Question about Ford 8N Tractor
How to start ford 8n without key - Ford 8N Tractor
3 Suggested Answers
  • 8404 Answers
SOURCE: my 1949 8N Ford tractor, the starter just spins
My thought is you need a new "bendix" for lack of a better word. The device I speak of spins out and connects with the flywheel. There is the possibility you have electric problems but based on what you say, I think it is mechanical.
Thanks for posting your question at FixYa.com
Pleae vote
thank you
a
Posted on Nov 09, 2009
SOURCE: 8n ford wont start when hot,plugs are dry,ethar
can u send the license key for 355664007645462 this will be help from u
Posted on Dec 11, 2009
What is the point gap for a 1948 8n ford tractor
The ignition point gap is 0.015" and the spark plug gap is 0.025". More specs here:
http://www.tractordata.com/farm-tractors/000/2/2/223-ford-8n-engine.html
Jun 08, 2014 | Ford 8N Tractor
What is the point gap ford 8n
.015 for 2N, 8N & 9N
The 8N also had problems with ignition switch causing several troubles, cheap and easy to replace....Below link is an excellent site.
http://www.yesterdaystractors.com/atrp/specs/ford.htm
May 14, 2014 | Ford 8N Tractor
My ford 8n starter only clicks, solinoid ok
Are you getting same voltage on each side solinoid when key turned.
Feb 28, 2013 | Ford 8n,9n,2n, Tractor Starter With Drive
Dec 11, 2009 | Ford 8N Tractor
My 1949 8N Ford tractor, the starter just spins
Pleae vote
thank you
a
Nov 09, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
The steering column shaft in my 1954 Ford 8N tractor broke and I need info on howe to fix it.
Not sure, but if it's a 1954 model, it's not an 8N. 8N was only built thru 1952.
But sounds like you will need a new steering shaft.
www.Ford8N.com
Sep 19, 2009 | Ford 8N Tractor
Ford 8N wont start
It sounds like the conversion was more trouble than it was worth. I won't claim to have the solution to your problem having never worked on an 8N, but I was wondering about the capacity of the points and condenser in the distributor. If the condenser is not 12 V also, it might be causing the points to melt which would keep from getting a spark at the plugs. Check the condenser for voltage rating and also check if you are getting a spark at the plugs by unscrewing a plug, reconnecting the high tension lead, and hold the edge of the plug against the block while cranking using thick leather gloves, insulated pliers, rubber, or other non-conductive material to keep from getting shocked.
Jul 10, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Ford 8n sometimes just stops-very hard to restat.
Could be a bad condensor or coil, flaking out when they get hot. If it starts ok after it cools down about an hour and is cold, then very likely the problem.
www.Ford8n.com would have everything you need for replacements.
Apr 22, 2009 | Ford 8N Tractor
Ford 8N Tractor Logo
Top Ford Toys Experts
D. E. Hev
Are you a Ford Toy Expert? Answer questions, earn points and help others
