Question about John Deere JA65 Self Propelled Mower
Safety switch adjustment on John Deere self propelled lawn mower
5 Suggested Answers
  • 252 Answers
SOURCE: lawn mower belt diagram
try www.johndeere.com apply for user id and password
will need to wait for these to be issued to you via e-mail
then go to www.jdparts.com and enter your user id and pw and enter the correct site for your country and then enter model stx38
scroll through list to find deck or attachments and double click it
your deck could be a yellow or black deck
cheers
Posted on Jul 21, 2010
  • 603 Answers
SOURCE: john deere stx 38 with black deck, will not do
I see this problem not as an electrical but a seize problem. Since I can't be there to inspect I am relying on your discription of the problem. I would go first to the place of the problem. If this solenoid goes up to disengage and down to engage ,or the opposite, this is most likely your problem area. It may be seized in the disengaged position therefore not allowing the blades to get spinning. Disconnect the belt and try to turn unit by hand, if tight or completely stuck use penetrating oil on pulley shaft.If shaft loosens up and blades engage this was the problem. Is there a grease fitting anywhere in the area?I hope this at least gets you started in the right direction. GOOD LUCK.
Posted on Jun 17, 2011
  • 640 Answers
SOURCE: I have a John Deere riding lawn mower model #
DO NOT RUN THE ENGINE IN THIS CONDITION
The solution is not too difficult here, but may be a little messy if you are not careful. You need to drain the oil/gas mixture into a container. CAUTION- the gas in the oil acts as a thinner and the mix will flow out very quickly so be ready to catch it in a container. Change the oil filter and refill with oil like normal oil change. Remove spark plug and rotate engine several times, this is done because the fuel in the oil washes the oil out of critical locations within the engine and rotating several times to put oil back on those critical surfaces. Reinsert plug and you are ready to start it up.
I hope this help you, if it really does please rate four thumbs up.
Posted on Jul 22, 2011
SOURCE: I replaced the belt on the lawn mower the idler
look up john deere web site for spare parts
print out parts cataloge for parts , it gives you the basic outline and shape of belt configeration
Posted on Mar 04, 2012
My john Deere 110- 42" cut lawn mower ran out of gas and won't crank back. Noticed the parking brake is engaged but will still roll. What is my problem?
Hi Shannon, It's either fuel OR electrical, First check electrics, If it cranks but not starting......
How to test a solenoid....
How to test lawn mower solenoid
How small engine governors work....
How Small Engine Governors Work any governor setup
How to test lawn mower electrical safety switches....
Shows all safety switches disabled....
Disable all lawnmower safety switches
Apr 29, 2016 | John Deere Garden
I have a John Deere JS30 self propelled lawn mower I had issues with it running for 15 minutes and then it stops running. Was low on oil. Added oil over the full line now it runs for 3 min and dies
Wayne, correct your oil level to full line, change your spark plug and try mower. If still acting up after a couple minutes, the Gas cap vent may be plugged, remove or loosen cap to see if mower will run longer and better. If no improvement, the carburetor is dirty and needs cleaned or rebuilt.
Lawn Mower Starts Then Stalls
How TECUMSEH FUEL CAP can Give You Problems
lawn mower troubleshooting
HOW TO CLEAN The Carburetor on BRIGGS Stratton Quantum Lawnmower Engines
Apr 03, 2016 | John Deere Garden
Why wont john deere stx 30 pto wont engage
Most of these mowers have a safety switch between the PTO switch and clutch. A safety switch or relay is most likely the problem. Hope this will help ya.
Jul 19, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
John deere gcv160 self propelled wheels not working
The cogs behind the wheels may be blocked with grass. It may also be on the self propelled belt above the blade.
Jun 21, 2013 | Husqvarna Garden
I have John Deere JS63 self propelled lawn mover. It runs rough and loses power. I cannot mow a ful strip of the lawn as it stall. It is extremely nderpowered. It also runs a little rough when idling...
Have the valves adjusted for they are required to be adjusted every year refering by the owners manual. If the lash or gap is too big this will cause the symptoms your having. Also replacing the spark splug and changing the oil is recomended every year too
Jan 16, 2011 | John Deere Garden
John Deere JA65 Self Propelled Mower Logo
24 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
