Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
My dream maker big eze hot tub the jet light on the upper control panel just keeps blinking what does that mean
    Scholar:
  • 111 Answers
Are the jets coming on when you press the button?
Try unplug the control from the board and plug it back in.
Posted on Dec 02, 2012
3 Suggested Answers
  • 12744 Answers
SOURCE: my dream maker spa does not work. there is
open control panel will see a small glass fuse replace if blown if 220 volt check that getting power on both lines
Posted on Nov 04, 2009
Ian  Hot Tub
  • 77 Answers
SOURCE: Dream Maker spa - does my dream maker spa 4 person
Depending upon the age, the Dream Maker has a digital thermostat which is easy to change but to be honest I don't think that is the cause of your problem.
Check the keypad connection on the PCB (circuit board).
t could be either the keypad or PCB at fault and withou trying one or the other you'll not be able to determine the problem. My advise would be for you to contact your local parts supplier and ask them whether or not they can supply you a keypad to try with the option to send it back for a refund if it doesn't cure the problem.
A keypad can be trial fitted to the PCB, just unplug the old one, plug the new one in and turn on the power. There's no need to install the keypad to the spa, therefore you wont damage it in anyway.
If the keypad doesn't cure the problem, change the PCB.
Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 01, 2010
6 month old jacuzzi hot tub has started leaking intermittently , any help here to solve this problem
remove front panel visually inspect pumps to see if leaking if ok check by control box remove cover inspect where plumbing runs through keep eliminating thing until you find it
Sep 02, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
Sparform hot tub blower won't turn off
When an appliance will not turn off, no matter what you press on the control panel, you have either a non responding (dead button) topside control panel, or your topside panel did receive the message to turn it off and the circuit board is not responding.
  • If you have some kind of indicator light when you press your Jet/pump button, if the topside panel is operational and does actually receive your request to either turn on or off an appliance, an indicator will appear - either a light or icon.
    • If one does appear when button pressed, then dis-appears when pressed, that means your panel is good - as it is responding to the pressing of the associated button.
      • Bad circuit board
    • If nothing appears when you press the button, no lights or icons - indication of topside receiving your request, then you you have a dead button.
      • Bad Topside Control Panel
May 18, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream Maker Spas leak
This means one of your top jets is leaking. Firstly try Fix A Leak this will stop any leak up to an 1/8". If this does not help there will be more difficult work in store.
Each jet sits in a jet body, these jet bodies are behind the tubs shell, you'll need to get in behind them to see which one is leaking. This can be difficult as they are often covered in insulation foam.
Sep 05, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
Hot tub has power but nothing else works
MY control panel was replaced ,it cycles but, no lights ,no jets,no heat works..What's the problem .
Oct 01, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
436 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
