Question about GE JVM1651 Microwave Oven
CHANGE LIGHT ON WHIRLPOOL RANGE HOOD - GE JVM1651 Microwave Oven
Whirlpool - troubleshooting
That is the power level or brightness of the light setting.
Aug 08, 2014 | Whirlpool WMH31017AB 1.7 cu. ft. Microwave...
Hood light & exhaust fan not working
You have no power to the unit. Breaker is out or the hot wires into the hood has come apart. The wires coming into the unit usually terminated in a junction box next to the fan housing.
Teas it for power an/or reset breaker.
Oct 21, 2013 | Whirlpool GH5184XPQ Microwave Oven
Whirlpool MH2155XPQ microwave range hood lights, timers, touchpad chimes, etc. work, it just will not cook food.. Can you help me.
probably the diodes have blown, easy fix if you can solder and use a multi meter.Get back to me if you want to try it
Jul 14, 2010 | Whirlpool MH2155XP Microwave Oven
Need a replacment microwave oven (black) for a Dometic DOTR12C. It is built in to the RV and has the light and vent screen at the bottom, over the stove. Dimensions H 16 1/2 W 22 Depth 16 5/8 Weight 48#....
Pretty easy to change.Maybe cash and carry would be a little cheaper, or even trying an appliance dealer to see if they can get the same thing. Perhaps contacting manufacturer of microwave directly will help. (www.dometicusa.com) There was some recalls on some of the models. Are you sure it's not just sitting in an opening above the range hood. Most are just 4 screws or so, and out they come from opening above that.
Jun 02, 2010 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
I dont have a vent for above range microwave oven
It doesn't have to vent outside. These are designed to recirculate the filtered air back into the room. If you cook without a range hood now it will work fine for you.
Eric
Oct 29, 2009 | Whirlpool MH7140XF Microwave Oven
I need install instruc. for a Whirlpool wallmount microwave.
sears should be able to get you the installation instructions and maint manual for this also, get on line go to sears.com and look up uour microwave part number like you did and look for the manuals
Dec 08, 2008 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Installation
I just took out the range and made an outlet out of the existing wiring.
Jun 25, 2008 | Microwave Ovens
Open Questions:
See all GE JVM1651 Microwave Oven Questions
GE JVM1651 Microwave Oven Logo
85 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
