Question about GE DCVH515EFWW Electric Dryer
Change belt GE dryer dcvh5150ww - GE DCVH515EFWW Electric Dryer
    Top Expert:
  • GE Master
  • 9,472 Answers
Here are some videos for the belt replacement.
Posted on Dec 02, 2012
Tip
Fridgidaire and GE Dryer Belt Replacement
Here are the belt diagrams for replacing your dryer belt for Fridigaire and Ge Dryers
For Fridigaire dryers 1970-1985
9b6122a.gif Style: Flat with ribs
Installation Tips: Ribs face toward drum
For 1985-1995
For 1995- present
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
For Ge Dryers
1970- 1990 standard capacity
Installation Tips: Ribs against drum
1970- 1990 Large capacity
1990 – to present
on Mar 02, 2010 | Dryers
How do i get into the dryer to change the belt GE dde6500galwh
There are probably 2 screws on the back towards the top of the machine, on the left and right sides of the machine. unscrew those then take a flat-head screw driver and pry the front of the top of the machine off on each side there is a clip holding it...
there is also a access door in the back of the dryer somewhere, that will likely expose the motor and belt tensioner/spring. release tension and belt should come looser.
Nov 17, 2009 | GE Dryers
My Dryer portion of my GE stacked washer/Dryer will turn on and I can hear the motor running but the drum will not turn. I pretty sure is the belt. I haven't been able to locate a schematic anywhere of the...
Not that easy but go to this web site www.applinace pros.com and look at it's diagram and you can see if you want to tackle this issue, if you do and rn into problems you can get help from us here if you need it.
Nov 13, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
GE DRYER WON'T TURN ON
when you changed the belt, you had to take it apart and remove the front of the dryer am I correct? If so when you put it back together did you make sure to re-connect the wires that go to the door switch? Those wires are the only ones that you should have disconnected to remove the door along with the front. See if you forgot to re-connect them ok?
Feb 17, 2009 | GE Dryers
Need to know the exact way to put belt on ge dryer model number DDE7200RALWH cant figure it out around the pulleys , ge assures its the right size belt for the dryer , but belt seems loose and drum wont...
with belt around drum, pull idler back with tension on it and put belt over pulley of motor and let idler up against belt and it should be right ,,,, larryyb
Dec 10, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
GE DCVH515EFWW Electric Dryer Logo
85 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
