Question about Acer Aspire Laptop PC V5-531-4636
Restore Acer Aspire V5-531 to manufacture condition
How to restore to manufacture condition
  • 52 Answers
SOURCE: acer aspire 6920 back to factory settings
Acer sent me these instructions.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Posted on Jul 12, 2009
migregorio
  • 42 Answers
SOURCE: Acer Aspire 3680 Complete Restore
http://www.acerpanam.com/us Go to that website and click on "eRecovery Disc Purchase". Acer does not come with recovery discs. It only comes with a recovery partition from which you can make recovery discs. If they discs were not made you'll find the provided website useful. If you're trying to recover from your recovery partition, then continuously hit the F11 key at startup. This F11 option is not always displayed. If this doesn't work then your hard drive is corrupt or damaged and you will need the discs (and potentially a new hard drive).
Posted on Apr 13, 2008
SOURCE: restore window vista for acer aspire 5920
Hi Acer supply the restoration files in a hidden partition on your hard drive. If it is the same as mine try this. Start the pc, then while the Acer logo is showing, press ALT & F10 at the same time. Then just follow the instructions. Bear in mind that this will format your C drive so you should do a backup of any important data first. Hope this helps.
Posted on Sep 27, 2008
  • 52 Answers
SOURCE: restore back to factory settings
From Acer direct
If you see this:
1alexh
  • 484 Answers
SOURCE: restore a acer aspire 4330 back to factory settings
Follow these instructions carefully:
To start the recovery process:
1. Restart the system.
2. While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3. Refer to the onscreen instructions to perform system recovery.
I copied the above from an Acer manual, and it works on my own system, which is not the same model as yours. But you must understand that this will basically restore your computer to the condition in which it was when you bought it, unpacked it from the box, and followed the instructions to set up a new computer.
This will give you your system back as if it were brandy new, but in most cases, anything you created, like DOCs, or XLS files, again … ANYthing you created since buying this computer, will also probably not be there any more.
You will have a pristine, clean as new, computer system.
Be careful, be absolutely sure this is what you want to do, and go ahead and do it.
-a.
Posted on Dec 15, 2009
Acer Aspire One AOA150 Recovery
you might be able to go to the web site for your model computor and order a restore disk. I ordered one for my laptop from hp for 15.00
Nov 12, 2014 | Acer Aspire One AOA150-1570 Notebook PC
Acer does not have cdrom for reboot
Hello, if you're referring to a Manufacturer Restore or so called PQI service it's easy.. Restart your acer or power on, make sure you hold on the ALT key + and press repeatedly the F10 button..This will take you to the manufacturer restore.Just follow the on screen instruction.
Mar 11, 2014 | Acer Aspire One D257-13404 Netbook 1.66 Gh...
I want to reset my acer aspire one D250-1042 for sale
This model Acer has a restore partition on the hard disk.
Check out this WEB site for instruction on restoring the laptop back to the out of the box condition.
http://www.pctechbytes.com/acer/acer-aspire-system-recovery-partition/
Oct 21, 2012 | Acer Aspire One D250-1042 Laptop Computers
How can I reset an Acer Aspire M3600 to factory defaults without the recovery disk
Maybe going to a restore point which should be automatically stored in your computer....you may lose recent info. Just search your computer...like in the "Control Panel"..."computer"...or similiar icons on desktop and it will lead you to a restore facturpoint or a way to set manufacture default settings
Jul 07, 2012 | Acer Aspire M3600 Drivers Recovery Restore...
I have a problem with my ACER ASPIRE 3683WXMI lop top. does anyone have any Ideas on how to Reprogram...
reprogram what. but if you want to bring in factory condition then when turn on power press ctrl and f10 together before booting it will go to factory restore menu from here you can restore windows to factory contion
Mar 02, 2012 | Aspire Acer AS5315-2856 Laptop
I want too restart my aspire as in backto zero, i cannot connect to internet
Not sure what you mean by back to zero. If you want to restore it to its factory default condition, then do the following which will not only clear all user data but remove any malware or viruses. Before starting the procedure, make sure the netbook is plugged into its AC adapter to ensure the restore to factory default condition proceeds to completion without being interrupted by low battery.
1. On power-up while the Acer logo is showing...
2. Press and hold down the Alt key then press the F10 key repeatedly
3. Screen should then indicate starting the Acer eRecovery Management environment.
4. Wait until eRecovery has loaded and its menu asks How would you like to restore
5. Click on Restore system to factory default
6. Once retore is complete, the system will restart Windows for setting up its configuration
Jun 01, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have an acer aspire AST180 UA381B and I need the system restore disks but they do not carry them anymore. What can I do?
I would suggest you install Linux Mint 10, a free operating system.
Without the restore disks,you would have to buy a new Windows CD. Have a friend burn an ISO image of Linux Mint. Just go to www.linuxmint.com, and there are lots of helpful tips there on how to install. Linux Mint has a similar feel to Windows, so it should be good!
Mar 29, 2011 | Acer Aspire (AST180-US340B) PC Desktop
When i boot from cd with my t 120 restore discs in nothing happens
I would suggest making sure the discs are in prestine condition and also that your your cd rom is clean as well if nothing happens still you should contact the manufacturer about maybe downloading the restore disc to another media i.e. zip drive or external HD and simply boot from that to do a restoration
Mar 28, 2010 | Acer Aspire T120 PC Desktop
Want to reset my aspire 5315-2326 to out of box condition
Most Acer computers have a built-in system restore partition that will restore the computer to factory settings. At startup, press the F10 key and you will be directed to the system restore menu. Follow the instructions there to restore your system.
CAUTION: This will format your hard drive and you will lose all of your data. Back up anything that you want saved from your hard drive BEFORE you begin this process.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 13, 2009 | Acer Aspire 5315 Notebook
How do i restore my acer aspire 5715z pc back to manufacturers spec plz?
Restart the laptop while pressing the F5 button you should be introduced to a menu that will allow you to restore to factory spec..................
Dec 26, 2008 | Acer Aspire 5315 Notebook
Acer Aspire Laptop PC V5-531-4636 Logo
2,689 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
