Question about Acer Aspire 5610 Notebook
After booting process done. Screen goes blank and Keyboard not working only Mouse cursor is dispaly and working on the blank screen in My acer Laptop.
    Novelist:
  • 176 Answers
Try booting the system to Safe mode.
To boot to safe mode:
Restart the computer. As soon as the BIOS has finished loading, F8 key on your keyboard. When Windows Options menu appears, scroll to select the Safe mode menu item, and then press Enter.
Select "Last known good configuration" then press Enter.
If that doesn't work reboot again and keep tapping on F8 to Safe Mode and instead of selecting "last known good configuration" select "Repair Your Computer"
Or you can try this:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
  1. Place your Windows XP set up disk in your CD drive.
  2. Turn off your computer and change your BOOT order to boot from CDs first.
  3. Turn your computer back on.
  4. Press any key on your keyboard when it asks you to.
  5. Press enter when you see a blue screen, one of the options should say, "To setup Windows XP now, press ENTER.".
  6. Press enter to start the windows set up.
  7. Accept the Licence and Agreement and confirm that the setup is searching for current versions on XP.
  8. Press "R" when the set up has found your current version of XP.
  9. Notice that the Set up is deleting all your windows xp files and replacing them. (This will not cause loss of data)
Posted on Jan 11, 2009
  • Ed Deguzman
    Ed Deguzman Jan 11, 2009
    Dont know what happened there after "Or you can try this" ( please ignore that )
When i power up my Acer M3400, everything loads then after the 'welcome' windows part the screen goes black and i can only see the mouse cursor? I tried to restart but nothing happens. It keep
Not sure, but try loading Safe Mode by pressing F8 during boot and lowering screen resolution. In Safe Mode you can even run System Restore. It load to a previous date that you choose.
Jan 11, 2013 | Acer Aspire M3400 PC Desktop
Gx620 boots up, then screen goes blank, reboot gives blank screen with cursor blinking. will boot with cd but still shuts down after a minute or two.
Remove the battery and open the case. Look inside the computer with a flashlight to see if any of the capacitors are busted or leaking from corrosion. The capacitors look like little battery towers, but they are not as tall as the AA or AAA batteries.
If the capacitors are bad, your computer goes bunkers.
Apr 30, 2012 | Computers & Internet
Blank screen but only the mouse cursor are showing
Press CTRL+ALT+DELETE keys and go to task manager, there you go to file and type explorer.exe and press OK. now you can see your desktop..see the pics
Jan 31, 2010 | Acer Aspire One AOA110-1113 Netbook
Compaq screen goes blank after power up?
When yo upower up press F! or F2 or "del" key to enter in bios then check your harddisk is detected? if your harddisk is sata then enable sata option in bios then save settings.
If every thing is fine then it should be dispaly resolution issue.
When yo upower up vthe computer press F8 key then enter in enable vga mode then go to control panel then dispaly proeprty-> settings ->change screen resolution to 1024*768 then restart .
Thanks for using fixya.
Please rate this solution if it helps you.
Jul 27, 2009 | Acer 91.63X07.001 Keyboard
Acer m5640 windows vista premium home won't boot, no screen image, mouse and keyboard won't light up when connected via usb, cursor frozen on screen when last "working," fan and hard drive appear to be...
Check the processor on the machine first: is it seated properly, is the cooling fan turning on it. Next, reseat all of the memory modules in the case. Finally, test the keyboard and mouse and confirm they work; try a different keyboard and mouse on the machine. Listen for any unusual noises in the case (any noises that sound out of the ordinary), try running the machine with the side panel off if possible.
Jul 05, 2009 | Acer Aspire m5640 PC Desktop
Computer boots up, but can't use keyboard or anything else
sounds like a problem in windows may have to reinstall the os
Mar 30, 2009 | Acer Aspire 5100 Notebook
Acer flatscreen won't accept signals from G-Byte cpu -
found that using an older screen and 9 pin plugs for mouse and keyboard worked - no idea why it wouldn't before.
Mar 19, 2009 | Acer Computers & Internet
Keyboard, mouse and usb ports don't work.
I have a Acer 5100 I am facing the same prolem my USB ports stopped working and then the Keyboard the system boots but i cannot do anything like the password nor can i start in safe mode or go to set up, if somebody can help me sort this problem ,thankyou
Ahmed
Jul 30, 2008 | Acer Aspire 5100 Notebook
My Keyboard and mouse are not responding
try plugging in an external keyboard & mouse, hopefully that should work
Sep 15, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5610 Notebook Logo
228 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
