooked up an HD video camera to the set about two weeks ago.  While I disconnected the camera I left the other end of the connector cable plugged into the T.V..  As I've since learned from friends who work in television, this is what's called an "unterminated cable" -meaning one end is unconnected.  It can lead to problems with electrical interference and appears to have been the problem in this case;  When I disconnected this cable from the T.V. the red bars went away.
So, check your cables.  Make sure everything is properly connected and get rid of anything that might be picking up interference.
Hope this makes sense.
Sep 29, 2007 | LG 50PX4DR 50 in. Plasma TV
Hitachi 42" Plasma 42EDT41
Had the same problem.  Was quoted $800 to fix.  Searched the internet for 6 months and found this thread on avforums.com
http://www.avforums.com/forums/showthread.php?t=462873&highlight=black+line+on+plasma&page=4
Read through all the posts.  Very simple fix, but you have to have some mechanical inclinations or you can cause more problems than you started with.  I was up to 5 of the black lines, but decided to attempt the soldering these guys did and fixed it all for the cost of a soldering iron!  Even if you decide not to attempt it, it gives you somewhere to start to tell a technician.
Aug 18, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
THICK BLUE LINE VERTICAL LINE ON SCREEN OF MY PLASMA PICTURE
IF THE LINE IS ABOUT 1INCH WIDE THE CHANCES ARE IT WILLBE YOUR PLASMA DISPLY THAT HAS GONE . WOULD BR CHEAPER TO BUY A NEW UNIT . HOWEVER TRY RINGING HITACHI EXPLAIN THE FAULT COMPLAIN THAT IT SHOULD OF LASTED LONGER THAN THE WARANTY AND SEE WHAT THEY WILL DO ABOUT IT
Jun 14, 2007 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Hitachi 42HDS69 42 in. Plasma Television Logo
6,226 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
