Question about Kicker KX650.4 Car Audio Amplifier
What are the resistors on a kicker kx650.4 R60, R50, R59, R58,, all are blown
Trying to replace them can anyone help???
Need Help with burned resistors value. Please.
have you repaired the component that burned these resistors out? if not then you cannot replace them as they will just cook again.
Nov 06, 2015 | Cobra CPI 1575 1500 Watt 12 Volt DC to 120...
Cobra 39LX blows TR15 and R58
When you replace only burned or damage parts, you should use a good meter an check all parts around them. Many times the part destroyed is just part of problem. Its going to take a service tech to really go over it now. Caps an resistors go bad when you have parts burned. Not much one can tell you without seeing it
Jan 16, 2014 | Cobra 29 WX NW ST 40-Channels Base CB...
Cold start difficulty
Hi, Mark probably all it needs is a proper tune up otherwise the usual suspects are:
1. Enrichner system plugged, not properly functioning or improperly operated.
2. Fuel overflow.
3. Restricted fuel supply.
4. Gas cap and or fuel tank not venting properly.
5. Plugged slow jet or passages.
6. Inlet system air leak.
For more information about your issue please visit the websites below. Good luck and have nice day.
Just purchased 1970 BMW R50 5 Owned many motorcycles but this is my first...
http://forums.bmwmoa.org/showthread.php?58825-R50-2-starting-problems
BMW Repair Manual R50 5 R60 5 R75 5 Repro
BMW Motorcycle Parts Fiche OEM BMW Motorcycle Parts online 1970 present BMW
http://www.bmw-motorrad.com/us/en/index.html?content=http://www.bmw-motorrad.com/us/en/services/manuals/manuals_main.html¬rack=1
Aug 20, 2013 | BMW Motorcycles
My KICKER amp KX200.2 has a resistor blown out it is R17 i will like to know the specific resistance so i can replace it
If you look closely at the color bands on the resistor. That will tell you what resistor you need to replace. All resistors are standardized color coded. You can find out the resistance online. Hope this helps.
Aug 14, 2011 | Car Audio & Video
HOW TO USE PRESTIGE INDUCTION COOK-TOP MODEL :pic 1.0
Dear Sir,
i have Prestige PIC 1.0 induction stove.The issue with the stove is whenever i switch ON the stove the 2 Watt Resistor in the PCB(R50 After Diode IN 4007) getting blown off.Even after replacing the resistor also I have the same issue.Can anyone help me on this that where i have to check, whats wrong in the stove.? thank you
regards,
Prakash
Bangalore
Feb 17, 2011 | Microwave Ovens
Hitachi 53UDX10B Red Silhouette
Replace Both of your STK convergence ICs STK392-110 use 150s also ck these ResistorsRK42,46,50,54,58,62
R42 2.2ohms
R46 1.5ohms
R50 2.2ohms
R54 1.5ohms
R58 3.3ohms
R62 1.8ohms Replace all of them Call Mats for Parts 1-800-628-1118
Sep 29, 2009 | Hitachi Televison & Video
Gear box washers
Hi, Dogan_cakir sorry you can't find the first and best tool you ever bought for your BMW but despair not for a mere $10 you can download another one. For more information about your issue and free downloads that you need please visit the websites below. Good luck and have a nice day.
1970 1993 Bmw 2 valve Twins R45 R50 R60 R65 R75 R80 R90 R100 Motorcycle...
http://www.k100.biz/pdf/FAQ/FAQ_K100_tips.pdf
http://www.ibmwr.org/r-tech/airheads
Sep 23, 2009 | 1976 BMW R 60-7
Hitachi 50FX20B convergence problem
RK42 is 2.7 ohm 1watt
RK46 &RK54 are both 2.2 ohm 1watt
RK50 & RK62 are both 3.3 ohm 1watt
RK58 is 3.9 ohm 1watt
They are all metal film (flameproof) 5% resistors
Jul 20, 2009 | Hitachi 50DX01B 50" Rear Projection...
Peavey 400BH
Thanks for the update. I'll need to look through my records for similar problems. Stay tuned...
Dan
Jun 13, 2008 | Audio Players & Recorders
The picture is green and purple images
This is an issue that is currently the reason for a number of Class action Law suits against Sony for both the KDS-R50 and R60 models. The suit has provided an extended warranty for in-house repairs through June 2009. Call a number and they will schedula a replacement free of charge. I just had mine replaced for the same reason (Grren tent, yellow or orange stains.) Here is the link for information regardignthe suit:
http://esupport.sony.com/US/perl/news-item.pl?mdl=KDSR50XBR1&news_id=219
Apr 21, 2008 | Televison & Video
Kicker KX650.4 Car Audio Amplifier Logo
24 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
