Question about Canon EOS 1100D / Rebel T3 Digital Camera
I have a canon rebel T3 . How do I change the aperture ?
I'm trying to complete a class assignment requiring taking pictures with changing aperture openings and F stops. Can't seem to find how to change the aperture .
  • Ronda Lynch Dec 02, 2012
    OK - that worked ! Is there a way to set the f stop & aperture seperatly ?
  • Chris Hingee
    Chris Hingee Dec 03, 2012
    The F stop and aperture is the same thing. The size of the aperture is determined by the F stop. The larger the F stop number the smaller the aperture hole size.
  • Canon Master
  • 32,281 Answers
On right hand top of the camera there is a Mode dial. Move the dial to Av (aperture priority) then rotate the wheel in front of this dial to set the F stop. The shutter speed will automatically adjust by the light meter.
Posted on Dec 02, 2012
  • 155 Answers
SOURCE: Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Posted on Apr 09, 2009
dlundmark
  • 797 Answers
SOURCE: Canon Rebel XT I can't change aperture or shutter speed in manual mode
You may try this. Reset all in the menu setup.
What you will be doing to to reset all the settings back to factory settings. Then you will want to go through the settings and reset them the way you prefer.
Posted on Aug 24, 2008
SOURCE: Rebel xt will focus but wont take pictures
I had this issue just this morning, and came here for a solution.
Problem: Camera functions normally except it will not take a picture, let me autofocus, or bring up the light meter in the viewfinder.
Attempted Solutions: First turned it Off/On. Then Switched lenses, same thing. Removed/replaced battery, changed settings. Removed the lens, and it takes a picture, replaced the lens, and it still will not. Then I came here, and heard that it was most likely an issue with the lens contacts. I've heard of Rebels having error 99's which were contact errors, and canon's official solution was to use a pencil eraser (like the one attached to the back of a No.2) and gently rub the surface of the contacts with it, and it worked in that situation.
Guess what? This solution worked instantly, and my camera is back to normal. I don't know if it will work long term yet because I just tried it like 10 mins ago and only after taking down all of my lighting equipment, but all seems well.
Posted on Nov 30, 2008
  • 6 Answers
SOURCE: Canon rebel XS error 99
Instead of taking out the battery, just open and close the battery compartment to reset the camera.
SVRGuy02 is right, set the slep time longer to avoid the issue so much and just open and close the battery compartment before beginning each shooting exercise
Posted on Jul 16, 2009
old marine
  • 2126 Answers
SOURCE: my canon t1i rebel does not take pictures and says its busy?? wha
In the manual mode, you have to set the focus (distance to subject), aperture and shutter speed. Did you set all of them before you shot the picture?
Posted on Feb 26, 2010
Why does my canon eos rebel t3 not take a picture when the shutter button is depressed but tje red eye reduction button keeps flashing and the video still works?
Usually, it means that the timer function has been turned on, and the camera is going through a countdown to trigger the shutter.
After that, it means that something else is not working correctly. If video works and records, then you know that the sensor and memory are functioning correctly. At that point, check to see whether your camera and lens are set for the form of autofocus or manual focus you want and that the aperture is still functioning correctly.
At some point, switch the camera to an all manual settings mode and try the shutter switch. If it still does not take a picture, the switch may have a problem.
Aug 18, 2014 | Canon EOS 1100D / Rebel T3 Digital Camera
Can't see picture of computer but can on camera
Install the Canon Raw software on the disk that came with the camera :-)
Jul 08, 2014 | Canon EOS 1100D / Rebel T3 Digital Camera
My manual setting is not working. Everytime I try to take a picture using manual mode without flash its dark.
Just to make sure, you are setting the proper exposure? In manual mode you have to set both the aperture and shutter speed yourself. If you don't set them properly then you'll get under- or over-exposed pictures.
Mar 19, 2013 | Canon EOS 1100D / Rebel T3 Digital Camera
I'm having trouble trying to change the aperture on Manual mode
Use the wheel next to the on/off switch. It should be at normal position for your right thumb. Make sure the On switch is all the way up to the line, past the first on-setting. This enables the wheel.
Dec 01, 2012 | Canon EOS 1100D / Rebel T3 Digital Camera
Canon T3 flash flutters and does not take pictures help!
The 'fluttering' is a pre flash used to help the camera focus in low light. The internal flash isn't a powerful flash and is usually only good enough for subjects up to about 2m away in reasonable light also to light a subject that is back lit. Try putting the camera in manual mode (M) 1/60sec on f5.6 flash popped up review it and make adjustments accordingly i.e. open up or shut down the aperture as the flash usually syncs at 1/60
Aug 13, 2017 | Canon EOS 1100D / Rebel T3 Digital Camera
Canon t3 wont display images
Try resetting the camera by removing thebattery for 15 mins. Then install the fully charged battery in the camera andgo to the menu and set the Date and Time.If this does not work then this camera needs to be sent away forrepairs. Just like a motor vehicle, some repairs to your camera require atechnical specialist to fix your problem.
Apr 18, 2012 | Canon EOS 1100D Rebel T3 Body Only Digital...
How do I change the colour settings on a canon rebel t3
Full details are in the "Shoot by Ambiance Selection" section of the manual (page 64 in my copy). If you need a copy of the manual, you can download a copy here.
Mar 20, 2012 | Canon EOS 1100D / Rebel T3 Digital Camera
Canon rebel T3 focus problems
in manual mode, will not try to focus itself, my be the manual auto switch is faulty, or the focus related mechanism not rotating the lens, open the lens carefully check the focus motor and gear set (engine is the technical term)
Sep 01, 2017 | Canon Rebel XT / EOS 350D Digital Camera
My canon t1i rebel does not take pictures and says its busy?? wha
Feb 26, 2010 | Canon EOS 500D / Digital Rebel T1i Digital...
Aperture setting and shutter speed together?
Yes it does. Check your manual. If you don't have a manual you can get a pdf download from canon. This link should get you there. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=214&modelid=9429#DownloadDetailAct
Sep 01, 2009 | Canon EOS Rebel K2 35mm SLR Camera
Canon EOS 1100D / Rebel T3 Digital Camera Logo
1,093 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
