Question about Electrolux EWMED65IMB
Dryer gasket ripped
I tried just taking out the screws around the door, but apparently there's more to this than I thought. Do I need to take the front panel off, and does that mean taking the top off, then the control panel, etc?
  • Tom Dooley Dec 04, 2012
    Actually, that's not true. Looking at the schematic that's available at the convenient parts link you posted, you can clearly see that there are 2 top and 2 bottom screws for the front panel. And those 2 top front panel screws are only accessible by removing the top cover, with the 2 screws at the back. I figured this out a couple of days ago and was able to replace the gasket. I do appreciate your response.
    Top Expert:
  • Electrolux Master
  • 9,472 Answers
Remove the screws on the bottom of the front panel is all you need to do to get to it. Here are all the parts for your dryer if you should need to order any of them.
Posted on Dec 02, 2012
How to repair a lg dryer dlex3470v
See the groove on the edge where the gasket fits onto the door? As you peel away the gasket, you'll see how you need to thread the gasket onto the door flange so that the gasket will fit properly.
Use a silicone-based spray on lube to help it slide back on. Start at the top & work your way around the edge pressing the gasket groove onto the metal as you go. You might not even need a new gasket unless it is damaged.
Aug 14, 2014 | Dryers
Rubber gasket around window on door of dryer is coming off
It sounds like it is worth a try to re-attach the existing gasket. I would try some silicone based adhesive. It sticks to most anything, remains flexible and can take high heat. Maybe something like this:
https://www.lowes.com/pd/E6000-CLR/50149282
Jan 15, 2018 | LG Washing Machines
How do I replace the oven door gasket on my VGIC3686
Replacing a Door Gasket
If the oven won't heat to the desired temperature or heats unevenly, the problem could be a defective door gasket. The best way to test for this is to pass your hand around the door, being careful not to touch it, while the oven is turned on. If you can feel heat escaping, the gasket needs replacement. Replace it with a new gasket made for the range.
On most ovens, the gasket is located on the frame of the oven, and the door closes against it. This gasket is generally friction-fit in a channel and can be replaced. In other units, the oven door has two sections, and the gasket is not mounted on the door frame, but is installed between the front and back sections of the door. Don't try to replace this type of gasket; call a professional service person. Here's how to replace a frame-mounted gasket:
Step 1: Pull the old gasket out of the channel. On some oven door frames the gasket is held in place with screws. To get at the screws, bend back the exposed edge of the gasket.
Step 2: Clean the channel and the door frame with a solution of mild household detergent and water.
Step 3: To install the new gasket, start the replacement at the top of the door frame and work down the sides, easing the gasket around corners. Finish the installation along the bottom, butting the ends of the gasket firmly together.
Apr 16, 2012 | Viking Kitchen Ranges
My front lambda sensor has gone on my vw golf reg x509egc what price range shud it be to get it fixed coz i dont wanna get ripped off. many thanks paul
Being ripped off is when money changes hands & NO
Service whatsoever is performed.
That is called Fraud & is a crime
Your never ripped off, ever
You just don't like or understand the
service agreement between you &
the merchant
O2 sensors cost around $40.00 & could go
above a hundred on eruo vehicles
Look on ROCK AUTO.Com for a price & different brands
You surely can screw in any O2 Sensor yourself
It won't take more than 10 minutes
You being in the UK vs: the US who knows what they cost
Sep 23, 2011 | 2001 Volkswagen Golf
Door does not close properly - need door gasket
if the door gasket is not ripped you may try taking a hair dryer to the ares that dont seem to be touching the frame of the cooler. Hold the hair dryer about 6 inches away from the gasket and move it back and forth slowly taking care not to melt the gasket or any of the sourrounding plastic.
Sep 01, 2011 | Haier HVT12ABS Compact Wine Cooler
The freezer gasket is no longer sealing properly allowing frost to buildup around the edges which eventually falls into the refrig area, thaws and leaves a puddle. Can we replace the gasket?
Yes, the gasket is replaceable, for modest cost and difficulty=easy.
Where to get new gasket: take exact Mfr. & model number (and serial number) of fridge
to your nearest
major appliance parts store (see yellow pages). Call them, to see if they have your replacement
gasket in stock, or may need to order it.
How to replace gasket: pull back inner edge of gasket until your see the 1/4-in hex head machine
screws attaching it to the freezer door. Using nutdriver, unscrew old gasket's screws, and
install new gasket by reversing the procedure, starting with the top middle screw, and proceeding
around the edges.
Its a "nutdriver project." If for some reason the screws are too rusted to re-use, an equivalent screw
(just match the diameter and length) is easily
(and inexpensively) obtained at your nearest hardware store - you won't even need to return to the
appliance parts store.
This procedure works for most standard freezer-over-fridge units - you can include your exact
Mfr. and model number in your next query for more precise info.
Jul 04, 2011 | Refrigerators
Dishwasher keeps leaking from door
Hi, if it is leaking around/under the door, it must be the seal around the door. Check to see if the seal needs to be pushed in somewhere or is damaged..
Try running the cycle with no dishes in the washer and see if it leaks, it sounds like a gasket in the door to me and you can also check hose by removing the front panel on floor and check there....
Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
Jun 22, 2011 | Bosch SHU9915UC Dishwasher
Haier BC112G wine coere is an apparent spill that
you will have to gently pry it all around with a thin scraper, i am assuming there is no sealer as fluid would not have leaked in if there was.be gentle but forceful.
Oct 17, 2009 | Haier BC112G Wine Cooler
KHWS01PWH0 Front Loading Automatic Washer Leaking
out the bottom of door?? no through the bottom panel???. check the rubber door seal for rips or tears pull it back and look around entire circumference. smalll rip in very front of seal where door should close against will cause leak for sure
Mar 07, 2008 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
Electrolux EWMED65IMB Logo
Top Electrolux Dryers Experts
John Tripp
John Tripp
vince
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
