Question about Kitchen Ranges
Whirlpool 465 gas range - oven does not ignite
Hello, I have had this Gas Range for over ten years now. It has been working fine. Two years ago I had to replace the ignitor for the oven since it was not working properly. As of yesterday, when I set the oven on bake (default to 350) it starts the timer for 10 mins as usual to get the oven to this temperature. I can see that the ignitor goes on and becomes incandescent, but the gas never seem to flow to actually start the oven. The temperature in the oven goes up a bit, but that is just the resistor that is warming up the space and not actual oven. I don't get any error messages on the console on the top. II would greatly appreciate any help. Sincerely Luca
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 01, 2012
  • 2 more comments
  • Luca Bogoni Dec 02, 2012
    SF385PE60, RJ1510681 Thanks in advance for any insight.
    As I have checked some of the other proposed solutions. I smell no gas while I do see that the ignitor get glowing hot
  • Richard Roth
    Richard Roth Dec 02, 2012
    Test the temp sensor. It should read around 1100 ohms at room temp and around 1650 ohms at 350 degrees. Here is the probe to order if you find it bad.http://bit.ly/11mxitI
    Thank you for the suggestion. I will look and see. Appreciated the link to the temp sensor as well.
SOURCE: Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
I just had my ignitor replaced. The ignitor glowed but it must pull a certain amount of amps before it will allow the gas valve to open. Once the ignitor starts glowing the gas should come on within 30 seconds. Now that I saw it done I realize it was something I could have done myself. Be sure the tech does not try to slip you a used ignitor as mine tried.
Posted on Jun 10, 2009
duby1990
  • 367 Answers
SOURCE: the range on Whirlpool Super Capacity 465 will not ignite
You need to replace the oven ignitor. This is located under the bottom pan of the oven. Take out the racks and then remove the 2 screws from the back section of the lower plate. Then you will find the ignitor. The ignitor may still get red but the ignitor has to draw enough current to open the gas valve. This is a very common problem. Replace the ignitor and this will fix your problem.
Posted on Feb 06, 2009
fridgetech
  • 473 Answers
SOURCE: GE RANGE MODEL #JGBP35BEA2BB
Sounds like that ignitor is weak.  When the ignitor glows it builds up resistance to the gas valve for gas to come in.  If it sometimes takes 10 min then the proper resistance isn't there and this will give you that gas smell.  Replace the ignitor and this should solve your problem.  Can expect to pay $80 - $100 for the part.
Posted on Oct 14, 2007
SOURCE: whirlpool super capacity 465 gas range model# sf377pegq5
I have the same problem intermittently on my Super Cap 465. After reading the following quote from another site, "There have been cases where radio waves, electronic signals and sometimes something as strange as dimmers in lights have caused some weird problems with some computer panels in stoves like these", I tried turning off lights that might be on the same circuit and wouldn't you know it, the oven igniter circuit worked.
Posted on Jan 04, 2009
i dont know want is wrong with it when i turn the oven on it keeps saying e2 and f3 i dont know what that mean please help me one on .... :(
Posted on Nov 28, 2009
Whirlpool supercapacity 465 gas oven will not heat up all of a sudden
Does the igniter glow white hot? What is the complete model number?
Feb 13, 2013 | Kitchen Ranges
WHIRLPOOL Sup Cap 465 oven turns on for 3 sec, then shuts off
The flame sensor is dirty or bad.
When the unit does not sense flame after ignition, the gas valve shuts down the system.
They can become corroded or dirty, but usually just need to be replaced.
Contact whirlpool for warranty info. If the unit is under warranty, they should send you the parts for free. If not, they can direct you in how to order the part.
http://www.whirlpool.com/custserv/email_form.jsp
Sep 26, 2009 | Amana AGDS902 Gas Kitchen Range
Whirlpool 465. The top range burners will not ignite. I can hear and smell the gas. The oven burner works fine. Do I need to replace an ignitor for the range?
The bake is seperate from the burner ignition system. You may need a new spark module for the top burners. All burners should spark at the same time even if you are only trying to lite one burner.
Aug 27, 2009 | Ovens
Oven works sporadically
IF YOU CAN SMELL GAS, TURN THE STOVE TAP OFF. Get it checked out immediatly.
Aug 03, 2009 | Whirlpool GS460 Gas Kitchen Range
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
The range on Whirlpool Super Capacity 465 will not ignite
Feb 06, 2009 | Whirlpool GS460 Gas Kitchen Range
Dec 05, 2008 | Whirlpool SF357 Gas Kitchen Range
Whirlpool super capacity 465 gas range model# sf377pegq5
Aug 20, 2008 | Whirlpool GS460 Gas Kitchen Range
Kitchen Ranges Logo
165 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
