Question about Insignia Televison & Video
Just bought a 19" Insignia LED TV. Specs of the TV keeps appearing on and off at the bottom of the tv. Don't want to keep seeing it. How can I make it stop?
19" LEd TV 60 HZ 720p
  • 736 Answers
If the actual specs of the television keep appearing, the television could be in demo mode. Demo mode is turned on when the television is being displayed in the store. Is this a display open box model? There is an option in the display or set up menus to activate or deactivate demo or store mode.
If it is not the specs of the television but rather the channel and program information you are seeing, you may be having a different problem. In this case it is a signal issue you are having, and the only way to remedy that is to connect the television to a cable/set top box with RCA or component cables or to install a signal booster. http://www.amazon.com/Motorola-Booster-484095-001-00-Bi-Directional-Amplifier/dp/B000066E6Y
Posted on Dec 01, 2012
tthekraut
  • 374 Answers
SOURCE: 19" LED TV INSIGNIA HD
I have one of the same tvs. Start by going under menu,setup,tuning band and set it up for antenna. When you get that far put in auto channel search. To see how to get best reception where you live go to http://www.antennaweb.org
Comment if you need any further help
Posted on Mar 17, 2010
SOURCE: Insignia LCD TV 32 inch will not come on
I received no replies to my request. I guest I stumped 2 million techs. I'll just buy a new TV with a 5 yr warranty. No thanks to joining your service, I can do bad all by myself.
Posted on Feb 09, 2010
  • 8909 Answers
SOURCE: How can i change my
It will do it itself. If you were to play a PAL video through it at 50Hz, it will be fine and if you play an NTSC in simple PAL it will be at 60Hz and display a reasonable picture.
Hope that helps.
Posted on Nov 16, 2010
  • 403 Answers
SOURCE: I bought the westighouse 42"
you have to check the output of the blu ray, your only gonna get what thats putting out. electronics have to match to work properly.
Posted on Mar 19, 2011
  • 7 Answers
SOURCE: I just brought my tv in 3 days ago 55 inch led 240
THE VIZIO XVT553SV has a know problem of random power cycles and random shut offs. It is recommended you call Vizio Technical Support for a proper and permanent solution.
Toll-Free: 877.698.4946 (877 MY VIZIO) Technical Support if you don't get proper assistance at that number call the Executive Office at Phone: 949.428.2525
Posted on Jul 18, 2011
Screen size and resolution keeps changing while I work.
some tv devices are set by default to auto adjusting, look in tv's setup and adjust the resolution manually.
Feb 23, 2013 | Toshiba Computers & Internet
What are RMT-B118A Insignia codes
Unfortunately, Sony did not elect to include Insignia codes in their remote control, so it is incompatible with Insignia TVs.
Sep 06, 2012 | Sony RMTD187A Remote Control
My Insignia TV has a blue screen with parental cotrol the problem is I don't have a Control to pres display how can I unlock it???? HELP:(
Hello
When an Insignia TV is locked, it keeps you from watching all of your channels by only displaying a black screen. Insignia TVs are locked from a single button command on the remote control, so it is easy for you to lock the TV by accident. Since Insignia TVs can be locked so easily, it's important to know how to undo this command and unlock the TV yourself. So, unlock your Insignia TV with the push of a button and once again enjoy watching your favorite programs.
· Find the lock button on the Insignia remote control. The lock button is located on the third column from the left on the second row from the top of the remote.
·Stand within operating range of the Insignia TV, then aim the remote at the TV's receiver and press the "Lock" button on the remote control.
· Aim the remote at the TV and press the channel buttons to make sure the TV is unlocked. When the TV is locked, it shows a black screen and does not allow you to view anything else. If the screen remains black, press the "Lock" button again. If this doesn't work, change the batteries in the remote and start over at step
OK
Sep 17, 2011 | Insignia NS- 27" TV27 TV
Insignia 27" tv, unit takes a long time to come
Unfortunately this is probably a hardware problem, hopefully you got it form Best Buy and it is under the 2 year warranty. The sad fact is Insignia TVs just don't last, however it might be something minor that a repair shop can fix. So I would take it into a repair shop and after they say it will take $400 dollars to fix it, chuck it and get a new TV.
May 19, 2011 | Insignia NS-27 TV TV
Mar 17, 2010 | Insignia NS-LCD19 19 in. LCD TV
Insignia NS-LCD19 is not producing a picture
You might need to change the input on the TV. I'm almost certain that it will have a DVI and Coaxial input among others.
Check the monitor for an input button or pull up the menu and see if there is different input selector.
Oct 13, 2009 | Insignia NS-LCD19 19 in. LCD TV
VCR picture with INSIGNIA 26'' lcd tv
I would check if you have selected the correct tv input on you remote. the shadow movement you see may be bleeding over from another input. on your TV remote you will see "input", keep clicking it, delaying a little each time, until you get to the correct input you are connected to.
Apr 07, 2009 | Insignia LCDTV26 26 in. Television
Televison & Video Logo
166 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
