Question about Electrical Supplies
Wiring diagram ambionair generator
I need a diagram to show how to hook this generator to my house panel box.
5 Suggested Answers
  • 153 Answers
SOURCE: electrical wiring for kohler engine
Perhaps you would enjoy the entire service manual. Here it is: http://www.asberry.net/files/TP-2379.pdf
Posted on Apr 29, 2009
protek480
  • 1714 Answers
SOURCE: Installing load panel & inlet box
The bigger lugs will tighten just fine. Go that route and it will be easy to upgrade! If it seems way large when you put the wire in, strip the wire back and double it over. The # 6 may be a bit big for the 30 amp lugs. 30 amp circuit is usually # 10.
Posted on Sep 08, 2009
  • 3 Answers
SOURCE: plug wiring diagram for 240v outlet 7000w blackmax
Probably its similar to the wiring on page 31 of this manual (pdf page 28) of this manual, reference NGK-7000HE: http://www.electricgeneratorsdirect.com/manuals/NGK%20Generator%20Honda%20engine.pdf
Posted on Mar 14, 2010
  • 1383 Answers
SOURCE: Generator is not converting over
You did not mention your model number, however most generators do not have the 12v charging option. Those that do like yours generally use a seperate winding producing about 14volts ac which is passed thru a full wave bridge rectifier. This rectifier us usually mounted inside the panel usually against metal to absorb heat (gets hot while in use). Look for (about one inch square) rectifier and test with meter. Replacement can be of the Radio Shack variety. Good Luck
Posted on Aug 30, 2010
How does the wiring go from the own generator to its battery and then to electric panel
the ONAN generator only charges its own battery that it uses to start the machine,the generator itself is grounded with a 6 ft copper rod that is driven into the ground and secured to the ground strap of the generator,the wiring from the generator goes to a transfer switch that is installed ONLY BY A LICENSED ELECTRICIAN! DO NOT ATTEMPT THIS YOURSELF!,the switch is hooked up to your main electric line at the meter and to the breaker box,when the switch is used,it shuts off the main electricity from the company and opens the circuit to the generator only.here is the transfer switch,it can run everything up too 100 amps in your house or only 1 thing like your heat.
Apr 21, 2015 | Cars & Trucks
I need the capacitor for a Mecc Alte Spa Generator Type T20F-200A 15KW
Take the specs off the capacitor and look it up on-line. Should be able to find one easily. You can also try your local electrical supply house.
Feb 28, 2015 | Electrical Supplies
Sparking in power box when we use the generator and trips the braker
When you say "power box" do you mean the main breaker box in your house? Is the generator hooked up to the breaker that you say trips when the generator is on? There is a short somewhere. First check the generator. Is it running OK. In other words if you plug something into the generator receptacle directly, does it work? If the generator itself works properly, then check the wiring from the generator to the circuit breaker. DO NOT use the generator until the problem solved = safety first.
Jun 12, 2014 | Cars & Trucks
I am installing a 20kw Generac generat or, how does the generator communicate with the transfer switch? there is no wire diagram for this all that is hooked in is the utility, the generator and the...
You need to pull in two yellow wires called N1 N2 for sensing 220v. One red and one white called 23 and 194 those are your 12vdc transfer wires. And then last of all your 12vdc from battery charger. Hope this helps
Feb 16, 2011 | Generac Guardian RTSE200A3 200 Amp...
My newly installed Frigidaire wall oven, model FGEW3065KF fails to heat up except for the convection element. Broiler element makes no heat at all and bake element is uncertain because it is hidden. Before...
I think I can help you but i am a bit confused with the panel box and the junction box. If you want to reply explain the circuit in a bit more detail from the switchboard where the fuse is to the back of the oven. It would also be a good idea to have a voltmeter or test lamps handy. Does the double pole breaker do the Active and Neutral or is it 2 phases going through the breaker. Did the wiring used to be for a full range and now there is only the new oven in its place.
Feb 11, 2011 | Ovens
Where do you remove the Ground Neutral bond on a EU6500is generator? I need to do this to hook it up to a transfer switch as per Service Bulletin #20.
Page 39 of the current owners manual for the both EU6500 and the EM5000 generators indicate that there is not a neutral ground bond on these units.
Per the wiring diagram, the ground pin on the outlets is connected to the frame ground of the generators (on both generators). To have grounded electrical service, a bond wire would connect the generator frame to the ground terminal on the transfer switch. The ground system from the breaker / distribution box (usually to a ground rod) then serves as the electrical ground for the generator, as well as the balance of the rest of the system, satisfying NEC requirements.
See Page 39 in both manuals:
EU6500 EM5000
"The system ground is not connected to the AC neutral
wire. If the generator is tested with a receptacle tester, it will not show the same ground circuit condition as for a home receptacle."
Sep 22, 2010 | Honda Transfer Kit for EM 5000iSAB and EU...
1955 Harley-Davidson generator wiring diagram.
Tyhe F side id the Field coil. Follow whatever directions you have for the control box.
Apr 07, 2009 | 1993 Harley Davidson FLSTF Fat boy
Electrical wiring for kohler engine
Feb 26, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
I can't remember if you plug in the generator to the electric panel first (with power turned to the generator and off of the main line feed) and then start the generator, or start the generator and then...
OK, by talking about a plug, I am assuming you have made a double male plug to hook the generator to the electric panel. This is not really advised, because it is so easy for it to be plugged into an outlet by someone not knowing what it is far, and getting electricuted. Now, away from preaching, and to helping.
It is best to hook it to the generator and then crank it, so you are not dealing with a load when you plug the systems together. When your power is restored, it would be good to install a plug to your electrical box and have it go to a disconnect like is on your outside A/C unit. It moves you away from the hot wires.
Hope your power is on soon!
Dec 21, 2008 | McCulloch 13HP 338 Cc Portable Generator #...
Electrical Supplies Logo
29 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
