Question about Western Digital Computers & Internet
My external wd elements not reading and the light in the hardisk is on but not blinking
Its a hard disk that i was using until one day i plugged it to my frnds computer and when i bought it back the speed was low and my hardware was not recognizing anymore
  • febinaz
    febinaz Dec 01, 2012
    i was running smoothly before i plugged it to my frndz pc
  • febinaz
    it was having great speed too but now i dont know what happned
  • 2,072 Answers
Could have picked up a virus from your friends computer, or the device is just on the fritz. It also could have been corrupted. When removing an external hard drive you should always go to the bottom right click on the little green arrow icon and select "safely remove <your device>" otherwise you risk corrupting the files on it. Plug in the hard drive to your computer. Right click on Computer/My Computer and select Manage. Click on Disk Management on the left side. If your device shows up then the drive most likely has corrupted files or the file table. Right click on your device and initialize it if it isn't and then format the device and it will work again. You will lose all your data in the process. You can download Recurva from piriform.com to try and recover your files if you like. If the device doesn't show at all in disk management then I'd say its toast.
Posted on Dec 02, 2012
  • 355 Answers
SOURCE: samsung external hard drive not recognized
its happens when the hard drives cable or usb port is problem
change the ccable then try
other wise plug the pci usb card & first diseble the motherboards usb port
then try
ok bye..........................................
Posted on Nov 17, 2009
marcopenat
SOURCE: My Computer does not show: Western Digital My Book Essential Edition 500 GB external USB hard drive
Well i got a simple 320 gb external hard drive, and since the first month i had problems, i solve the recovery issue by opening the hard drive, and find it out, the inside was broken, and it got unplugged. so plugged it back and got my info. if your data its more important than 200dlls or less break the thing open, because if you claim the warranty they are not responsible for your information.
Posted on Dec 13, 2008
SOURCE: My I Mac doesn't recognize the WD 500GB external drive anymore
it must be initialised /mounted 1st for osx
Posted on Mar 08, 2009
kamal1984
  • 1383 Answers
SOURCE: Transcend 160GB Portable Hard Disk is not recognized by computer
when you power up the computer press F2 or "del" key to enter in bios then go to usb option and enable usb 2.0 legacy. then save settings .
then check.
some times usb speed make issue so try this.
Also check your usb cable working fine try with other usb cable.
Also check harddisk jumper settings.
If still face problems then you need to repair it.
You shuold take it to service shop becasue you try with 10 computers and all gives same error then your harddisk has hardware issue.
try above solution .
Thanks for using fixya.
Please rate my solution if it helps you.
Posted on Jul 20, 2009
bob_computer
  • 3153 Answers
SOURCE: my mac won't recognize my wd hd anymore
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Posted on Aug 31, 2009
My WD elements 1.3 TB external hardisk. It gives a buzz when connected and is not recognised by windows
It sounds like the HDD inside is dead. The USB interface may have an issue but usually clicking or buzzing is HDD failure. If you have a desktop you can try removing the hard drive from the external case and connecting it directly to the computer using a SATA cable.
Jun 19, 2016 | Western Digital Wd Elements Se 1tb...
My hard-disk is on-Warrenty basis.On hardisk light is blinking but unable to detect on pc ,So Please tell me the procedure how to recover my data. P/N-WDBAAA5000ABK-00 S/N-WXM1A80N4025N
Can you hear the drive spinning when you connect it to your computer? A spinning sound means your external drive is being powered by the USB from your computer - there are several reasons the drive is not being recognized.
If you are not hearing any spinning sound the drive could be damaged.
Does the drive get recognized by any another computer? If yes - check disk management and see if security is enabled on the drive. Also - check to see if there is a drive letter assigned to your external hard drive.
Link
Feb 28, 2011 | Western Digital WD Passport 250GB Portable...
My wd elements hard drive cannot connect to any laptops or pcs there is some kind of bad smell from my power adapter i try to use 5 usb cables to connect to laptops it isn't hot at all when i use the...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 31, 2010 | Western Digital Elements powered by WD 320...
We bought some time ago an WD External Harddisk and now the Adapter doesn`t work anymore! What can I do?
Try connecting it to a different computer.
Any external storage device has three major parts:
* USB cable
* disk-drive
* USB-to-disk-drive adapter
Disconnect the disk-drive from that adapter, and connect the disk-drive as a "slave" disk-drive in a desktop computer, and see if you can read the files, which implies that the adapter is the part that has failed.
If you cannot read from the disk-drive, check its WARRANTY status. W.D. will replace it, if the warranty is still valid.
Otherwise, W.D. has a "Customer Loyalty" program: find the serial-number of your unit, access their web-site, and purchase another W.D. external storage unit, at a significant discount, by citing the serial-number.
Or, if the adapter is OK, then replace the disk-drive by a new one, and close-up the casing, to create a "revived" external storage device for your use.
Oct 23, 2010 | Western Digital Elements powered by WD 320...
Computer is not recognizing my external hard drive
If the light won't blink, there could be problem with the power source. Do scanning hardisk for errors manually ( take off the hardisk from the case, assemble it on other PC Desktop)
May 06, 2010 | IO Magic Corporation GigaBank (I250HD35)...
External Disk WD Elements problem
did u format the wd 320 gb already
you have to format it first to work from it
Apr 06, 2010 | Western Digital Elements powered by WD 320...
The WD hard disk 160GB is not recognized after plugging into USB
It is very possible that your BIOS will not support a large hard drive. Without more information on your system it will be hard to diagnose your problem.
Oct 06, 2009 | Western Digital Elements powered by WD 320...
No power to my WD elements 1 tb
Same thing here. What about the data. Could you recover it ?
Jun 09, 2009 | Western Digital Elements powered by WD 320...
640 GB WD element hard drive has no power
Try it on a different USB port or on a different computer - is this hard drive powered via a mains cable ? If so is that plugged in and switched on as well ?
Also does the hard drive have an on off switch at the back or on it anywhere that needs turning on ?
Does this hard drive have a firewire port or another way of connecting to it ?
Apr 10, 2009 | Western Digital Elements powered by WD 320...
Computers & Internet Logo
609 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
