Question about Canon Optura 30 Mini DV Digital Camcorder
Please check By mistake it was connected to 24 V power supply. After that, the camera can?t be turned on.
  • kmilman Jan 28, 2009
    To rockitman187
    Do you have repair manual for Optura30? How I can disassembly camcorder?
    Thank you
    President:
  • 2,559 Answers
The damage is to the board and will need to be replaced.
you can try and locate the blown section with a magnifying glass.
board repair or replacement is needed.
Posted on Jan 28, 2009
  • Randy Hough
    Randy Hough Jan 29, 2009
    you can go here and download it,It is located near the botton of the page.
    Please rate fixya
I have a KDL52s5100 it is not working(no lights, dose not t turn on) due to a thunderstorm. I have bought 2 powersupply board and a new main board and still nothing turns on no even a light.. please help....
make sure that all the voltages in the power supply output are present before connecting to the control motherboard. also confirm that the cables supplying the voltages to the motherboard are all matching e.g do not make a mistake to connect the 3.3v cable to the 12v terninal. just be cautios and your system will power up
Sep 21, 2011 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
I have an Acer AX1700-U3700A and I was working online and stepped away came back and the computer was turned off. I Pressed the power button but nothing turn on .... I have not idea what happened .... Is...
  1. Check your computer is getting power, (reconnect power from outlet)
  2. if power is ok, then open your computer cabinet, disconnect motherboard power (24 pin), then make short Green and Black wires and check power supply fan is working or not, (Switch off computer when disconnecting)
  3. if fan is not working replace power supply (SMPS) and check (working fan means SMPS is ok, but in some occasions Fan may work in defective SMPS )
  4. if the power section is ok you need check you mother board
Thank you...
Please rate me if it is valuable
Aug 28, 2011 | Acer Aspire AX1700-U3793A PC Desktop
Model D3057F3H Want to use it to power a car radio. What is the on / off connection and what is the 12V out let than can handle 5amp
Check the label on the power supply for the current rating on 12 volts.
The +12 volt is the yellow colored wire and the black is the ground.
To turn on the switch mode power supply connect pin 14 (for a 20pin connector) or pin 18 (for a 24pin connector) to ground.
You can use a switch so you can turn the power supply ON and OFF.
Please click on this link for diagrams of the 20 and 24 connector pinouts :-
http://pinouts.ru/Power/atxpower_pinout.shtml
http://pinouts.ru/Power/atx_v2_pinout.shtml
Sep 12, 2010 | Hi-Pro (HP-P401W) (HPP401W) Power Supply
Akai LCT2662 won't turn on, indicator solid orange
Any luck getting this fixed?Please let me know.Thank You very much!
Tyler
Jul 13, 2010 | Akai LCT2662 Television
Camera works fine with power supply cord connected. It will also charge the battery if connected to camera and power supply connected to ac outlet. Checked battery and it has 8.32 Volts stored in it after...
Your charger is probibly the problem i had a friend of mine that had the same problem but different camera i told him to get a new charger he did and it worked so yoyu do the same goodluck:) please rate this solution...
Jun 06, 2010 | Cameras
HP a1050y no power I tried all suggestions posted, and everything
Try Unpluging the power supply and press and hold the power button for about ten secs - leave it off for about two min and plug it back in and turn the computer on.
see if that work,
Thanks
Mar 31, 2010 | HP Pavilion A1050y (PU131AV) PC Desktop
Code 803
E803 (The output voltage of the composite power PCB has a fault.) Cause Wiring Composite power supply PCB (J208) Continuity DC controller PCB Composite power supply PCB
• If it does not turn on, see "The scanning lamp fails to turn on." • If it turns on but is dark, replace it (its ends may be blackened). Correct the connection. Connect it securely. Replace the harness. Replace the DC controller PCB. Replace the composite power supply PCB.
Turn off and then on the main power. Is the problem corrected? Does the scanning lamp turn on when the Copy Start key is pressed? Or, is it dark after it has turned on. Is the connection between J111 on the DC controller PCB and J204 on the composite power PCB good? Is the connection of the connector J208 on the composite power supply PCB normal? Check the 24-VDC line between J111 and J204. Is its continuity good? Is there an output of 24 VDC at the J111-1 and J111-3 on the DC controller PCB
Mar 16, 2010 | Canon imageRUNNER 400S Copier
By mistake I used power cord from DVD player to charge my camera. And camera doesn't work any more. It completely die.
You might have burned it out, I cannot tell I would suggest you take it to a tech locally. The issue with plugging a wrong adaptor in is voltage this will pop the supply inside the camera.
Again from here I cannot see but if it does not turn on yes its damaged.
Thanks and please lay in your ratings.
Jan 30, 2010 | Fuji FinePix S3000 Digital Camera
Hercules switching power supply 500 wat max
yes 20 pin connecter power supply is ATX(advance technology extended )power supply and old which was low watt and 24 pin is EATX (enhaunced advance technology extended) power supply is new and high watt so 4 pin connecter can be detached from 24 pin connecter and can be fitted in 20 pin connecter
Oct 18, 2008 | Guillemot Hercules Dual Fan ATX 450W Max...
Canon Optura 30 Mini DV Digital Camcorder Logo
54 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
