Question about TruTech PLV16190 Television
Trutech plv31199s1 using it as a computer monitor
It tell me that it is unsupported mode
  • atmalkovich Apr 13, 2009
    Using PLV3119981 as computer monitor, only 32 colors (no red), windows xp device manager shows no problems (plug and play monitor). Video card and drivers good. Tried several video cards. Works fine as TV or DVD player.
2 Suggested Answers
SOURCE: Need Universal Remote Codes for TruTech
I need a remote for TruTech model DW13TT
Posted on Dec 22, 2009
SOURCE: Lost remote control Trutech® 19" 720p LCD TV/DVD/PC Monitor - PLV31199S1
Wont connect to my cable trutech 19 tv/dvd/pc monitor
Posted on Dec 07, 2010
I need the code for programming a universal remote for TruTech 19" TV/DVD serial nunber PLV31199S1
Use code search to find something that can handle some or all functions of your TruTech TV. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not contain all possible codes.
Dec 29, 2016 | TruTech Televison & Video
I have a Jensen (JE1909ACB) 19 LCD TV Can't get it to hook up as a monitor on my desktop. It reply's unsupported mode.
Are you using the VGA port on the Jensen TV? What is your computer's OS?
The usual reason for the unsupported mode message is that the the computer did not recognize the TV as a monitor on boot up or that the previous settings were incompatible with the TV. (For example, if you previously had a CRT connected to the computer and used a refresh rate of 75 Hz, the TV can't handle the refresh rate. It needs to be set at 60 Hz.)
First turn off both the TV and the computer. Then turn on the TV and set it for the PC input (assuming you are using the VGA port). Next turn on the computer. If you have Windows XP or later, it should find the TV and set the resolution without any input. (If it doesn't, use a different monitor and set the resolution to 1366 x 768 and 60 Hz. Then try again.) If you used the HDMI port, try the VGA port. This TV doesn't understand a computer signal over the HDMI port (only set top boxes).
I hope this helps.
Dec 08, 2011 | Car Audio & Video
Is trutech plv31199s1 tv an HDTV?
Yes, it is. It displays up to 720p which is perfect for a 19" display.
May 02, 2011 | TruTech Televison & Video
I want to use Trutech 19" tv as computer monitor. Scrreen starts to set up and then get error message "Unsupported Mode." Is their a simple fix for this?
Hello Fayeburns,
Yes, there is a simple fix for it.
The reason why your TV is showing Unsupported Mode is because of the display resolution of your
graphics card, which is higher than what the TV can handle.
What you can try is, when your system is powered up, just go to your display settings, then
reduce the systems display resolution to--preferably 800x600 or 1024x768, then go to where you
normally select the output, and select 'Output to external monitor"...this should send the signal
input to the monitor.
In case it still doesn't work, just try and update your graphics card driver to the latest one and try
the same process again.
Most Laptop graphics display resolution are generally very powerful as compared to what the TVs
can handle.
Try this out and let me know how it goes.
Hope this helps.
Goodluck and thank you for using Fixya!
Dec 26, 2010 | Computers & Internet
Needs remote which remote is best for this unit
Any of the universal remotes should work.  Check their sites on line first to see if they have codes for your TV.  I recommend a Logitech Harmony remote that is "activity based" and can control all your electronics with a single remote.
Jun 02, 2009 | Audiovox PLV31199S1 19 in. LCD TV
Remote control switch destroyed
If you get an universal remote, you won't have all functions to control the TV. Moreover, the codes for many audiovox model are often not reported on universal remote manuals , therefore you may need to use autodetect feature on universal remote.
The best choice is buying a replacement original remote like the ones below:
New Original TruTech PLV31199S1 Remote Control
$39.95 -
New Original Trutech PLV31199S1 Remote Control $39.95
Apr 18, 2009 | Audiovox PLV31199S1 19 in. LCD TV
TruTech PLV16190 Television Logo
484 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
