Question about Monster Cable MCC AVL300-S Remote Control
How to update settings on website for the MCC AVL 300 remote
Wont let us do anything, just says " go to website to update settings"
3 Suggested Answers
donzaca
  • 273 Answers
SOURCE: the remote wont turn on/off any systems. monster
check whether the shot enta emitting light emitting control if ok then the problem is in the receiver
Posted on Aug 22, 2009
  • 126 Answers
SOURCE: I need a replacement battery
they arent available at stores
Monster USA
Toll Free Number
1 877 800-8989
or http://www.monstercable.com/service/default.asp
Posted on Dec 03, 2010
Message on my harmony 890 is "go to website and update settings my question is How? do I do that? thanks
Greetings - I suspect your setting on the remote are corrupted.
You can go to http://members.harmonyremote.com and create an account and log in. Then you can update (and thereby fix) your settings. The website will prompt you through the necessary steps.
Good Luck and Thanks for using Fix Ya.
Mikeywaf
Apr 10, 2011 | Televison & Video
My garmin Nuvi 250 keeps giving the following messages "Updating GPS Firmware 1%" and then " GPS Firmware Update complete" and wont acquire the satellites and work. It keeps repeating...
There is a reset button on the bottom of the unit. It is actually underneath the label that has your serial number and electrical information on it. If you feel along with your finger you'll be able to feel the indentation. Do not use anything with a sharp point to depress the button as you can damage your unit. Depress the button for about 10 seconds. That should reset your unit back to factory default, or as the unit was when you first took it out of the box.
If this doesn't solve the issue then go to the Garmin website as you did before to download your update. Using the cable that came with your GPS, connect it to your computer. If you have already registered your unit at the website you should be automatically taken to the support website. The system should read your unit and see that it needs an update. It will ask you to download that update. Once that is done, and the file is copied to your computer the program should automatically run itself and do the install to the GPS.
If resetting didn't fix your issue, and you can't get onto the website with the GPS because it keep rebooting you'll have to take the unit into your local Garmin repair center. They may have to open the unit and either replace the operating IC or do a factory hard reset for you.
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
Feb 21, 2011 | Garmin nuvi 250W GPS Receiver
I GET SET 1 EVERYTIME I PRESS BUTTON ON CONTROLLER
Set remote to 1 by pressing 1 holding Ok/Enter for 3-5 seconds.
Jan 30, 2011 | Panasonic DMPBD45 BluRay Player
How do I turn it on? I press the "on" button and
The manual says:
http://www.coinwash.com/temp/rinnai.pdf
"For the name of the Authorized Distributor or Installer nearest you, please contact your local HVAC dealer or gas service technician, visit the Rinnai website (www.rinnai.us), call Rinnai at1-800-621-9419 or write to Rinnai, 103 International Drive, Peachtree City, Georgia 30269"
Manual says that the remote is for setting temperature.
When you turn on hot water spigot, tankless water heater will heat the water to the set point temperature.
If water heater is not set up to use remote, then tankless unit will heat to 140 degrees F.
"With the MCC-45-4US remote control installed the water temperature is adjustable from 96
to 180°F. The water temperature cannot be set to a temperature other than 140°F
without the use of the MCC-45-4US remote control unit. If you require a temperature
other than 140°F you must install the MCC-45-4US remote control unit."
"Error messages are displayed on the remote control units, simplifying service calls."
Page 9 of manual shows hot to set temperature using remote.
Water taps must be shut off to set temperature.
Circulating pump must be turned off.
"Simply press the H or C button until desired temperature is displayed"
"green in-use indicator will display"
If your unit is not working, the manual says to contact local plumber.
Fixya has specialists who will talk to you by phone about your problem for a fee.
Dec 18, 2010 | Rinnai Digital Remote Water Heater Control...
The remote wont turn on/off any systems. monster
Aug 22, 2009 | Monster Cable Monster Central 121161...
Vista Home Premium 64 bit. Iam getting error 80070005 stating it cannot search for windows updates and it encountered an unknown error. I am not a techie, just a grandma who uses the computer alot.
This error can occur for many reasons but generally assocated with IIS connection to a database. Seeing how your are a grandam and more than likely not connecting to anything and that your machine will not connect to windows update. I suspect you have a trogen, rootkit or some other malware. See if you can update your virus software and run a scan it may or may not detect anything. The worst case is that you will need to use your backup disks and re-install windows. You may need to get some onsite help with this. Your machine not being able to connect to either virsus update or windows update is always a dead give away that you have some form of malware infecting your PC.
May 01, 2009 | Gateway LX6200-01 Phenom X4 9500 8GB DDR2...
Samsung BP-1500 problems When I tried to update the F/W to V 2.0 081106_21_XSA.RUF I encountered a problem. I now cannot play any dvd's and my Samsung LCD cannot connect with the player. this is what I...
Just contacted manufacturer with same problem.....your unit needs to be updated....check website...can be done with flash drive or burn a cd
Dec 19, 2008 | Televison & Video
Monster Cable MCC AVL300-S Remote Control Logo
112 people viewed this question
Top Monster Cable Televison & Video Experts
Electro Med Services...
Are you a Monster Cable Televison and Video Expert? Answer questions, earn points and help others
