Question about Kitchen Ranges
How do I repair a small chip on whirlpool glass stove top
It is at the front of the top right at the edge and nowhere near any burners. Is there a touch up paint avalable?
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Dec 01, 2012
  • Paul Edmonds Dec 02, 2012
    Model Number is YGFE461LVS
  • Richard Roth
    Richard Roth Dec 03, 2012
    Here is the touchup paint for that model.http://bit.ly/YnN9JQ
Amigaman
  • 248 Answers
SOURCE: Whirlpool electric range top burners
Probably have to replace the infinite switches. These are the controls you turn for the burners.
Posted on Nov 18, 2007
  • 1314 Answers
SOURCE: stove top burner replacement
if your sure you have it wired correctly then replace the switch but first id double check the wiring on the switch
Posted on Jan 10, 2008
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
  • 105 Answers
SOURCE: Maytag Electric Ceramic Glass top stove
You can replace the failed component which is either the burner or the switch that controls the burner. A voltage test would have to be done to determine which compoonent has failed. Generaally it is worthwhile to repair the range.
Posted on Apr 08, 2009
SOURCE: burner on glass stove top has turned black
The nice grey-flecked surface coating is very thin; the solid black is underneath. You've "cleaned" the coating off -- that's why further scrubbing just makes it worse. We did the same thing :-(
Posted on Apr 25, 2009
How do i change a whirlpool model wbp88800 burner control
Unplug stove. There should be two screws under edge of the cook top. You need to open oven door to get at them. Remove screws, lift cook top up at the front and prop it up. There will be two or three screws with spring clips holding the burner to the cook top. Unplug the connections, remove screws, remove burner. Install in reverse. I did this at Christmas just in time for dinner. It takes about ten minutes.
Feb 06, 2015 | Whirlpool Kitchen Ranges
Does model XFG371LVQ Whirlpool stove have air adjustment for top burners?
Remove the front panel to find where the gas injectors enter the burner tubes you will see they are cut away and have a screw holding an outer ring which is adjustable, open them up more to get more air in .
May 16, 2014 | Whirlpool Stove / Oven / Range Cooktop -...
I have a Whirlpool electric range RF263LXTQ2- 2 yrs old-it gets so hot that the large burner pans are both charred black. Had it looked at about a year ago and couldn't find any problem-top and front of...
Since you are having problems with multiple elements the problem is probably the circuit board that controls them. This can be ordered and replaced. Be sure to unplug the stove before getting into the circuit board though.
Mar 13, 2017 | Whirlpool RF263LXTQ Range
Large right front glass burner snd surrounding
The item number for this through repair clinic.com is 770583 with a cost of 374.00 Most costly part of the stove. Sorry wish it could have been better news.
Mar 09, 2010 | Kenmore Kitchen Ranges
My glass cooktop has a chip on the top edge. Is there something I could fill in the chip with?
most hardware stores and some parts stores sell a special bake lite enamel paint the repair chips and cracks with on appliances
Jan 20, 2010 | Kitchen Ranges
The right front burner on my Mom's Frigidaire FEF316(I think, the # is 316232636) does not work. She heard a pop and saw a flash under the stove top near that burner when she turned it on. I switched the...
The recepticle that the burner ends plug into get worn and loose. This will cause arching and that may be what she saw. OR, there could be a wire loose under the stove top feeding the burner. Lift it up and give it a good inspection (with the breaker off). You may need to replace the burner recepticle.
Aug 01, 2009 | Frigidaire FEF316 Electric Kitchen Range
Cracked Glass Top
I not know of any means of repairing same (maybe the system used to fuse auto glass) but if you want to replace it try repairclinic.com Item 935927 or 948440 $216/$227
Aug 27, 2008 | Jenn-Air JED8430 Electric Cooktop
Lifting the top to clean spills
Hi
Look under the counter top find the bolts that secures the stove top, unplug the power and remove the top, then look around the edges of the stove top and you should see some small screws that atach the glass to the frame, remove those and lift the glass carefuly, "DO YOUR THING" and then just reverse the steps and done.
Eddie Rentas
Tupper Lake NY
Jun 22, 2008 | Cooktops
Thermador wcggcv30 gas cooktop - how to remove glass top
Remove the brass ring nuts and the screw from each of the burners and pull off the knobs, then lift up the glass cooktop; no need to remove the three screws around the perimeter or even take out the box.
Nov 23, 2007 | Cooktops
Kitchen Ranges Logo
56 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
