Question about Jandy Ae2500t 115,000 Btu Heat Pump
I want to know the P.S.I. on the low and high side on the refrigerant i have ajandy AE2500T
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
Need a professional
Posted on Sep 25, 2014
What is the gas pressure on both compressors on subzero 321
The pressure of the refrigerant in the systems vary depending on the temperature of the refrigerant gas and the type of gas used. So this is a question that can't be answered without a lot of additional information.
Mar 02, 2015 | Refrigerators
Fault low ref pressure. how do i fix this?
check to see if filters are clean if so check to see if voltage on both sides of pressure switch if not either need new pressure switch or copper line is plugged
Nov 28, 2013 | Jandy Ae2500t 115,000 Btu Heat Pump
Low pressure fault
check filters if clean check pressure switch see if 24 volts both sides if not not enough pressure or bad switch
May 10, 2013 | Jandy Ae2500t 115,000 Btu Heat Pump
Low H2O flow
check filters if ok check the pressure switch should be 24 volts both sides if not bad switch or calcium in syphon tube
Feb 20, 2013 | Jandy Ae2500t 115,000 Btu Heat Pump
Low ref pressure
check filteres if clean check pressure switch voltage both sides should be 24 volts
May 18, 2012 | Jandy Ae2500t 115,000 Btu Heat Pump
Heat pump low ref pressure
ee if filters are clean then check pressure switch to see if voltage on both sides should be 24 volts ac if not pressure switch bad or copper line plugged
Apr 02, 2012 | Jandy Ae2500t 115,000 Btu Heat Pump
What should the pressures on the low and high side of the air conditioner read ?
low side should be about 30 psi at idle speed, high side 120 to 180 psi depending on ambient temp. higher temp, = higher pressure, as you increase engine rpm to say 1000 low side should drop to 10 to 15 psi & high side should increase about 30 psi. If high side goes over 280- 300psi you have contamination (air) in system or over charged with refrigerant. you will need to recover freon, evacuate & recharge system with proper amount of refrigerant. If the low side drops below 0psi or into vacuum then the refrigerant level is low, you will have to check for leaks , repair leaks & refill refrigerant.
Hope this helps
Paul T
Jun 01, 2011 | 1997 Chevrolet Suburban
Ac wont get cold after adding refrigerant
To diagnose problems, an A/C manifold gauge set is needed to read high and low side pressure readings. Avoid adding refrigerant with a simple charging kit like the ones sold at parts stores. Don’t add any stop leak, this can cause problems in the compressor, expansion valve or condenser.
Keep in mind that using an A/C gauge set and seeing BOTH high and low side readings can help in diagnosing the problem when you know what to look for. First, on a 134A system the high and low side service ports are different sizes. AC gauge sets have color coded hoses, the blue color coded hose has a connection that fits on the low side service port and the red hose has a connection that will only fit onto the high side. The yellow hose won’t hook up to anything if just checking the readings; it can be used to connect to a vacuum pump or attached to a refrigerant can or tank.
Normal readings on high and low side with AC OFF (static pressure) - Depends on outside temperature, but normally is between 80-105 PSI Normal low side reading with AC on high speed and MAX & engine at 800-1000 RPM’s - Ranges from 25-35 PSI - Note that on many Chrysler products a normal reading on the low side may be 15-25 PSI Normal high side reading ranges from 200-350 PSI.
Don’t assume that if adding little Freon is good that adding a lot is better!  Overcharging just a little can decrease the performance of the system and possibly damage the compressor.
Both low and high side readings are lower than normal, this indicates a cars AC system is low on refrigerant and is under-charged. If both low and high side readings are too high, this indicates an overcharged system - too much refrigerant. This also can indicate that the condenser fan is not working, is too slow or the car is overheating and heat is transferring from the radiator to the condenser.
When the low side goes so low that it’s reading shows it is in a vacuum, the most likely cause is a bad expansion valve or blocked orifice tube. Another possibility is a restricted condenser. Blocked condensers are not as common as they used to be but if a compressor fails and comes apart inside the remnants can end up in the condenser causing it to restrict the flow of refrigerant.
When the compressor clutch is definitely engaged and the low side is high and the high side is low, the most likely cause is that the compressor is failing - it is not pumping sufficiently. Rarely an AC clutch could be slipping but usually this will be accompanied with a squeal or chirp.
Hope this helps. If the compressor did come on and pulled the R134a in to the system, you may still be low or you may be over charged. With out any pressure readings it's had for me to say what is the problem. You could also have a bad orifice tube ( expansion valve) Good luck and hope this helps.
Jul 03, 2009 | 1998 Ford Windstar
95 Deville - Low Refridgerant/AC Comp. off
Good luck and hope this helps, keep me posted be glad to answer any question you may have. And yes the A/C system on your car uses R143a and there is a A/C pressure switch along the low pressure line or on the accumulator, it looks like a oil pressure sensor with a two wire lead cliped on it.
Jul 02, 2009 | 1995 Cadillac DeVille
Want to know operating pressures on a 134a refrigerator low and high
Maximum efficiency is achieved when there is the greatest difference between high side and low side provided the low side stays under 30 psi or so. The low side pressures must stay low enough to cause the refrigerant to change states in the evaporator. If you see frost on the compressor suction line, there's too much refrigerant, and you'll overload the compressor. The correct approach, if you have the equipment and it sounds like you must have a gauge set but you need recovery to do this right, is to evacuate the sealed system, (a tight system will hold a vacuum overnight, but an hour is a good test if you suspect any leaks) and refill with the exact amount of refrigerant (by weight) as indicated on the ID tag.. Any system that will not perform when filled to that specification has either a bad valve in the compressor, or a restriction caused by contamination. Contamination is usually from moisture (humidity) introduced into the system by improper servicing, but is usually relieved if the system is under vacuum long enough to boil out the moisture. If the compressor is the culprit, it's usually game-over.
May 30, 2009 | Electrolux Refrigerators
Jandy Ae2500t 115,000 Btu Heat Pump Logo
41 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
