Question about PfaFF Tiptronic 2030
Pfaff 1222 frozen 20 mins after I start using it
Every time I use my pfaff it freezes after 20 minutes sewing..  I cannot move the  right hand wheel forward, only backwards which makes the machine foot go up and down very fast.  I have had my machine repaired several times. I am always told that there is a different problem. I love sewing but I fear I may have bought a lemon.  It is very frustrating. Just when I am whizzing along enjoying myself the machine stops.  I am considering buying a new machine which is not a pfaff because I am so tired of this ongoing problem.Can you help me please! Di from Australia
  • 3 Answers
My mother has had a Pfaff 1222 for 40 years and loves it. Take yours to a new/different repair shop or find an authorized place for an overhaul. It's not a lemon, just poorly maintained. you have a problem the service people just haven't figured out yet.  If you have taken the same machine to the same people with the same problem more than once and they tell you it's a different cause every time, they are not competent. Also check the owner's manual for any tips.
Posted on Jan 17, 2009
Pfaff 1222 part
Search for:
Pfaff 1222 parts
(may find it on eBay or some online sewing machine vendors)
Foot Control Pedal 90 222040 08 For Pfaff 1212 1221 1222E Sewing Machines...
Aug 01, 2017 | PfaFF Sewing Machines
My Pfaff 1222 will not sew; the needle moves up and down in the same hole. What does it need to fix this problem?
More than likely, the machine is seizing due to old oil that has dried out--probably affecting the movement of the feed dogs. As a mechanical machine, it needs frequent oiling and cleaning to keep it operating smoothly. Most older machines, like this, are set aside or abandoned for this very reason. If only their owners knew there is a very simple solution. They can be rejuvenated with some elbow grease, "good" sewing machine oil, and heat. Below is the method I've used to find a second life for several older machines:
Wheel on right side that controls the needle up and down is very tight...
Your machine may be purring again in no time!
FWIW--your machine is popular and well-worth spending a little time and money to make her hum again:
Thread Pfaff 1222 Vs New Machine
Manual:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0ahUKEwiSvKLPwNHTAhWmr1QKHQjLDYQQFgg7MAM&url=http%3A%2F%2Fwww.pfaff.com%2FSiteMedia%2FPFAFF%2FProducts%2FMachines%2FSupport-manuals%2Fpfaff_1221_1222-manual-EN.pdf&usg=AFQjCNEOGguC-PcdLTPymc0oWxgw7Utvkw&cad=rja
May 02, 2017 | PfaFF Sewing Machines
Pfaff 1222 E Makes a whirring noise, wheel won't turn
How long has it been since it's had a thorough cleaning & oiling (including the internal moving parts)? Resist trying to run the machine if the only thing running is the motor. You could burn up the motor or possibly break a gear.
The following method has helped me rescue some frozen older Berninas (which your model seems to resemble). This method worked on all of them except one that also needed a cracked gear replaced.
It was working now it seems to be frozen the needle part wont move
Oct 31, 2016 | PfaFF Sewing Machines
Skipping stitches and sometime the thread breaks.
Sounds like a tension problem maybe. Too tight tension will bend, and break the needle, especially if sewing fast in free machine embroidery, in this mode, the tensions have to be looser anyway. I can't explain why the wheel flagged and stopped, but experiment with tensions first.
Mar 27, 2017 | PfaFF Sewing Machines
When I turn on my PFAFF 1222 it wont sew
It may be in bobbin filling mode. Can you turn the inner circular on the hand crank. If you can click it into position, this should engage the needle mechanism.
Jun 14, 2009 | PfaFF Sewing Machines
Pfaff 1222 and pfaff 1229
Have a certified repairman look at the power board in the machine. The power supply circuits are broken on the board itself. Can be repaired with wire and solder. How do I know? Just fixed my wifes 1229 that had the same problem.
P.S. New boards are NOT available from PFAFF or anyone else
Sep 26, 2008 | PfaFF Tiptronic 2030
Changing Pfaff 1222 sewing machine belt
Have a look at this: remove the top cover and have a look (don't put your fingers in !) at the plastic gear in the middle of the mechanism (left side of he selection keys). It often cracks and then the motor is able to turn the whole mechanism for part of the circumference of this gear and when it passes on the crack, it locks or slows down until the crack is passed. You need to have it changed if this is the case.
Feb 25, 2008 | PfaFF Tiptronic 2030
Sewing Machines Logo
520 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
