Question about Kitchen Ranges
Frigidaire electric range model FEF379ACJ Does not work
Replaced the oven lamp recepticle but the stove top and oven still don't work. The stove top display does not work also
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
You will need to replace the main control board/clock, on the unit. It controls everything on the unit. Here is the part to order.
Posted on Dec 01, 2012
  • 833 Answers
SOURCE: My Frigidaire range display has gone out and the oven doesn't work.
sun, first test is to power the unit down. Find the pair of breakers which are generally 40 or more amperes. Turn them both off and back on. If this doesn't fix it, you will probably need a circuit board.
Posted on Dec 13, 2007
  • 116 Answers
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Posted on Sep 04, 2008
SOURCE: Frigidaire stove
I believe the oven it has a power surge protector within the appliance. Try to unplug it and plug it back in. It should solve the problem.
Posted on Dec 20, 2008
SOURCE: thermador range electric model ref 30
in pre heating the oven it does not go beyond 250 degrees. what could be the problem. I have a thermador 30 inch dual-fuel range (rdf30).
Posted on Feb 09, 2009
SOURCE: Whirlpool eletric range model RF363PXDW w/F1 display
The manual to this oven is here: http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203196274.pdf
That should fix almost any problem you have
Posted on Apr 03, 2009
Stove top and oven doesn't work.
If it is an electric stove it may have tripped one side of the 230 line. Check the house cuircuit breaker panel and find the stove circuit breaker. It will be tied together by a bar or clip. Shut off both breakers completly and reset them back completely. If it is a power problem this should reset the stove.
Dec 01, 2012 | Kitchen Ranges
Frigidaire stove(smooth top -electric) all of sudden started to beep' constantly w/F1 flashing.Tried to reset - unsuccessful. Unplugged & waited an hour to plug back in & still beeping...
The F1 error code means a button on the touchpad is stuck,usually pushing clear/off will clear it. Since you have done that and it returns the touchpad needs to be replaced
Gene
Aug 11, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Request Onwers Manual/Troubleshooting Guide: [FEF366CCE]. PROBLEM: Oven locked in code [F9] & [F1] w/ the the [Door Locked] LED flashing w/ beep. Stop top functional, oven inop.
Here is the Owners Manual for your model:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257123en.pdf
Here are all of the error codes and solutions for Frigidaire ranges: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Frigidaire Range / Stove / Oven Fault Codes#ixzz1Dxy4q2ze
Feb 14, 2011 | Frigidaire FEF366 Electric Kitchen Range
Frigidaire Glass Top Stove - Model #FEF668CJ5C The
Check your incoming power for 240 volts and your circuit breaker.
Check the cord where it attaches to the back of the range. If they are OK,look for a loose or broken wire.
There are no fuses in-line with the surface burners.
Jul 10, 2010 | GE JBP65 Electric Kitchen Range
The right front burner on my Mom's Frigidaire FEF316(I think, the # is 316232636) does not work. She heard a pop and saw a flash under the stove top near that burner when she turned it on. I switched the...
The recepticle that the burner ends plug into get worn and loose. This will cause arching and that may be what she saw. OR, there could be a wire loose under the stove top feeding the burner. Lift it up and give it a good inspection (with the breaker off). You may need to replace the burner recepticle.
Aug 01, 2009 | Frigidaire FEF316 Electric Kitchen Range
Oven wont work
If the sensor were bad, the unit would throw a fault code. On the back of the range, near the top, there should be a tech sheet for you to use to troubleshoot the range. It sounds like a thermal sensor may have opened up. Consult that tech sheet, it should point you in the right direction.
Dec 12, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Kitchen Ranges Logo
119 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
