Question about Kitchen Ranges
Stove top and oven doesn't work.
I have a frigidaire stove that while cooking it had a loud boom noise and it shut down. I found the over lamp recepticle completely burnt out and replaced it. The lamp now works but the stove top and oven doesn't work. Any ideas
    Prodigy:
    An expert who has answered 500 questions.
  • 650 Answers
If it is an electric stove it may have tripped one side of the 230 line. Check the house cuircuit breaker panel and find the stove circuit breaker. It will be tied together by a bar or clip. Shut off both breakers completly and reset them back completely. If it is a power problem this should reset the stove.
Posted on Dec 02, 2012
fridgetech
  • 473 Answers
SOURCE: Frigidaire Stove elements not working
First thing I would check is see if you are getting 220 volts to the stove.  Must be a constant 220.  Let me know what you find.
Posted on Oct 15, 2007
SOURCE: Amana gas range ARGS7650 oven not working, stove top working
check clock has not accidently been switched to Auto this can also happen if someone has interupted the power supply
Posted on Dec 26, 2007
aborcass
  • 2651 Answers
SOURCE: Frigidaire ES340 clicking noise and display blinking when oven door opens
sounds like a bad door/light switch.it cant seem to tell if door is open -closed and clicking really fast betweeen the 2. replace the switch
Posted on Mar 02, 2008
SOURCE: Frigidaire stove
I believe the oven it has a power surge protector within the appliance. Try to unplug it and plug it back in. It should solve the problem.
Posted on Dec 20, 2008
heatman101
  • 43501 Answers
SOURCE: I have a frigidaire GAS stove. Oven doesn't work.
Even though the ignitor glows it does not mean that it is working...sounds crazy but it is true... the ignitor needs to pull a certain amperage to let the gas valve open and as they get older they stop pulling enough current...
Check out this tip I wrote about this problem...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
Posted on Mar 05, 2010
How to remove the stove top on frigidaire stove model FFGS3025PS
IF you open the door to the stove, you will see screws under the lip of the cook top, take those out, check the back of the stove for screws and then lift the cook to. On some models you may have to remove the sides of the stove too.
Mar 13, 2016 | Frigidaire Stove/Oven/Range Cooktop -...
My frigidaire stove made a loud pop while oven was on and then lost power....stove top elements working stove clock not working tested fuse, and changed it still not working
Thank you for your post, friend!
I understand that your Frigidaire range made a loud pop while in operation and lost power. I noticed you stated that the stove top is working and you have changed out the control board but the oven is not working. It could be a possibility that your terminal block or wiring harness has shorted. I would recommend contacting a professional technician to come out and perform a diagnosis and repair on your range. This will help to avoid any unnecessary part purchases. I hope this information is helpful. -Matt
Feb 24, 2015 | Frigidaire Kitchen Ranges
Loud pop and light behind stove. Stove top works, oven does not.
Good Morning Stephanie - Typically you may locate the model and serial number in the storage drawer, on the right side. Based on the symptoms you are describing, you may either have a communication error from the main control board or a faulty bake and/or broiler element. If resetting the unit did not solved the issue, at this point I would personally contact a professional to accurately diagnose the range to determine the root cause to reduce the risk of unnecessary parts.
May 26, 2013 | Frigidaire FEF316 Electric Kitchen Range
Frigidaire electric range model FEF379ACJ Does not work
You will need to replace the main control board/clock, on the unit. It controls everything on the unit. Here is the part to order.
Dec 01, 2012 | Kitchen Ranges
What is the single fuse in top panel of electric oven/range for?
Hello there and welcome to fixya
Normally the single fuse that you have found is for the electronics like the clock and the various other basic funtions o the stove ect ect if this fuse has blown out it will limit the stove or the cook top to be able to do such things like setting the timer or turning on the ovens light and it may also effect the troubleshooting program that is built into the stove ok like error codes and simple things like this
Hope this is very helpful for you '
Best regards Mike
May 16, 2011 | Frigidaire GLEB27S7A Electric Single Oven
I have a 2 yo fridgedare stove that the oven went out..the stove top is working but now oven isn't? The other day while i was cooking a loud noise like a "boom" happened and now oven not working?...
The noise you heard was probably the oven element short circuiting to earth. If the cooktop and grill are working then the fuses, internal/main must not have blown. If this is the case the oven indicator light should come on when you turn the oven on. If it does the oven element is definitely faulty and needs replacing.
Mar 05, 2011 | Frigidaire Ovens
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Frigidaire over the stove microwave that pops/arcs
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Dec 15, 2009 | Frigidaire GLMV169D Microwave Oven
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Oven cuts off
turn off breaker to oven pull stove out and check incoming power supply, possible looseconnection at that point
Feb 17, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Kitchen Ranges Logo
254 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
