Question about GE Profile Spectra JGB920 Gas Kitchen Range
My GE JGB920TEC3WW has been heating up very slow and now while I was cooking a roast for a few hours I smelled gas. Tried running a clean cycle, the broiler came on, but I think the lower part is sup
My GE JGB920TEC3WW has been heating up very slow and now while I was cooking a roast for a few hours I smelled gas. Th eraost still cooked. I tried to increase the temp afterward and instead of increasing it just got cooler. I turned it off. Tried running a clean cycle, the broiler came on, but I think the lower part is suppose to also. Is this the ignitor like the other person's?
    Top Expert:
  • GE Master
  • 9,472 Answers
You are absolutely right! You will need to replace the sensor. Here is the part to order.
Posted on Dec 01, 2012
catriver
  • 878 Answers
SOURCE: Oven will not heat up.
eerb, most likley your ignitor failed. When you turn the oven on to bake you should hear a relay click on the electronic control (clock). You can do a couple of things here. If you have a ohmmeter the ignitor should ohm out at between 50 and 150 ohms. You can physically swap out the bake and broil ignitors to see if the ignitor comes on in bake. Or you can swap the bake and broil wires on the board. They should be marked BA and BR. This way when you turn on bake, the broil ignitor should glow and verify you have power going to it. Carefull when testing, be sure to kill power to the range before any changes. Catriver...post back
Posted on Dec 12, 2006
jsrock516
  • 5911 Answers
SOURCE: GE Profile Spectra JGBP85
Yes, it could very well be an igniter. The igniter can still glow and not work. The reason being that the igniter (depending on type) needs to produce .25 to .37 amps in order for the gas valve to open. If this potential is never reached, the igniter will glow, but gas will never flow. Or, gas will eventually flow for a weak (slow) igniter and will take forever to ignite. Which could be the reason for your low bake temperature. The burner does not stay lit all the time during the bake cycle. It will cycle on and off as needed to maintain the oven temperature. If the igniter is taking a long time to relight the burner, it could take a long time to heat. The broiler has a separate igniter and probably doesn't get used as often as the bake igniter. You can test the theory by swapping the igniter between the bake and broil burners and see if the problem moves to the broiler. Make sure you secure power to the range BEFORE attempting to remove the igniter, however. You should not have to turn off the gas to do this. Everything should be accessible through the oven door and broiler. I tell you this, because a new igniter (depending on the type you have) can run as much as $100. It will probably be worth the effort just to be sure. I hope this helps you.
Posted on Jul 15, 2007
Krazytech
  • 725 Answers
SOURCE: Oven not lighting
Hi The gas valve will not open until the ignitor pulls enough amps around 3.2 . so from the infromation you wroke you may need a new ignitor..let me know what you can find out..
Posted on Sep 03, 2007
leroyal
  • 2120 Answers
SOURCE: Oven won't heat. No gas smell. Broiler and stove work.
Bad oven control circuit board. Look up on eBay
Posted on Feb 21, 2009
Maytag317
  • 1136 Answers
SOURCE: No Bake; everything else works
Hi, When you put the oven on bake, can you see the ignitor glowing but get no flame?
Sound like the ignitor might be getting weak and not opening the gas valve. Please let me know if this sounds like the problem.
It is common for the ignitor to go bad. Even if it glows, it can be bad.
Please let me know if I can assist you further.
Vic
Posted on May 31, 2009
How to cook a pork shoulder blade roast
in a pot on the stove or in a slow cooker .
May 01, 2017 | Grilling
Della 12 Quart 1600-Watt Electric Pressure Cooker Multi-Functional Timer Slow Cook XL Part number: 048-GM-48261 Unable to get this cooker to slow cook.
it is possible that you have misunderstood the instructions
for a slow cooker you have low medium and high
press slow cook and on low and in 8 hours the food is cooked
I see from your statements that you expect the cooker to be set on slow cook but cook at a high temperature fast
if it says slow cook --9 hours and the temp is 125 degrees , have you waited 9 hours to see if it is cooked as the slow cooking process is by the gradual build up of heat in the container that is not expelled by radiation to the air
in a pressure cooker , that build up of heat also builds up pressure and so it cooks better
other solution--- if it is not right return it for a warranty refund or if out of warranty , junk it and get a different make
Mar 25, 2017 | Crock Pots & Slow Cookers
Hoq to cook a blade roast pork in a crockpot
Low and slow. Cook the pork roast looooow and slooooow. Trying to rush this cut of meat just isn't a good idea. Cook the pork roast in a slow cooker for anywhere from 8-10 hours. Brown it before cooking.
Jan 18, 2017 | Grilling
How do you cook a roast with potatoes and carrots
  1. Place roast in crockpot.
  2. Sprinkle 1 tsp salt over one side of the roast. ...
  3. Then add garlic, oregano, and thyme evenly over the meat.
  4. Tuck the onion quarters, carrots and potatoes around the roast.
  5. Add ½ cup beef stock/water and turn on low for 8 hours or high for 5 hours.
Mar 24, 2016 | Crock Pots & Slow Cookers
Why do my roast potatoes take two hours to cook what am i doing wrong, cooking at190 degrees
I'm not really an expert in cooking and I've never roasted potatoes in some Crock Pot or Slow Cooker but for sure you need more then 190? (guess F?) to roast potatoes.
You should look up a receipe book for your device, like this one:
http://www.crock-pot.com/recipes.html
Aug 23, 2015 | Crock Pots & Slow Cookers
GE DPXH46GA6CC gas dryer makes large humming noise in heat cycles and burning smell
Two things are likely going on here,1- something is dragging down your motor check for a twist in the belt, idler pulley bad, belt installed wrong or wrong belt. Also check your front drum felt and glides if the felt is bunched up that will drag down the motor. Now the smell you probably have some felt or lint in the burner clean it carefully you do not want to damage your igniter.
Aug 04, 2013 | GE Dryers
Whats the difference between a slow cooker and a roaster oven?
a slow cooker just cooks slowly. a roaster oven however roasts food just like in a range oven. they can usually also bake and slow cook also. roasting cooks at a high heat while slow cookers are a lower heat for a longer time. roasters are great to use because the meat tastes really delicious and also the whole kitchen will not get boiling hot like with roasting in the oven.
Jan 24, 2013 | Kitchen Appliances - Others
How long should i cook on high a full crock pot with vegetables and raw meat
when do you want to eat? It usual takes a good six hours on high.
Dec 31, 2012 | Rival Crock Pots & Slow Cookers
Accidently started clean, food inside,hit cancel,can't open
you would have to disassemble the cook top in order to get the the locking mechanism to manualy unlockit
May 01, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
GE Profile Spectra JGB920 Gas Kitchen Range Logo
128 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
