Question about Kenwood Dishwashers
Kenwood dishwasher model no;kid60s10 not heating water
Is it the element or heater element
SOURCE: Dishwasher Dishlex DX302WB No Hot Water
Thank you This worked for me!
The heater was ok found dry joint on pc board
see attatched photo
Took top 6 screws out of door holding front panel in place
Removed front switch panel
I then labeled the 6 cables with 6 being for the heater
Removed pc board from housing to find dry joint
using small piece of wire and solder repaired board
re assembled
now as good as new
Posted on Jun 14, 2008
  • 1462 Answers
SOURCE: Whirlpool Dishwasher ADG7540/1
an ntc is very reliable. have you checked continuity thro the heater? other common fault is a dry joint devoloped on the control card - take it out and check for dry joints
Posted on Oct 03, 2008
SOURCE: AEG DISHWASHER, DOES NOT HEAT WATER.
I had this same problem on our AEG dishwasher. The reason was on the controller board. There is one relay switch which drives the heater element.One of the legs of that relay box was disconnecteds from the circuitboard. Check this out.
Posted on Dec 09, 2008
  • 177 Answers
SOURCE: Miele dishwasher not heating
hi,
you would have to turn the unit on it's side and remove the bottom plate and check with a multi meter the resistance of the heating element to see if the heating element is defective. i doubt the dishwashing liquid caused a fault other than causing the unit to over sud and spill water into the base. You could remove the panel under the door and have a look and see if you have flooded the base. if you have a float switch in the base (white polystyrene disc and switch) this will stop the unit from working as well. dry up any water and try it again. hope this helps and don't use the dishwashing liquid in the unit.
Posted on Jan 22, 2010
torres No9
  • 27 Answers
SOURCE: hi i have electolux model DX403 dishwasher .the
it,ll be the circuit board definately come across this problem alot.
Posted on Jun 27, 2010
What does e3 mean on kenwood dishwasher
It means it is not heating the water enough. The manual says.. Longer heating time but not reaching required temperature. The possible causes: malfunction of temperature sensor or of heating element
Apr 30, 2012 | Kenwood KDW243A Builtin Dishwasher
Kenwood KDW 243A Dishwasher has an E3 fault and will not wash the dishes, can you tell me what is causing this please? Thank you
The error (E3) relates to the water heating but not reaching the required temperature. This can be due to a couple of things generally. The sensor which detects the water temperature can be faulty or the heater element itself is faulty and not heating the water to a high enough temperature. I think it's needing to be replaced.
Check to see if there is a thermostat screwed up into the underside of the tub on the rear right side. If there is, test the thermostat to see if it's open circuit, if it is you'll need to change it.
Jun 12, 2011 | Kenwood KDW243A Builtin Dishwasher
Do all dishwashers use heat element or do any
all dishwashers use heaters and all should be connected to hot water the heater is only to keep the water hot not to heat it
Jun 05, 2010 | Dishwashers
Fitting a heating element to a Kenwood dishwasher
E3 usually means the heater element has failed. From the title of tyhe post it seems you know that already.
Jun 27, 2009 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Water heater no go.
The heating element is turned on first during the main wash cycle, which could be approximately 10 minutes in. Since this error is coming up, the first thing to check/replace is the heating element.
I am only familiar with the LDF family of LG dishwashers and on them, to get to the heating element, you pull the dishwasher, invert the entire DW and remove the access panel.
Good Luck, please post back here what you find, OK?
May 07, 2009 | Dishwashers
Does a LG model LDF 6920st have anything way to heat to hot water
Dishwashers do have a water heater element. In fact, it's the same heater that is used for hot dry, but you can switch it off for the drying cycle if you want. Dishwashers heat the water so it will be hot enough to properly clean the dishes. Sorry, you lose the bet.
Nov 26, 2008 | LG Dishwashers
Dishwashers Logo
1,072 people viewed this question
Top Kenwood Dishwashers Experts
Oloyede Monsuru
Owen Barnes
Are you a Kenwood Dishwasher Expert? Answer questions, earn points and help others
