Question about Brother MFC-J435w Network-Ready Wireless Color All-In-One Printer
Paper jam error brother MFC-J435W
Cleared paper and printer wont print
SOURCE: paper jam, and I don't
I had the same problem.  I had removed all the visible paper and when it came back on made some awful noises and flashed "paper jam".
I even moved the roller forward and backward (after having uplugged the device.  I did this repeatedly and the "paper jam" alert continued (along with the awful noise).
As a last resort I thought I would just take it apart and hope to get it back together but figured it was a sensor or something along that line if I could not find any paper anywhere
with the machine unplugged (it would not shut down), I opened the lid I used a flashligt to look around trying to figure out how to take it apart.
It then dawned on me that I had not moved the print head over and using a screwdriver I gently pushed it to the center of the bar.  When I looked inside with a flashlight, there was the paper jam way inside under the cover.
I used some needlenose to reach in and took the paper out and it is now working fine.
I hope this helps, but you may have to search really deep into the device.
Posted on Dec 10, 2008
SOURCE: I can't find the back door sensor on Brother MFC-7420
I have the answer. I just fixed mine. The sensor is not really on the door. You have to remove the door by openning it all the way and carefully sliding it out ( one of the pegs holding the door is hourglass shaped. This will slide out first. The other is round. You will see a black flap that covers a red drum. Pull the flap down carefully. There will be a six inch long rod it's about 1/8 of an inch in diameter. It extends from the middle of the flap all the way to the right side. This probably popped out of place. Make sure that it is all the way to the right as this is where the sensor is. There is a little spring on the bar on the left side. This should be straight up and down. if it is not, then you need to fiddle with the bar.
The trick was that the sensor is NOT on the door, but on this inner flap. When the door closes it pushes this flap agains the drum and the little bar activates the sensor.
Please do not applaud so loud, you are ambarrazing me!!! hehehe. Good luck!.
Posted on Aug 11, 2008
Mix-it-up
  • 832 Answers
SOURCE: Cleared printer jam, message Unable to print 30
...and 50? Is it toggling between those two error codes?
Anyway, see here what to do:
http://www.fixya.com/support/t211210-brother_mfc845cw
Posted on Mar 11, 2008
Semi-Driver
  • 434 Answers
SOURCE: brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
Posted on Jan 21, 2010
pineworks
  • 4041 Answers
SOURCE: problem paper jam printer brother no mfc-490cw
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 27, 2010
After fixing a paper jam my printer started printing blank pages... What do I do?
Come on, none of these solutions are helpful. She obviously got the paper jam fixed and didn't need advice about that. It prints a blank page not Black doesn't print right. And a damned spam post linking a commercial site. I'm having the same problem and this is no help.
Mar 26, 2013 | Brother MFC-J435W Network-Ready Wireless...
MFC-J435w when trying to print I get error 5A Help?????
buy a new one. there is no repair for print heads. and don't use refill inks.
not good for print heads
Aug 01, 2017 | Brother MFC-465CN InkJet Printer
Brother MFC-8840D printer w/false paper jam indication.
With my Brother 8840D I have had paper jams that when cleared would not delete from the display nor would the machine operate until I unplugged the machine for around eight hours. I guess it is a sort of reset or reboot.
Jun 06, 2010 | Brother MFC 8840D All-In-One Laser Printer
I cleared paper jam. All is spotless. Won't
check fuser sensor switch have to remove fuser assy
May 18, 2010 | Brother MFC 8820D All-In-One Laser Printer
Multi-Function Center MFC-240C All-In-One InkJet Printer: i get the message "print unable 36" displayed on m...
Error code 36 is generally because of a paper jam that was not cleared. Remove the rear jam cover (the plastic cover in the back center of the machine)and the paper tray and check for any pieces of paper. Sometimes just a scrap will remain, but it's enough to cause the machine to not work.
Once you've replaced the covers, if the jam code does not reset, turn the machine off and then back on.
May 16, 2010 | Brother Multi-Function Center MFC-240C...
My printer is showing an error
our printer brother mfc 5460 is not printing.....even though there's an ink....how can we fix that? pls help....
Dec 27, 2009 | Brother MFC-5460CN All-In-One InkJet...
Error messages
I can't help directly but if you go here to the (Australian) support site
http://www.brother.com.au/customersupport/customersupport.asp
you may find your answer.
Note You may need to contact them direct to get your answer.
Good luck.
May 11, 2008 | Brother Multi-Function Center MFC-240C...
Brothe MFC-240C paper jam error msg won't clear
**, it is not fixed. I followed instructions on Brother web site and was able to find a piece of paper near the printhead, so I removed it. The printer makes a grinding sound when it tries to print and the same paper jam error returns and can't be cleared. I beleive that the printer repair cost will be more expensive than replacing it with a different printer, and it won't be Brother brand. I probably would not be able or have the tools to do any complicated repair job.
Mar 08, 2008 | Computers & Internet
Brother MFC-J435w Network-Ready Wireless Color All-In-One Printer Logo
915 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
