Question about Cooktops
Electra elechebi error e6 on two rings
Tried powering off same error only a week old
  • Anthony Jan 21, 2013
    Same thing for me 2 weeks old on a Electra elechebi, I get error e8 on two left rings. Any ideas how to fix this ?
    Exactly the same problem, 2 weeks old and on the Electra elechebi I get an error e8 on the two left rings. How do I fix this or who supports the product ?
Induction cooker are display E6 error
I did exactly the same thing as "Carol Johansson" did to fix her "Electrolux" induction cooktop.
My "Omega" induction cooktop was intermittently (more often than not) coming up with error E6 problems on two of the four elements, after a power reset it started to do it on all 4 elements.(Now the Boss was not happy)
I pulled it all apart taking photos of every stage of dismantling, makes it a lot easier to put it all back together.
The main power supply board which supplies the other two boards has about six electrolytic capacitors, two of them where bulging, (curved on the top instead of being flat). They where the 470uF 25V ones, I replaced them with 470uF 35V ones from Jaycar for $2.80.
Put it all back together and we can eat tonight, Boss is happy!!
Hope this helps and thanks to Carol for pointing me in the right direction.
May 11, 2016 | Cooktops
I have an EKI 807.2 Glass hob. I can't turn the heat up on more than one ring without E flashing on all the Rings followed by 6
Are you sure it is properly wired? For 1 phase 230v:
1= power earth
2-3 intersected = N
4-5-6 are L1-L2-L3 that should be conected together to L
Kuppersbusch is not very cooperative about what their error codes indicate, but E6 seems to be a (low) voltage issue, so you might too check the cabling to the outlet, measure the voltage with a multimeter when you successively switch on elements
Dec 22, 2015 | Kuppersbusch Glass ceramic induction hob...
Induction error e6
check your earth connection
Jul 18, 2013 | Cooktops
Induction error e6
Hello it07002 - You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, then the unit more than likely may be experiencing an issue with the EOC (Electronic Oven Control) and/or user interface board. This is not a typical do it yourself job; please consult a professional or your manufacturer.
May 07, 2013 | Electrolux 36" Electric Hybrid Induction...
Recently i have purchased Prestige induction stove, can you describe what does E3 mean?
e 3 is error because of high voltage may be more than 30 kW at your house......it will not work with it u have to buy a voltage regulator for it........
Jul 16, 2011 | AEG 23 in. 6410KF-N Electric Cooktop
When turning on my 2 year old Neff induction Hob T4543N1 it displays a full set of E errors and cuts out it does after two attempts corect itself and function perfectly
I had flashing Es every time I turned the hob on - got worse and worse until unusable. Neff help line useless - service call cost ridiculous. My problem was the capacitor on the 5 volt power supply had failed. 5 volt supply was at 3.8 volts. Replaced the capacitor and the hob's now perfect - a joy to use. Only helps if you are tech savvy and willing to open the unit, but may give you some hope or point you in the right direction.t
Jul 28, 2010 | Neff Cooktops
Whirlpool induction ceramic cooktop error E6
my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
Dec 15, 2009 | Cooktops
Replacement of control board for Electrolux Icon 30''
Hello, I am going to go out on a limb here and risk a bad feedback score but I have seen this many times in the past few years and have even made the mistake of replacing the EOC (Electronic oven control) when the EOC was not the problem, Reading between the lines with no model number I'm going to assume you got the error code for a bad EOC which is why the repair guy changed it. Well the second one could be bad too but I seriously doubt it. To me after changing the EOC and it still don't work the problem is going to be with the touch pad if it has one (be mindfull I dont have model number so I don't know other then electrolux which oven this is). The way to test this diagnosis is to turn the power off...Remove the ribbon/cable harness from the touchpad to the EOC. Switch power back on and wait 24 hours. If Error code does not return it's the touch pad, if within the 24 hour period the error comes back it's the EOC. Can't be any easyier then that to figure which it is and any tech worth his salt would know that. Hope this helps some, Maybe you can try it while you are waiting for the new part. Good Luck!! if you have any further questions or concerns please feel free to comment again. Mike
Jul 20, 2009 | Cooktops
Cooktops Logo
66 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
