Ok my little sister has a magnavox tp2785c221 tv when she came home from school the tried turning on the television but never powered on when u press the on button u can hear a noise
Magnavox tv model: tp2785c221 Wont power on
    Master:
  • 879 Answers
It sounds that the line output transformer has damaged. Check this site for more details. It has more than 1400 posts to different brands of electronic entertainment and other equipments. All posts referrers with the repair and fault finding to electronic entertainment equipments. It will be best to view it either in Flipcard or Timeslide option, can be selected by the sidebar tag at the top left of the display screen. Timeslide view will be the best to select. If you are using Google Chrome as browser, Flipcard option will be the best.
Posted on Dec 02, 2012
SOURCE: TV screen wont turn on but just a loud noise coming from the tv
i have a panasonic ct32sc13g flat screen tv 2003 model wont come on no lights will come on
Posted on Dec 20, 2007
Shuttle83
  • 1139 Answers
SOURCE: tv power wont stay on
Hello All,
The problem that is happening is due to the shutdown circuit activating, which is an indication of excessive current flow. This may indicate a problem in the High Voltage section or in the power supply feed from the HV section. In any case this problem is best dealt with by a trained professional. I would suggest that you take the TV to a qualified TV repair person and have them check it out.
I hope this helps
Thank you,
Shuttle83
Posted on Jul 25, 2008
Bappa170873
  • 505 Answers
SOURCE: Philips/Magnavox TV, model MS3250C321 shuts off randomly.
TV shutting off automatically means its a problem with the Lamp. Contact Pioneer or any local tech shop or Best buy and get the same replaced.
Turning off after specific time : Go to the timer option and disable the Automatically Switch off option. This will resolve the issue. Please let me know if it worked. If you need the user manual or instruction manula please click on the link below
http://www.generalmanual.com/Televisions/Sanyo-DP19647-Wide-Screen-Integrated-Digital-LCD-HDTV.htm. Hope this will be of help to you.
Thanks
Posted on Oct 17, 2008
techjuli
  • 157 Answers
SOURCE: TV seems to be in some kind of sales demo mode
To disable the Demo mode, perform the following:
  1. Turn GA_googleFillSlot("TL-IMU-Article"); on the TV.
  2. Simultaneously hold down the Vol+ and Vol- buttons on the front of the TV. Do not use the remote control.
  3. Hold for about 6 seconds
  4. Certain model TVs may turn off, others will not. But in either case, the Demo mode should be disabled.
Posted on Nov 30, 2008
  • 139 Answers
SOURCE: Mitsubishi WS 55807 wont turn on
SECONDARY POWER SUPPLY IS OUT
Posted on Dec 28, 2009
My magnavox tv changes from green to red to blue and stuff and i get no picture or sound on it what is wrong with it? and is there something i can do to fix it?
Sounds like T'Con board fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Feb 11, 2015 | Magnavox Televison & Video
Hi i have a magnavox 42" plasma TV (model
I'd look for the manual and see what it says about that red light. I can't find squat for "Magnavox KM42010P".
May 28, 2011 | Philips Magnavox MRD120 - home theater...
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
60" Projection Screen Phillips Magnavox won't turn on
Check the site www.TvRepairKits.com - they put together a kit to fix this problem.
Nov 30, 2008 | Philips Magnavox 9P6034C 60" Rear...
2001 Jeep Grand Cherokee Laredo started smoking!
Fill the rad and check for leaks. Bring the engine temp up to normal, if necessary. Try not to spill any water when filling the rad, if you do, let it dry before starting the car, JKust makes it easier to find the leak. Frankster016
Oct 24, 2008 | 2001 Jeep Grand Cherokee
Help! Toshiba 51H84..Power light flashing, tv picture won't come on!
You need a new HV transformer. Usually you can just buy the transformer itself. It's a little black tower on the backside of the tv. If it's not that, it's the convergence ic's. There's two of them, given it's a toshiba, the part number is more than likely stk392-110.
Sep 07, 2008 | Toshiba 57H81 57" Rear Projection...
Magnavox rear projectin television
Check the fuse first, if you are luck, probably you only need to change the fuse otherwise you probably need a new TV.
Turn off home electrity power or unplug all the expensive units when it is lighting to protect them.
Jul 07, 2008 | Philips Magnavox 51MP392H Rear Projection...
Red bar across top of screen??
I had the same horizontal, solid red bar along the top of the tv screen. I have an older analog Philips Magnavox TP2785C221. It just started all of a sudden. It was on every channel. However, the bar did not appear on the other input channels (e.g., AV1, AV2). So this meant that the red bar was only occurring on the antenna input. I unplugged my cable decoder box and restarted it. The red bar went away and that seemed to solve the problem for now.
Jun 25, 2008 | Philips Magnavox 42MF521D/37 Television
Nothing comes on...,when i push the power.
as there is high volage in side tv so please do not open back cover unless you know. As set is dead so problem 1 power supply section see proper output voltage is there. 2if it is ok check horizontal section. 3 as you have said that fuse has not blown means there is not much dangereous in your tv. good luck
Sep 19, 2007 | Philips Magnavox 27MS343S 27" TV
Magnavox universal remote for sanyo tv
ok...got this nice sanyo ds19310 from brother without remote..have a magnavox universal remote but don't have code for tv or if i can use magnavox codes or can i set remote to it another way...thanks for any help i can get! megnavox tv code is Press following key combination 0>6>2>5>9>6>MENU to select item press cursor(up)and (down) to change item value press cursor(right)and (left) cancellation of service mode press POWER button on the set regards thanks
Sep 10, 2007 | Sanyo DS19310 19" TV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
