Question about Humidifiers
Sunbeam humidifier SWM 2412
Need manual
SOURCE: Sunbeam Ultrasonic Humidifier, model: 697-6
Located My Manual:
Hope this helps!
1. Remove tank from base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled, or tap water. Water temp should NEVER be too hot or too cold. Return tank to base and let sit for a few minutes. Be sure the filling cap of the tank is tightened firmly.
2. Plug power cord into a 110-120V AC wall outlet only. Turn power switch to "on" position. Power light will illuminate. Turn mist nozzle until desired level is being released. Aim nozzle away from furniture and walls.
3. Always turn humidifier off when water runs* out. Unit will continue to operate when tank is empty.
*Humidifier will run up to 12 hrs on low; 6 hrs on high.
DO NOT LET WATER SIT IN TANK FOR LONG. THIS CAN ENCOURAGE BACTERIAL GROWTH.
Place unit on level surface away from direct sunlight.
DO NOT ADD MEDICATION OF ANY TYPE INTO THE NOZZLE, BASE, OR WATER TANK.
ALWAYS LEAVE ROOM DOOR PARTLY OPEN. DO NOT MOVE, TILT, OR EMPTY WHILE OPERATING.
Mild bleach and water solution for cleaning, never detergent.
Clean every 3rd day during use. Clean after long storage
Humidity varies from room to room. Aim for 30 - 50% relative humidity. If windows/ walls fog or frost, reduce mist intensity. If room too humid, ventilate by opening door or window; adjust mist intensity.
Posted on Jan 23, 2009
6ylucy
  • 742 Answers
SOURCE: I need to know how to clean the base of my humidifier.
ask at http://manualfox.com/link/sunbeam.htm
They will find it for you.
Posted on Jan 03, 2010
SOURCE: I have a Sunbeam humidifier
After you lift off the reservoir, there are two grey twist locks (one on the left, one on the right. When you twist these, the bottom can be removed from the unit, which contains the filters.
Posted on Dec 07, 2010
SOURCE: How do I change the
Turn the unit off and disconnect from the electrical
outlet.
2. Remove the tank from the housing.
3. Unlock the housing from the base by turning the lock
knob to the unlocked position.
4. Lift the housing straight up and place to the side.
5. Unlock the wick holder from the base by turning the lock
6. Remove the wicks from the wick holder.
7. Follow the weekly cleaning instructions.
8. Insert new filters into the wick holder and lock the wick
holder back onto the base.
9. Replace the housing onto the base and lock it into place.
10. Fill the tank and place back into housing.
11. Repeat Operating Instructions.
It will take about 30 minutes for the humidifier to reach
Posted on Dec 12, 2010
  • 3 Answers
SOURCE: My sunbeam humidifier doesn't work
Do you mean Dehumidifier? A machine that takes the humidity out of the air. If this is what you mean and you hear the fan motor working with no water dripping then the problem is that the coil which holds freon gas has leaked out the gas and can be recharged again with the leak fixed of course. Depending how old the unit is you may be better off buying a new model. Repairs can be costly. Hope this helps!
Posted on Mar 26, 2012
Need a copy of the users manual
Sunbeam.com provides all their products user/owner manuals.
http://www.sunbeam.com/service-and-support/product-support/instruction-manuals/instruction-manuals.html
Apr 16, 2016 | Sunbeam Humidifier. 3.23-Gallon...
Faulty water level indicator
It is the reed switch inside the post that the float runs on, it gets corroded and needs to be replaced. It is an easy and cheep fix if you can get the reed switch. I would also suggest adding silicone as the factory seal is poor before you put it back together.
Oct 28, 2012 | Sunbeam Humidifiers
Need a manual for Sunbeam humidifier scm 1895
Sunbeam doesn't have it on their site. They sell small low end appliances but have no interest in taking the effort to support them. They'd prefer you buy a new one.
Jun 26, 2011 | Sunbeam Humidifiers
I purchased a used Sunbeam Humidifier SWM5602 and need the manual. I have tried to search it and get a free copy so I know how to operate and clean it. Can you email me a downloadable copy of the manual?...
Lana, apparently that Model Number may have been discontinued. However, your Owners Manual may be available by calling Sunbeam Appliance @ 888 -264-9669.
Hope this helps you get the manual.
Rich
Mar 29, 2011 | Sunbeam 701 Humidifier
I have a Sunbeam humidifier SCM 2412. What is the filter replacement number? How do you get into this thing to replace it?
Nov 19, 2010 | Sunbeam (0013871361) Humidifier
How do I change the filter on Sunbeam Model SCM 2412 humidifier?
outlet.
Nov 03, 2010 | Sunbeam (0013871361) Humidifier
Sunbeam humidifier model 2422 will not reset low tank
I have a similar issue and this is a no filter warm mist humidifier. I just need to know how to reset it, but can't without manual that I don't have!
Mar 06, 2010 | Sunbeam Humidifiers
Just bought a swm 5251 hunidifier with no manual in the box. what are the buttons on the top for? I don't want to run back to walmart at this time of night and want to use the product. How much water does...
  • There is a knob in the centre, which has positions O (Off), 1 (Low), 2 (High). To the left from the knob there is a yellow light, which is a signal to refill the watertank. The red light to the right from the knob is simply POWER On light.
  • The tank holds aprox. 0.9 gallons (3,35 L) of water. This should last about 8 hours.
  • You can find instruction here http://rapidshare.com/files/445360046/SWM5251-CN_owners_manual.pdf
Jan 15, 2010 | Sunbeam Humidifiers
Humidifiers Logo
44 people viewed this question
Top Humidifiers Experts
Mack Baxter
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
