Will internet box mat960a103 work with wireless internet can it receive the signal??
Hi there, I was going to buy the mat 960A103 unit to work with my samsung smart tv bluray player but will it receive the signal from my clear wireless internet receiver box , it's a great product sends internet out to 8 other items no problem. I have a samsung internet receiver adapter but does the box have a usb port to accomodate or some way of connecting with the signal? The tv is a samsung but not a smart tv but receives a fantastic signal through the samsung smart tv bluray player both a great buy! Please help! Hey I should make a commission ha ha!
Beni S-P
  • 1006 Answers
SOURCE: microsoft wireless notebook mouse model 1024 will not function.
Possibilities:
1) One of your USB devices have faulted, or is causing a resource conflict (or similar)
-- Remove all USB devices, and reboot.
2) Your USB chip/ports have been damaged.
-- Find a spare HardDisk or bacjup your data and re-install Windows and see how that goes.
3) Your Power Supply Unit (PSU) isnt supplying enough power to your PC (usually caused by a Video card upgrade). Try a more powerful PSU ... 400watts should do the trick
4) Bad memory (RAM) can cause wierd problems. run memtest for an hour to make sure your memory is ok
It seems that many people are still getting the 'USB Device not Recognized' problem from time to time. Unfortunately there is no easy fix.
Firstly, it's recommended that you make sure every one of your motherboard drivers are completely up-to-date, but you probably already knew that.
In XP, after a USB port isn't used for a long while the USB driver built into the OS sets the OHCI controller to suspend. When you plug a device back in, it can sometimes fail to 'wake up' properly. This problem was supposedly fixed in SP1 but there is a related registry hack that may still be able to help.
Run regedt32.exe and navigate to;
HKEY_LOCAL_Machine\SYSTEM\CurrentControlSet\Services\Usb
Create the Usb key if it doesn't already exist. Under this key, create a new DWORD value called DisableSelectiveSuspend and give it a value of 1. Then restart the PC.
A long shot perhaps, but I recall having similar problems with a USB hub built into my Microsoft keyboard and adding this key seemed to solve it. It wouldn't hurt in trying .
Alternatively, removing all entries relating to USB in Device Manager and all associated USB drivers will force XP into refreshing the USB driver stack.
Begin by unplugging all USB devices, then use Add/Remove Programs in Control Panel to uninstall any USB driver software. Next, boot up into safe mode and go to Device Manager. Once in device manager make sure 'Show hidden devices' is checked under the View menu. Uninstall all device entries in this order;
1. USB peripheral devices (printers etc.)
2. HID and/or Composite USB (Human Interface Devices) You're using PS/2 input devices so you may not have this entry.
3. USB Root Hub(s)
4. USB Host Controller(s) (Universal or Enhanced Host Controllers)
Then boot back into Windows (not safe mode) and it should populate the Root Hubs & Host controllers again. Proceed to plug your USB devices back in, starting with your powered hub. Be aware that most USB printers and scanners need to have their drivers installed first before you plug them in.
Hopefully some of this may be of help, let us know how you get on.
Posted on Dec 07, 2007
SOURCE: no HDMI video output from AVR-588 receiver to plasma TV ???
You can also use a digital coax cable (color orange) to go into coax 1 for DVD coax 2 for cable box. Just make sure to set the coax in input settings. The coax cables are a little cheaper than the optical cables and work just as well.
Posted on May 10, 2008
Agent Aaron
  • 265 Answers
SOURCE: Samsung lcd hdtv won't receive signal from fios hd receiver
Hey nothingsfree,
You may not necessarily have anything incorrectly set up, but there are a couple of things that I would suggest trying.
First, you'll want to make sure that your TV is set to the correct input source. Some TV's will require that the input source be changed in order to display any signals from an external device, like your HD-DVR. This can typically be done by accessing the main video menu using your remote control.
According to information provided by the manufacturer, you should be able to change the input source for this model TV (Samsung LN46A750) by doing the following:
* Press the "Menu" button on your remote control
* Press the "Up" or "Down" arrow button to select "Input," then press "Enter"
* Press "Enter" to edit the "Source List"
* Highlight the signal source for the HD-DVR, and press "Enter"
Next, you may want to try updating the TV's firmware. In some instances, simply updating a TV's programming can eliminate any potential hardware or software conflicts between two devices. To update the TV's firmware you will need access to a computer and a USB flash drive. Step-by-step instructions and the firmware update itself are available through the following website:
http://www.samsung.com/us/support/download/supportDown.do?group=televisions&type=televisions&subtype=lcdtv&model_nm=LN46A750R1F&language=&cate_type=all&dType=D&mType=FM&vType=L&prd_ia_cd=02010100&disp_nm=LN46A750
Make sure to read all the warnings and disclaimers available though, as your TV may already have a more up-to-date firmware version than the one that can be obtained through Samsung's support page.
Should neither of these address the issue, you may wish to see if connecting your HD-DVR to a different HDMI input solves the problem. Much like computers, TV's have been occasionally known to have faulty inputs or loose internal connections.
If all else fails, I’d suggest contacting the manufacturer for further assistance. In many cases manufacturers are able to provide over-the-phone troubleshooting support, in addition to having access to a wider variety of possible remedies for hardware problems.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 23, 2008
  • 34 Answers
SOURCE: NetGear Wireless Router not working
No need to worry about this issue,,,,
turn off ur router for 2 minutes..wait for 1 minute..turn on the router and wait for other 2 minutes..now it should work..
If still its not working means..there will be a reset button in the router..press the reset button and hold it for 60 secs..turn off ur router and turn it on..wait for 1 minute..
try to connect thru wireless..it will work
Posted on Jul 03, 2008
SOURCE: microsoft wireless notebook optical mouse 3000 Doesnt seem to work?
Okay, a coworker had this problem and it was a fairly easy fix, first, plug the USB reciever into a direct USB port, then pess the connect button on the underside of the mouse, when the red light starts blinking let go and then press it and hold, and at the SAME TIME press and hold the connect button on the receiver until both the receiver light and the mouse light turn on steadily, and voila!
Posted on Nov 24, 2008
How to turn on bluetooth radio
Which operating system ???...
There are a variety of ways to connect to the Internet or a home/business network using your Hewlett-Packard (HP) desktop computer---via a modem, Ethernet cable and even wirelessly.
A wireless connection works by sending a signal from your modem or router to your HP desktop's built-in wireless radio.
The radio receives and processes the signal so you can access the Internet or a home or business network.
In order for the signal to be received by your HP desktop, you must enable the wireless radio within the computer's configuration.
Click "Start," "Control Panel."
Double-click on the "HP Wireless Assistant" icon.
The HP Wireless Assistant dialog box will open.
Click the "Turn On" button next to the words "Wireless LAN."
Click "Close" to activate the wireless radio.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00045315&product=12455 - DeviceEnabled
Using Bluetooth Devices (Windows XP)
http://h20239.www2.hp.com/techcenter/wireless/wireless_TS.htm
Wireless networking center
Aug 30, 2013 | Packard Bell Computers & Internet
Wireless speakers not linked
Have you attempted to push the search button on the back of the receiving unit? Power down the transmitting unit and the receiver and reset the signal button on the rear unit after re-powering both units. Power surges seem to fry components on the rear unit. surge protection is a must on these things.
Oct 20, 2012 | Samsung Receiver Ah63-02058u For Ht-c650w...
What is the difference between an adapter and router?
Hi
A router is a device that normally will be connected to the modem which gets the internet connection from the modem & gives out a wireless signal.
An adapter is a device that will be connected to the computer. This is a wireless receiver which receives the wireless signal from the wireless router & connectes to internet.
Dec 27, 2010 | NetGear Computers & Internet
How to go wireless on laptop
You need three things
1) An Internet service provider. Once you sign up and agree to pay the fee they will provide the internet service.
2) A wireless router. This is a unit that receives your internet service by through a connection to your telephone line. Then it transmits a radio signal (wireless signal) that your laptop can receive.
3) A Wifi card in your laptop or an external USB Wifi Dongle. This is a radio or wireless receiver that picks up the signal from your router.
The router is usually security protected with a keycode. All you need to do is set up your Wifi card or dongle with the same keycode and you will be able to receive the internet wirelessly.
To check to see whether your laptop has a Wifi card already installed, do the following:
Click Start>Programs>Accessories>Communications>Network Connections> and look for "Wireless Network Connection." If you have this, then your computer has a Wifi card installed and ready to go.
Aug 27, 2010 | Computers & Internet
Hi, I purchased two units of logitech cordless
Your friend should be able to use the headset if your friend's computer has Bluetooth feature. THe computer will send and receive the Bluetooth signals with one transmitter/receiver like your computer does and then connect to the wireless lan with a different transmitter/receiver system on a different frequency. Just make sure your friend's computer has Bluetooth feature turned on and then setup the headset by the "pairing" process.
Jun 15, 2009 | Logitech Cordless Headset for PC & Mobile...
Installing Samsung HT-Z510 wireless speakers
I was able to solve the wireless speaker problem through unplugging all of the units and starting over. I need to have the signal go from the satelite box to the recioever then the TV in order to get home theater to work.
Jan 05, 2009 | Samsung HT-Z310T Theater System
3Com 7760 (3CRWE776075US) 802.11a/b/g...
Hi there
I think up to now you've been using someone else's Internet service, by picking up the signal wirelessly. You need your own Internet Service. You now connect your access point in the way the Internet Service Provider guide you. It is a different set up with cable (they provide a modem) or with BT (connection through your phone line).
Dec 31, 2008 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Wireless speakers
You should have two pieces for your wireless rear speakers setup. A. a wireless card inserted behind the all in one receiver. B. the receiving box that will connect to the 2 rear speakers.Also,you should not have any obstacles to block off the line of site for the rear speaker receiving box to the wireless card.
Best way to test it is too simply leave the rear speakers connected to the rear speakers receiving box on the floor near the a/v receiver with dvd player built in.Play a dvd and see if you have sound coming out from the rear.
solutiondoct
Nov 01, 2008 | Panasonic Home Theater System System
Wireless Connection to the Internet
Hey mate,
So looking at your pda - it has no wlan build in, so you would need to get a wireless adapter for it.
Its pretty simple, install the adapter, plug it in, setup the wireless details of your home and your set to go.
Jul 03, 2008 | Matsunichi i-mat IP3230 Pocket PC
'Bluetoothing' my contacts
receive contacts is the same as voice tags. Use voice tag menu to receive contacts from your phone.
Feb 13, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Computers & Internet Logo
David Payne
David Payne
