Question about Toshiba Computers & Internet
A105 lcd replace - Toshiba Computers & Internet
    Scholar:
  • 156 Answers
Toshiba a105 on start up screen is red, then goes black
The Toshiba A105 notebook computer is made for mobile computer users who need optimal processing power. The LCD screen is a 15.4 diagonal widescreen with TruBright technology. The laptop has a fast hard drive access rate that is in the 3ms range for the paging and access of data. There are problems that can occur with the Satellite A105 that can be solved by knowing what to look for when troubleshooting the system.
Black Screen Problem Black screen problems can occur when the Satellite A105 backlight is burned out or the inverter is not working correctly. The backlight can be replaced with a new LCD bulb manufactured for LCD screens. The inverter is a housing unit that controls the voltage to the LCD screen. The inverter must be replaced by a compatible A105 Satellite inverter unit. Power Problems b> During the power-up phase of the laptop, the Satellite A105 will quickly turn off without signing into the Windows Operating Screen. The problem can be due to a faulty power adapter that is not supplying the right amount of voltage to the system board. You can also check to see if the unit that houses the power plug is loose, which also indicates lack of voltage or electricity going to the board for power up operations. Hardware Conflict Problems b> Hardware conflicts can cause system errors or "freezes" by loading a new hardware component into the same hardware I/O address. The Satellite A105 has designated input/output addresses for peripheral devices, such as hard drives, video drivers and other hardware functions. To solve hardware conflicts, use the Control Panel "Hardware" device function to see which hardware I/O addresses is not being used. b> Audio Not Working Correctly b> Loading a new audio program can cause the audio codec for the Satellite A105 not to produce sound. The audio codec can be restored by loading the "restore system disk" for the A105 laptop. The restore menu provides options on certain components that you want to restore. If you pick the option for audio, the program will restore the audio to its factory settings. b> On-board LAN Switch Not Working b> The Satellite A105 is automatically configured to detect T Base 10/100 Ethernet networks. If the laptop does not recognize the on-board LAN switch, check the system setup to examine if the LAN switch is on. If so, a firmware update may be needed to upgrade the BIOS.
Jan 16, 2013 | Toshiba Satellite A105-S4334 Notebook
Are all Satellite A105 15.4" screens the same? I
The LCD assembly will have a part number either on a paper sticker or printed on some empty real estate. Check for one that matches the structure of part number(s) listed on eBay.
You can start with the link below:
Toshiba Satellite A105 LCDs
Aug 07, 2011 | Toshiba Satellite A105-S2716 Notebook
Screen flickers and dies
You have a faulty LCD inverter board.. Go here for instructions on how to replace and find a new one, or you can search on ebay for one. http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
Sep 11, 2009 | Toshiba Satellite A105 Notebook
Toshiba Satellite a105 s4004
Here, I found this:
Toshiba Satellite A105. How to remove and replace laptop FL inverter and LCD screen.
Jun 23, 2009 | Toshiba Satellite A105 Notebook
LCD dark with white vertical line down it
It is the C-Board Panel Attached to the Display Panel And Is Integrated into the Screen .. You will need a screen replacement..
Your part is.... Toshiba Satellite A105 15.4" LCD Screen LTN154X3-L06
Feb 13, 2009 | Toshiba Satellite A105 Notebook
A105 LCD problem
I don't know where this thread was originated, but your laptop has only one inverter board.
The inverter is a small board that powers the AC lamp that provides backlight to LCD.
Here is the spare:
Toshiba LCD Inverter Board M110 A105 A100 ...
See here Toshiba Satellite A105. How to remove and replace laptop FL
Dec 29, 2008 | Toshiba Satellite A105 Notebook
Toshiba A105 dispay
This is usually a sign that the LCD is going to die and needs replaced but it could just be loose.
If you are comfortable with computers and have some knowledge you could try taking the face plate off of the monitor and making sure the connection plugged into the back of the LCD is securely fastened.
The laptop could also be overheating. Try setting it on a table and using it with nothing covering up the vent holes. see if that helps.
Replacement LCD:
http://www.screentekinc.com/Toshiba__Satellite__A105-series-laptops-lcd-screens.shtml
Instructions on how to replace the LCD:
http://www.screentekinc.com/lcd-removal-instructions_en,toshiba.shtml
Jan 27, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 grey screen
just replace screen pop top off unscrew it out and unplug it put new one in and do u have latest video card drivers installed make sure u do that also
Jan 05, 2008 | Toshiba Satellite A105 Notebook
Laptop LCD mounting bracket broken.
try ebay search for toshiba Satellite A105-S361 "for parts only". you may get one for less than $10.00.
Sep 16, 2007 | Toshiba A105-S4054 Notebook
Computers & Internet Logo
15 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
