Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Freezer quit however fridge appears to be cooling...
Kenmore Coldspot model# 50562990
Side by side with ice maker and water dispensor.
Freezer quit (warm), fridge appears to be fine...is this possible???
    Scholar:
  • 67 Answers
If there is a fan in the freezer; in that is not working then yes OR the thermostat has gone. But the unit only has one compressor and if the fridge is working it is normally a good sign.
If you where really concerned you could call a domestic refrig tech they could fix it.
Hope that this helps
Posted on Jan 11, 2009
Kenmore coldspot ice maker not working
check to make sure the water hasn't frozen in the tube that it should fill the tray with. Please let me know if this isn't the problem and I can further assist you. If frozen, you should thaw out the freezer to get it working again.
Good luck
Apr 11, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
I have a Kenmore side by side model # 106.53609202 and its about 8 years old. About a month ago it stopped making ice. I've already replaced the water valve behind the fridge and waited 24 hours and...
OK, remove the cover on the face of the ice maker and let me know if the model look like this picture:
12_17_2011_1_36_01_am.jpgIf it looks like this model, I have the service manual for it with all the testing procedures.If it doesn't, see if you can get a model number off the unit. They make about 4 different model for this unit.
Happy Holidays!Richard
Dec 17, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker will not produce Ice
Make suer the freezer temp is 5 degrees or lower. If not the ice maker will not operate. Also make sure that you have water pressure at the back of the fridge. If so, you most likely have a bad water valve. It is what your water supply connects to. You can test it like this. Disconect the water line on the fridge side of the valve. Unplug the wires from the valve. Supply 110v to the plug. If water comes out from where you disconected the line, the valv is good. If not, you will need to replace it. If you can't find the answer with this. Reply back and I'll talk you through until we find it.
Please rate this solution if helpful.
Aug 21, 2009 | Kenmore Refrigerators
Kenmore coldspot ice maker quit
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 12, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Compressor will not run
mostly the relay called a PTC relay. If you have a ohm meter you can ohm out the compressor just to make sure but pretty sure the relay. ken
Jan 11, 2009 | Kenmore 50522 / 50524 Side by Side...
What size is this fridge?
there is a sticker some where inside that will tell you cubic feet
Dec 12, 2008 | Kenmore 53542 / 53544 Side by Side...
Water Leak
do you have a water dispensor?? is there ice in the bottom of the freezer??
Oct 02, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
313 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
