Question about Whirlpool ACE244XS Air Conditioner
Whirlpool ace184xpo fan motor has 3 speeds. are only 2 used
Hi, Lo, and fan only. Is fan only medium speed?
  • Mike Gibson Dec 01, 2012
    I have one to many wires.
2 Suggested Answers
  • 4 Answers
SOURCE: Whirlpool gold washing machine
It is either a timer issue or a motor issue. I know, that you knew. But if you have a motor with like circuitry and size, you can try that or to put it into the spin cycle and see if it is a mechanical obstruction or with a voltmeter see if the timer is working.
Posted on May 18, 2007
I have a sears whole house fan.The replacement motor has 2 poles ,the original has 3.The wire coming to the motor has 3 wires:black,red,white.The fan is 2-speed.This is the right motor.How should the...
The white wire is neutral which is how the current makes a complete path through the fan then back to the panel and operates the motor. the replacement switch you have is a two speed black(high) red (low) switch. If you had 3 speeds before and wish to continue getting all 3 you will need to get a compatible switch. Otherwise eliminate the medium speed (blue) wire and use the switch you have. If the fan has a wire connector system just cut the copper tip even and place a orange cap of wire cap the size that fits tightly to provide good protection.
Apr 07, 2013 | Dryers
Furnace transformer/fan-relay wiring to fan-motor
All you need is 2 fan speeds, 1 for cool and 1 for heat. Leave the low speed disconnected. Normally we have high speed for cooling, and med. or low for heat. So either speed connected to the heating circuit is fine.
Apr 12, 2017 | Heating & Cooling
Sounds like a relay problem but if your fan is running in heating and cooling and operating ok , leave it how you got it. It is possibly the low speed winding is shorted but will be fine with med and high. Sounds like a psc motor, doesn't use 3 speeds
Mar 31, 2017 | Heating & Cooling
Have an intertherm split system. Outside condenser compressor is starting, can hear freon flowing, but fan motor will not kick in. Gets hot then kicks breaker. Have replaced capacitor with factory part.
If that system is gas heat then you have 2 fan speeds Lo speed for heat and when ac is called for the motor speed shifts to hi with the use of a fan relay.
Some various fan relays in use today. themobilian_2285.jpgthemobilian_2286.jpg
May 02, 2011 | Heating & Cooling
MY HUNTER ORIGINAL RUNS THRU AN ORDINARY WALL SWITCH. IT HAS HI AND LO SPEEDS ON THE HOUSING, BUT EVEN LO SPEED IS A BIT TOO FAST AT TIMES... HOW CAN I CONTROL THE SPEED THRU FULL RANGE... A RHEOSTAT...
Jim,
You have a special fan there. Hunter Originals are my specialty.
There are two ways to accomplish a slower speed with this fan.
1. A wall variable speed control, solid state, rated for 3 or more amps, regular fan controls will not work as your fan draws 2.5amps on high, not even new ones that are labeled for the Original.
2. Retrofit the fan to make it a three speed. If you're good with wiring, it's really simple. What you need is, a standard 3 speed pull chain switch, not a double pole one like cheaper/new fans have that use capacitor speed control, we are using cap. speed control, but not the same way they do. So you want an "SP3T" switch. You also need an 9 10 or 11 or 12 MFD capacitor (depending on how fast you want your low to be 8 is 20rpm, 11 is 75 approximately). You will remove the switch cap to your fan, and you will find your switch has a black, blue and red wire connected to it. Remove all wires, attach the black to L on your new switch, attach blue to 1, then you need 2 extra pieces of wire. Stick one wire in 2 and the second wire in 3. Now, get your capacitor and hook one side of it to the red wire and position 2, then hook the other side to the wire you put in position three.
Remember to get the Single pole switch for non capacitor speed control fans, if you get the double pole, both winding sets in your fan will be activated, which will draw double current and burn your motor out.
2speedorignial.png?t=1296263478
Also, are you aware that your fan uses oil (like an engine) ? and is not permanently lubricated?
Jan 08, 2011 | Hunter Ceiling Fan Control Switch
Hunter Ceiling fan lost medium speed, kept hi and low. Speed control capacitor melted. Replaced both capacitors (speed and start) AND switch. Still no medium speed. Is it possible part of the motor...
well, they could have. but before you throw it out, go to the hardware store, and buy a new pull switch. either that, or just run it with the high and low speeds. It shouldn't hurt it at all. But, if there is any clicking sounds, or wierd noises coming from it , DON'T USE IT!! it may catch fire. but it did last a long time. 20 years is good for a modern celing fan. though I like my antique 1907 westinghouse 72 inch 2 blade fan. It hasn't died yet!!!
Aug 12, 2010 | Hunter Ceiling Fan Control Switch
Friedrich xq08m10 - f2 and f3 fan speeds reversed
Unplu cord and remove front panel. Then remove electrical box, you should be able to find the blower motor leads.
Black is usually- hi speed motor
Blue or Yellow is- Medium Speed
Red is- low speed
Just exchange the wires to match the dial
Jun 14, 2010 | Heating & Cooling
3 speed switch wiring schmatic
On a 3 speed switch you usually have 4 terminals, and they are marked L1, 1, 2 and 3.
L1 which is line voltage from the electrical cord or wall plug, #1 low speed usually a red wire from motor, #2 medium speed usually a blue wire from the motor and #3 high speed usually a black wire from the motor. That is if the fan is low,medium and high, if it says high, medium and low then reverse #1, #2 and #3
May 08, 2009 | Heating & Cooling
Hunter fan with remote control was 3 speed, now only 2 speed
It sounds like fan motor is okay. There are two motor windings -- one low speed, one medium speed. Low winding gives you low speed, medium winding gives you medium speed, both windings give you high speed -- so I would say if you get high speed, both windings are good.
The remote (the hand held transmitter) controls the speed by raising and lowering the frequency of the current which is 60 cycle coming to the fan ceiling box. If the fan speed -selector switch (usually a pull switch) is set to high, when the remote (transmitter) signals the receiver to change speeds, the frequency of the current is changed by the receiver (the receiver is usually in the fan housing).
Sounds like you'll need to replace the remote system -- these come in sets, both transmitter and receiver, and cost about $30. If you're not experienced with wiring fans, you should get an electrician to do the job.
Apr 21, 2009 | Hampton Bay 24002 Ceiling Fan
Whirlpool ACE244XS Air Conditioner Logo
48 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
