Question about Hansgrohe Plumbing
Our bathtub fixture has a knob to turn to adjust the temperature. It is almost impossible to turn. l
    Scholar:
  • 72 Answers
Depending on make and model it could mean you need to clean the thermostatic cartridge or replace the thermostatic cartridge. If you do not know the model number feel free to contact me at Hansgrohe. 1-800-334-0455. Press 2 for Tech and ask for David Scarborough. Or you can email me a picture of the unit in question david.scarborough@hansgrohe.com. I'd be happy to help.
Posted on Dec 03, 2012
  • David Scarborough Dec 03, 2012
Temperature
Hello R, thank you for your question! Generally speaking it is recommended that the temperature knob is set in the middle for both the refrigerator and freezer compartment for top mount refrigerators. The temperature can be adjusted by moving the knob in small increments, allowing the temperature to stabilize. If you desire a colder temperature, then turn the knob towards COLDER, or for warmer temperature, turn the knob towards COLD. Turning the refrigerator control will change temperatures in both compartments. For example, if the refrigerator control is turned to a colder setting, the freezer control may have to be adjusted to a warmer setting. Turning the freezer control will only change the freezer temperature. Hope this proves to be helpful!
Jul 22, 2013 | Refrigerators
I've had a Moen shower fixture for years. Suddenly the knob is no longer turning and I find it is cracked inside and thus affecting the grip. Called Moen and they sent out a replacement. Broke again. ...
you will need to replace the cartridge, along with the handle.
plastic gets brittle over time, but adding a difficult to turn cartridge will cause it to break more frequently.
make sure when you replace the cartridge, to clean everything well. a small wire brush will do, no need to scrub, unless there is a buildup of scale. just a light brushing inside the valve.
clean and dry, then lubricate inside the valve, and the new cartridge with non-silicone based lubricant. this will make your valve work like new.
Sep 04, 2010 | Home
Wont turn off
Metering faucets rely on water pressure running through extremely small pilot holes to close off the water supply. If the set was operating correctly and then developed this problem the most likely culprit is one of the pilot holes has become clogged leaving the fixture to run constantly. If the fixture never worked properly it may be defective. Uninstall it and return it to the place of purchase for a replacement fixture. If you don't believe the unit to be defective it will have to be taken apart and blown out with compressed air. Reassemble and test the fixture. It is best if you can get a schematic of the model you purchased so that you can see how it comes apart and goes together. This can help to avoid a lot of frustration.
Jul 06, 2010 | American Standard 1340.225.002 Chrome...
Install trim and adjust the thermostat on a Grohe shower faucet
Before you install the temperature control knob, adjust the valve body (47111) with a wrench to set the temperature to "100 degree or close to it". Now, place the limit ring to tdc (top dead center) and control knob with the red 100-degree align to it. Your problem may have been the valve's temperature setting is out range when you installing the temperature control knob.
Jun 28, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
Shower water either too hot or too cold can't adjust to suitable temperature in summer.
Turn your water heater down. There is knob on it that controls temperature. Only turn it little bit at a time until you are comfortable with the temperature at fixtures.
Mar 18, 2010 | Bosch Water Heaters
The temperature dial just keeps turning around and around but the temp won't change
If the knob is just rounded out, you can probably replace it with a new knob from the hardware store. If the shaft of the valve is stripped and not the knob, someone will need to replace the valve's innards. If the knob is fine but the valve is not working, again the innards need to be changed. You can get a kit to do it yourself but it's kinda tricky.
Nov 23, 2009 | Porcher Home
Scrubbed the gas fixtures on stove top, won't light
this is something I do not recommend you do yourseelf, but there is a adjustment screw on the front under the panel near the knobs little screw that can be adjusted
Feb 07, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove to hot burns everything
This is a simple fix as long as the oven is heating properly and the only problem is that the temp seems higher than what the temperature control knob indicates...
Purchase an inexpensive oven thermometer from the hardware store and place it in the center of the oven. Set the temperature control knob to 350 degrees F.
Check the temperature indicated on the thermometer in the oven after 20 minutes. If it's not within 5 degrees of 350, you'll need to adjust the oven's temperature control.
Turn the oven off.
Pull off the temperature control knob. You can usually pull it off by hand, pry it off with a thin screwdriver, or slide a piece of cord up behind it and pull.
Note which kind of temperature control knob you have. There are two types: The first has a screw in the shaft of the knob; the second has an adjustment dial on the back of the knob.
Adjust the temperature with the first type by turning the screw in the shaft with a screwdriver. Turn it clockwise to lower the temperature; turn it counterclockwise to raise the temperature. Turn the screw just a little bit in the appropriate direction.
Adjust the temperature with the second type of knob by turning the dial on the back of the knob. (This dial is held in place with a screw or a clip that will need to be removed.) Raise the temperature setting by turning the dial counterclockwise; lower it by turning the dial clockwise. The notches are typically in 5 or 10-degree increments.
Test the oven temperature again.
Repeat until you're in the right temperature range.
Good Luck!
Mar 20, 2008 | Kitchen Ranges
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Plumbing Logo
122 people viewed this question
Top Hansgrohe Plumbing Experts
Andrew Bugbee
Ian Lulham
Ian Lulham
Level 1 Expert
ray gallant
Are you a Hansgrohe Plumbing Expert? Answer questions, earn points and help others
