Question about Maytag Neptune MDG9700A Gas Dryer
Maytag Dryer runs for 8-10 seconds then shuts off accompanied by burning smell
I have taken the front off, cleaned the lint out of the inside. I also used canned air to blast around the wires, connection and the flame area. I have checked and cleaned from the lint trap all the way to the vent. There were no clogs. Any other suggestions?
    Top Expert:
  • Maytag Master
  • 9,472 Answers
When you say it runs for 8 - 10 seconds, do you mean it spins for that long or the flame is lit for that long?
Posted on Dec 02, 2012
  • 6 more comments
  • sdstobbe
    sdstobbe Dec 02, 2012
    Both. It seems to operate normally with both heat and spin and then shuts off.
  • sdstobbe
    sdstobbe Jan 16, 2013
    I took the cover off and watched when I turned it on. I gues it only spins - no flame
  • Richard Roth
    Richard Roth Jan 18, 2013
    Does the igniter glow and not lite?
  • sdstobbe
    sdstobbe Jan 18, 2013
    I did not notice. I will need to look again. I am looking from the front of the dryer so it is hard to see in there. Any suggestions on how to confirm if there is a glow?
  • Richard Roth
    Richard Roth Jan 19, 2013
    You may need to slide to unit out and remove the back access panel and run it to see if it glows.
  • sdstobbe
    sdstobbe Feb 01, 2013
    Sorry this took so long..... my wife is getting frustrated with me! There is no "back" per se. It wraps around both sides. So i duct taped a mirror to an ice fishing pole and stuck it back there so I could see. Results: It does glow! thanks again for your help on this.
  • Richard Roth
    Richard Roth Feb 02, 2013
    Ok, then the igniter is working so the problem is with the flame sensor. You will need to replace it. Here is the part to order.http://bit.ly/S3tNDB
  • sdstobbe
    sdstobbe Feb 05, 2013
    I have bad news. I replaced the flame sensor and the problem still exists. However, I noticed something that might be another clue. After installing the sensor, I was sitting thinking about what else it could be and after about a minute or two the dryer started up again and ran for about 5-10 seconds. I waited again and it did the same thing after another minute or two. It also still smells like something burning. I also felt inside the drum and it was not warm in there. Maybe there was not enought time to warm up. I am very grateful for your help. Sorry to keep bugging you. Do you have any other suggestions?
5 Suggested Answers
dididsaythat
  • 291 Answers
SOURCE: Maytag Dryer not working properly after cleaning lint trap.
where does the noise sound like its coming from??
Posted on Oct 08, 2007
reg501
  • 413 Answers
SOURCE: lint trapped inside dryer housing
SHUT OFF POWER AND GAS
1. Begin by opening the door removing the two screws on the left side of the door opening.
2. Then remove the screws that secure the door hinges to the cabinet. Lift off the door (may take some wiggling)
3. Grasp the outer top sides of the front panel and pull toward you.
4. Lower the front panel and lift off.
5. At each top corner remove the screw and latch that hold down the top.
6. You should be able to do the rest from here.
Posted on Jun 14, 2008
Washer_tech
  • 164 Answers
SOURCE: I HAVE A MAYTAG ATLANTIS GAS DRYER STOPS HEATING ABOUT 5 MINUTES IN
the flame going out is normal. the heat cycles on and off as called for by the thermostat. If the heat doesn't come back on i would start by changing the gas coils.
Posted on Nov 04, 2008
SOURCE: How do I remove the lint trap holder to clean out the lint inside
The font panel must be removed. This may be done by removing the control console (open upper cabinet doors to find screws behind the console). The screws along the top of the lower front panel are easily accessible. Disconnect the two interlock switches, remove the grounding clip attached to the bulkhead & lift the panel off the two lower clips. Inside the panel is a housing that leads to the exhaust blower. It will be packed with lint that may be hardened like papier mache. Just clean out the mess & reverse the process to replace the parts.
the
Posted on Feb 11, 2009
Maytag Centennial Gas Dryer: Only runs in "Air Fluff" setting. If any other setting (Normal Dry / Timed Dry) are used the dryer shuts down immediately. If I force the dryer to run by holding down the start...
Hello Kevin;
My name is Peter. I am a retired field service appliance technician.
When you run your dryer on fluff you are not using heat. The burning smell is when you use normal dry and the lint starts to burn. This will shut your unit down.
You just need a good cleaning. Nothing major. Send me your model number and I will help you.
Dec 11, 2014 | Maytag Dryers
Lg tromm gas dryer burning smell shuts off
Hello Debi;
You have a dangerous situation.
1.) First, your dryer is shutting down because your dryer is plugged up with lint and there is no air flow. You need to remove the top cover and control panel, the front cover and if your hot air distribution manifold id in the back or front end, remove that and clean. With a dry rag (DO NOT USE LIQUID CLEANERS), wipe the grease and grime off all components.
2.) The burning smell is the lint burning. Fortunately, due to the lack of air, the lint is being extinguished.
So far you are lucky. You have not had a major fire. DO NOT USE THE DRYER UNTIL THE ABOVE TASK HAS BEEN ACCOMPLISHED.
I wish I could provide you with more specific information on your dryer, but you did not provide a model number.
Nov 20, 2014 | LG Dryers
Burning smell however, motor runs fine, belt looks good, element heats up, vent is clean. i'm at a lose
Dryers collect lint.
Some, like the one I fixed last month, had a whole wastebasket full of lint inside it where you could not get it out without tearing the whole dryer apart.
I\'m suspecting either lint or some other foreign object is burning.
For your safety, please take it completely apart, or get someone else who knows what they are doing to do so, before you have a dryer fire.
( P.S. The last dryer I just fixed had a worn out felt on the drum, allowing the blower fan to suck lint past the screen and fill the inside of the dryer with that lint.)
Be blessed.
Apr 16, 2013 | Dryers
There's a slight burning smell coming from the dryer drum.
Some item may have gotten between the drum that rotates and the housing and during the rolling of the drum this item may be heating up from the friction. Check closely to see if you can find anything rubbing on the drum.
Jan 22, 2013 | Maytag PYE2300AY Electric Dryer
Dryer smoking up house and threw exhaust vent smells like something burnt
Hello, Well the smell is most likely from lint that is trapped in the dryer burning. The first thing you need to do is check the lint screen just inside the door. Second is to take the vent tube off of the back of the dryer and check to see if it is plugged with lint inside of the dryer. Clean out any you can see, also if the tubing inside of the dryer is most likely plugged with lint and the heating element is catching the lint on fire. If let go without cleaning this will cause a fire! I work for an appliance repair company and have seen dryers catch fire due to them being clogged with lint, you have two options; first is to clean it yourself, second is to have an appliance repair technician come to your home and clean it. The second is easier and safer but the first is cheaper but very labor intensive. I hope that answered your question and helped. Good luck!
Dec 09, 2010 | Kenmore Elite HE4 Electric Dryer
SMELLS LIKE ITW BURNING
I highly recommend opening the dryer by removing the front panel.
Unplug the machine, remove the front cover and be prepared to vacuum out the lint build-up inside the housing of the dryer.
Also clean the exhaust duct of lint buildup too.
Sep 12, 2009 | Whirlpool Dryers
The dryer smells when running like a burnt smell. How can I take it apart to clean the inside?
remove screws on front of dryer there should be four two at top and bottom under door .you will see your heating element you need to clean it very good then check yor hose on rear to make sure it;s clean and not clogged.. you will probley see a lot of lint.but take your time and good luck..vickie
Apr 13, 2009 | Maytag MDE3706 Electric Dryer
Maytag dryer - tub won't turn
You must clean all the lint from the motor and the blower whell compartment.
Jan 26, 2009 | Whirlpool LGV4634JQ Gas Dryer
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite HE4 electric dryer
If this is a Kenmore Elite front loader, taking the back off isn't going to tell you much. The heating element is inside the dryer under the drum on the right hand side. More than likely you have an accumulation of lint on the heating element housing and its beginning to smolder. Running the dryer on low will not change the fact that you have lint in close proximity to a glowing element. It will still burn. Here is a link you can look at that gives you some advice on dryers:
http://www.fixya.com/support/r385301-thorough_dryer_advice
You will need to unplug the dryer and remove the lower panel under the door to gain access to the heating circuits. If you have lint backing up into the dryer, you need to investigate why. If its been a while since you've inspected your dryer ventilation ducting, it would probably be a good idea to do so. Everything is in the link I provided for you. I hope this helps.
PS Conitued running of a dryer in this condition can cause the heating circuits to overheat and fail and/or cause a fire.
Jul 12, 2008 | Kenmore Elite HE4 Electric Dryer
Maytag Neptune MDG9700A Gas Dryer Logo
87 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
