Question about Polaris Pb4 - 60 Booster Pump
Polaris tail not sweeping. I believe the impeller on the booster is clogged restricting water flow
I have taken apart the polaris and cleaned thoroughly. This happened once before and I had to have someone come out.
    New Friend:
  • 77 Answers
If unit is operating satisfactorily otherwise, the check end of sweep tail for missing orifice tip. Without it tail won/t sweep. Also check adjusting screw. Out - more tail flow In - less.
Posted on May 11, 2013
  • 77 Answers
SOURCE: Polaris hangs in the deep end
Check to see if one of the drive belts is broken. You'll need to pull the wheels and separate the housing to inspect. Also make sure that the thrust jet is centered and pointing towards 12:00. This unit should back up after 3 minutes and reposition itself.
Posted on Apr 22, 2009
SOURCE: looking for wiring instructions for the
The diagram on the side of the pump shows how it sould be wired for low volatge. I'm having a problem wiring for high volatge and posted the diagram. Use the link to access.
http://www.poolspaforum.com/forum/index.php?showtopic=19400
Posted on Apr 29, 2009
SOURCE: Polaris 380 not running
check the filters
Posted on May 28, 2009
SOURCE: my polaris PB4-60 booster pump does not turn over.
I was able to save a service call by doing the following in under 8 minutes:
1.Switch off electric to pump.
2. Turn off valve on supply side of pump so water does not flow during this procedure.
3. Turn offf filter.
4. Unbolt the six bolts (1/2" socket) on the front side of the pump.
5. Carefully separate the pump from the front panel which contained the six bolts.
6. Grasp with both hands the black round thin disk (impeller) which is part of the pump and turn it either clockwise or counter clockwise. It may be slightly difficult initially but once it it freed it will move easily.
7. Reassemble.
8. Open valve and turn on filter and the power to booster pump.
Any questions e-mail me at bbgreg@optonline.net good luck
Posted on May 31, 2009
SOURCE: Older Polaris doesn't sweep
pantera ll by wicor sand filter distributes the sand back into the pool, what could the problem be?
Posted on Jun 02, 2009
Water comes out of the tail of polaris 360, but tail does not sweep.
check the filter in the wall of the pool where the Polaris line hooks up, it got a small filter in it. you are running it on low-pressure that's why it not sweeping, could also be a plugged impeller on the booster pump.
Jay the pool pump motor repair guy Longwood Florida
Jun 21, 2017 | Polaris Pool & Spa
How to fix the polaris pool sweep tail problems
there is a plastic clip you can use a zip tie if you cannot find it in the pool
Aug 16, 2014 | Polaris 280 In - Ground Pool Cleaner with...
How to fix a polaris pool sweep tail from coming off
there should be a clip that holds it on probably in bottom of pool or in the bag
Aug 16, 2014 | Polaris VacSweep 280 Pool Cleaner with...
I have a pb4 polaris booster pump that doesn't seem to put out enough pressure to run the pool sweep.
Check your in line screen and wall fitting to make sure they are right. Sometimes the over pressure button on the wall fitting will blow out.
Also, your local pool store should have a pressure stick they will lend you. It connects the end of the hose where the Polaris would be. You should be getting a least 28 psi. If you are getting less, you may have a clog in the booster pump's impeller. If you have that or more, the problem is internal to the Polaris. Verify that the backup valve is working properly as well.
Mar 21, 2013 | Polaris Pb4 - 60 Booster Pump
Hello, Volut cracked overnight and leaked for several hours, drainig the pool down well over 1 foot. Next day, replaced volute, but now polaris is not functioning. Water is being pumped into the...
With a new volute the most likely causes for low pump flow is a restricted return line, a restricted suction line(or air leak), or there is something wrong with the impeller in that order. There is a filter screen in the return line that can cause the return line to be restricted if it is plugged. It is either in the wall fitting or in the tubing system close to the wall fitting. If it is dirty it means that debris is getting into the system. Typically an early indication that a grid in a DE filter has a leak in it is a plugged cleaner filter screen. The speed of the motor could be causing the problem but this is rare without causing an over current condition in the motor causing it to shut off. My suggestion is first check the return filter screen. If it is dirty then clean it out. Before connecting the return hose start the pump and check the flow by reaching down and manually putting your hand over the water stream coming out of the wall fitting. Turn off the pump and connect the cleaner hose without the filter screen installed. Disconnect the hose from the cleaner and hold the end of the hose while someone turns on the pump. Water should come out of the hose at a high rate. Next install the filter screen and the flow coming out of the hose should be about the same. Now try connecting it to the cleaner. I hope this helps.
Aug 07, 2011 | Polaris Pb4 - 60 Booster Pump
I don't have any water pressurte through to the
If your getting good pressure at the pump Then the next thing to check is the wall screen. It will be in the wall of the pool behind the quick disconnect fitting for the cleaner hose. This is proballoy the problem but if it is clogged it will clog again and you will need to find the cause to fix the problem. Good luck.
Feb 28, 2010 | Polaris Pb460 Polaris Booster Pump...
Polaris is not sucking up pool debris, also the back up valve is not cycling, it's continously on and the wheel rotation is below 28rpm. I've checked the booster pump discharge valve and it's open, I've...
check the impeller on the booster pump, it's possible some debris may have clogged it. You'll need to take the booster pump apart. If you don't feel comfortable doing this, call a service tech.
Sep 12, 2009 | Polaris 380 In Ground Pool Cleaner
Polaris Pb4 - 60 Booster Pump Logo
390 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
