Question about Miele WT 2780 Front Load Washer
Washer dryer door malfunction
The door on my brand new Miele WT 2780 washer dryer will not latch. Anyone else had this problem? Its not covered in the manual. Very frustrating since if the door doesn't close then none of the programs will run. Did not expect this from such an expensive machine :-(((
  • 16 Answers
SOURCE: miele washing machine
All Miele washing machines and dishwashers need to fill in a required time. Flashing inlet (Tap icon) indicates that the machine can not fill in time. There are filters in the end of the hoses which connect to your water supply from the machine and filters in the inlet valves which you can get at by removing the hose from where it fixes onto the machine it'self. You will need some long nose pliers to grab the little tab on the small filter to get it out. Clean all filters and hoses. Still same problem then check the pressure of the water coming into the machine. There should be a good pressure coming out of the hose and will be difficult to stop the flow of water with your finger.
Posted on Feb 08, 2008
  • 1294 Answers
SOURCE: Miele WT 945 Washer Dryer - Spin not working + Water Inlet/Drain Light Flashes
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Your filter of the water inlet valve is accessible outside the machine; it is at the water entry point. Close your faucet & check this out; this gets clogged often.
Hope i am helpful...... Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Feb 25, 2008
SOURCE: Miele
Clean the drain by opening the door on the bottum left.
Use the yellow plastic thingy in the front of the soap drawer to do it.
You can open the machine door by pulling the yellow tag in the bottom door.
Drain the water through the filter, clean the filter and close.
Then unplug the machine and tilt it forward by about 1 foot until you see water coming out of the bottom (put towel on floor).
Plug back in and voila!
I do think that this machine is a major pain. No spin cycle and this kind of stuff to go through. Anyone want to buy mine?
Posted on Nov 06, 2008
SOURCE: Miele WT945 Washer/Dryer
You can get fluff out by opening the small lower left front panel with the yellow plastic lever/opening tool (on the left hand side of the washing powder draw). Make sure you place an empty container under the tap on the opening panel door to collect the condenser water. Water will flow as soon as you turn the big plastic dial (which holds the fluff). Once water stops flowing, completely unwind, take out the fluff dial, clean and retighten dial back. Close lid and you are set to go!
Posted on May 21, 2009
  • 132 Answers
SOURCE: can you replace the door seal on the miele w404
YES IT IS EASY TO REPLACE:
YOU HAVE 2 RING OF TIGHT:
1-BETWEEN THE OUTER CASE AND the door seal
2- BETWEEN THE SUD CONTAINER
AND the door seal
USING SMALL PLAYER AND SUITABLE WRENSH ,SCREWDRIVER
THANKS
Posted on Jul 28, 2009
Why is water not heating
Most washers require both hot and cold supply
Jan 06, 2017 | Miele Washing Machines
Miele washer does not power on at all
check the door switch or the mains fuse. they are both on the inside.
Feb 15, 2016 | Miele WT 2780 Front Load Washer
How do I get at the Motor on a WT 2780 Washing machine?
The most important thing you miss, is you should first diagnose what is defect. When 100% certain there is no cause for the defect other and died because of the usage and it is replaceable, you first should buy the spare part and then start the replacement. Without a manual I would not even start opening it. And when the motor costs more then half a new washing machine I would not even order one or replace one.
Please be careful when opening the machine. One mistake can cost your fingers or it even can cost a life.
Feb 09, 2015 | Miele WT 2780 Front Load Washer
Fault 55
I had the same problem twice. I removed the top cover and on the metal part in the middel you see a reset button on the right side with 2 connectors. Push the button in the and it will work again.
Jul 17, 2014 | Miele WT 2780 Front Load Washer
Why is my Miele WT945 front lader washer dryer not taking water in properly or at all?
you may try cleaning the inlet screen by removing the fill hose.then pry the ccreen out with a small screwdriver.
May 05, 2014 | Miele WT945 Front Load Washer / Dryer
No heat when drying
I have a Miele WT2780 where the fan motor stops spinning. This will stop the dryer from working even though the element heats up. The failure of the fan will not blow the air across the heating element and thus into the drum. New motors fitted are around £400 min. I am never going to buy another Miele - mine failed after 6yrs.
Another problem is the thermostat can trip. This is a small button inside the machine (TURN OFF MAINS ELECTRIC AND UNPLUG FROM WALL then remove the lid) on the right hand side of the alloy centre channel at the top. It has two wires connected to the switch and in the centre there is a small black button. Press it firmly and it will heat up again. If this keeps tripping then the air duct could be blocked with fluff. This is my next task as mine now trips more frequently so will post back here with instructions.
Update 12/10/16 - problem returned so dismantled top of air duct having removed the lid - tight torx screws - inside chamber was full of fluff. Removed and cleaned - all good now!.
Jan 04, 2013 | Miele WT 2780 Front Load Washer
Problem
Could you please describe the problem you are having a little better?
Oct 20, 2012 | Miele WT 2780 Front Load Washer
'Close the Door' on Miele WT 2670
Door lock faulty or wires to lock adrift.
Mar 06, 2010 | Miele WT945 Front Load Washer / Dryer
Miele WT 2780 Front Load Washer Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
