Question about Memorex Xtrememac Luna Sst
The screen of the sst luna dosen turn on what should i do?
00602-003 error
Your hard disk needs to be replaced!! E602-003 is a bad sector read on the hdd, if you restart the machine it may work for a while but it WILL come back.
You need canon part number WM2-5230-000 (not sure how you would get it) it needs to be installed in the back of the machine at the top of the main body after the back cover has been removed.. Once this is done you dilemma begins, Canon uses a program called "service support tool (SST)" which is only a canon issued program, this program is the tool used to update all the software and firmware in iR devices. This can only be connected to a 2200 machine via usb to centronics cable with a "nethawk driver" driving the cable. Then SST need to have the firmware for the 2200 series registered (it does not come together) within SST, then connect cable and turn the machine on at the switch on the right hand side WHILE holding keys 2 & 8 together, this will give you a black screen which only shows "DOWNLOAD MODE" in the lower part of the screen. Then the machine is ready to accept the data. SST is extremely touchy, so if anything is not right you will get a lovely pink screen in SST saying an error code. To correctly set up the hard drive you must first format the HDD from within SST, then install the BOOT and SYSTEM versions (boot must be "N" at the end of it's version eg. 37.44N to be a printer or a stand alone copier will have a "C" at the end. You must pick the right one or you will not be able to print (if it has a PCL kit installed in the machine).
After all Boot, system, language, fax versions are installed restart the machine, wait for a couple of minutes intil all that data is written to the HDD and it will pup up ready to go.
Apr 22, 2014 | Canon iR5000-6000-L1 PS Ver 1.0
Luna milano crib assembly instruction
Here is the link to the manufacturer's instructions page. Locate your exact model number (they are in alphabetical order) and download your manual. Milano Cribs by Pali Link
Jan 19, 2013 | Sweet Beginnings Bella Luna Milano Crib
How to fix the problem when it is display "download standby" in the screen in my photocopier machine of Canon iR2116J?
you need to upgrade the firmware. you need the latest firmware and sst. first install the sst on the system. open sst, registerfirmware or ir2116j. connect the machine to pc and start down loading. do as per the instructions on the display. if you are not an authorized service professional you are notgoing to get the firmware and sst. so better contact authorised service professional
Apr 07, 2011 | Office Equipment & Supplies
Won't print;
The problem means that your hard disk needs to be replaced. E602-003 is a bad sector read on the hdd, if you restart the machine it may work for a while but it WILL come back.
You need canon part number WM2-5230-000 (not sure how you would get it) it needs to be installed in the back of the machine at the top of the main body after the back cover has been removed. Canon uses a program called "service support tool (SST)" which is only a canon issued program, this program is the tool used to update all the software and firmware in iR devices. This can only be connected to a 2200 machine via usb to centronics cable with a "nethawk driver" driving the cable. Then SST need to have the firmware for the 2200 series registered (it does not come together) within SST, then connect cable and turn the machine on at the switch on the right hand side WHILE holding keys 2 & 8 together, this will give you a black screen which only shows "DOWNLOAD MODE" in the lower part of the screen. Then the machine is ready to accept the data. SST is extremely touchy, so if anything is not right you will get a lovely pink screen in SST saying an error code. To correctly set up the hard drive you must first format the hdd from within SST, then install the BOOT and SYSTEM versions (boot must be "N" at the end of it's version eg. 37.44N to be a printer or a stand alone copier will have a "C" at the end. You must pick the right one or you will not be able to print (if it has a PCL kit installed in the machine).
Thank you !!
After all Boot, system, language, fax versions are installed restart the machine, wait for a couple of minutes intil all that data is written to the hdd and it will pup up ready to go.
Hope this helps.....
May 21, 2010 | Canon imageRUNNER 2800 Black and White...
Canon ir3300 error602-003
how to install data in the hardisk of ir 3300 machine. plz say me the full process what is sst and everything
Dec 09, 2009 | Canon Office Equipment & Supplies
Where can I buy new wheels for my mamas and papas luna pushchair?
Hi does anybody know if you can get replacement wheels for the luna/luna mix??
Jul 23, 2009 | Baby Gear
How to format nokia 8600 luna ??
After honoring the screen gives white ekaranin
May 03, 2009 | Nokia 8600 Luna Cellular Phone
Screen lens nokia 8600 luna
dont try at home u will lost ur 8600ok
Feb 22, 2008 | Cell Phones
E602
Turn on holding down 1 and 9 keys. will go through a long complete format. If blocks do not fall down through screen left to right, HDD is completely gone.
Nov 23, 2006 | Canon imageRUNNER 8500 Copier
Memorex Xtrememac Luna Sst Logo
12 people viewed this question
Top Memorex Audio Players & Recorders Experts
Greg Cann
Greg Cann
 Grubhead
Grubhead
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
