Question about Ridgid Vacuum. 12-Gal. 5 PHP Wet/Dry Vac WD1270
The vac won't turn on
I plugged it in a it ran for less than 5 minutes and shut off. the electrical outlet works, i cleaned the filter and the machine will not go on. it was purchased in april 2012
2 Suggested Answers
mercadoarvin
  • 384 Answers
SOURCE: I have a fairly new
Hi There and Welcome to Fixya.
As a technician, if a certain electronic appliance had a 'burning'(or anything close) smell then there's a great chance that a minor short circuit occurred within the internal electronic boards. With this, I am highly recommending for this to be serviced unless you are a certified/trained technician that can perform the necessary repairs. And to answer your question, there are no "rest" or "hibernate" button on this machine.
For you to double check if you're missing something, here's the link for the user's manual as well as repair options :
RidGid Support
Thanks for using Fixya.
Posted on May 05, 2011
I can't find the owner's manual to our shop vac. What's involved in converting it from a dry vac to a wet vac? I think it does both, but I've only ever used it to clean the car.
generally you remove the filter and just use the foam sleeve (if it has one) it should have a float ball in a cage under the filter. this is to keep the water from going into the motor if it gets too full. That is pretty much it. You should have it plugged into a GFCI outlet when using it for wet pick up, also do not pick up flammable or hazardous liquids.
Jul 23, 2011 | Shop Vac 5841627 Wet/Dry Vacuum
I have a brand new KitchenAid mixer that is 5 years old and never used. I unpacked it this morning and it won't turn on, no noise, no movement, nothing. Help.
Please check manually the motor and see if it moves freely. Now make sure that the power plug and the connections to the switch are not tampered , check the continuity of the plug to the switch and to the motors.
If you notice any dirt or insects make sure that this has not clogged on the motor. If so clean using a degreasing spray- WD40- would be recommended.
If the motor is tight , lightly oil or degrease using the spray while manually rotating.
Once this is done connect the power while taking all precaution. Use the meter to check the flow of the circuit to the switch and to the motor. If there is a trip switch see that it is reset.
If there is power to the motor and still it does not work the brushes might be dirty and might need a cleaning/ reset.
Jul 07, 2011 | Vacuums
My eureka enviro vac shut off and wont turn back on it was clogged but does not smell burnt . is there a reset or some kind of shut off when it gets clogged?
Same thing happened to me. I checked the owner's manual and it turns out the Eureka Envirovac has a built-in thermal cut-off switch. So anytime the motor gets too hot, it just shuts down. Most of the time this is because it gets plugged or the filter is too dirty. In my case, the dust basket thingy and filter were clogged beyond belief. Probably would help to clean that more regularly in hindsight. Supposedly it will turn back on after the recommended 30 minute wait.
Apr 15, 2011 | Eureka 5893AVZ Bagless Upright Cyclonic...
Using my wet/dry vac - less than 5 hours on the thing - it just stopped - can't get it to switch back on. Tried different plugs - different days. Although I purchased over 2 years ago, it has hardly been...
It may have gotten hot if you went too long before cleaning the filter. It sounds like you may have burnt it up. I hope not! You might also check to see if you tripped a breaker on the electrical panel. Try plugging it in an outlet that is not on the same circuit. If it works in another outlet, then you have just tripped a breaker.
Good Luck!
Jim
Sep 30, 2010 | Genie Company GV150 Wet/Dry Vacuum
Hoover Mach 5 turns off after 5 minutes of using. Can you advise the problem?
5 minutes everytime? If so, raise brush all the way, and vacuum next to nothing. in fact, tilt vac up so the brush touches nothing. wait 5 minutes. If it doesn't shut off, your brush is set too high. if it does, the motor is over heating. make sure bag is empty, no debris in brush, filters clean and make sure you're not plugged into an outlet that a breaker on the outlet can pop too.
Sep 28, 2010 | Hoover U5194-900 Mach5 Multi-Chamber...
I have a BISSELL CLEANVIEW II, I turn the power switch to "on" and am able to clean carpet for 1/2 a minute until the power shuts off in the outlet the vacuum is plugged into! The same repeats itself! I...
well yes in deed it is time for a new vac. for the motor bearings or armature are ceasing up ang causing the breaker to pop. if the vac. cord is hot then you know for sure...
Nov 12, 2009 | Vacuums
Shop vac
the neoprene sleeve used as the filter may have come off the cage. there's a plastic ring that fits over the filter and cage and holds it in place. as far other suggestions, use an old cotton sleeve from a pajama top. tie it off one end, slip it over the cage and fasten with a large wide rubber band.
Sep 03, 2007 | Craftsman 17765 Canister Wet/Dry Vacuum
Ridgid Vacuum. 12-Gal. 5 PHP Wet/Dry Vac WD1270 Logo
41 people viewed this question
Top Ridgid Vacuums Experts
ken skalski
Thomas Perkins
Thomas Perkins
Tim Hunt
Tim Hunt
Are you a Ridgid Vacuum Expert? Answer questions, earn points and help others
