Question about Samsung Computers & Internet
Samsung SyncMaster B2230 No Display Problem
I have had my B2230 Monitor for a while now. And all it has been doing is collecting dust for the past year. The first time I turned it on, it displayed nothing. No Source indicator message on screen or any display, just the backlight. Then one day, it clicked back on and decided to work. Then afterwards, it did it again and now it just won't show nothing. DVI, VGA or HDMI, It just simply will not display the menu, source indicator or image. What can I do?
  • 300 Answers
SOURCE: "No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Posted on Sep 14, 2008
  • 55 Answers
SOURCE: Samsung SyncMaster 243T blacklight
i think you use tft monitor and after you plug it then lite appear and after few seconds it's gone. plz check the inverter circuit of tft monitor. and may be possible that the life of Flurocent tube is over. if you are not hardware engineer then plz tell any hardware engineer to check the your tft monitor.
thanks
Posted on Nov 13, 2008
robshow
  • 367 Answers
SOURCE: Benq FP71E, No Image Displayed
Try checking the settings in properties for this device to make sure they are as you left them. YOu can also uninstall the drivers for the card and reinstall them to see if that takes care of the issue.
Posted on Jan 05, 2009
yooperbud
  • 8637 Answers
SOURCE: Samsung GH19LS LCD Monitor wont display computer signals
You should have received two cables with the monitor. One is for VGA and plugs into you video card or computer board . The second one is for DVI digidal video and if you have that cable it plugs into the square connector. Then if you look into your monitor manual or quick setup sheet it will tell you how to connect and set the monitor to either VGA or Digital. I'm sure that is what has to be set. Don't hook up both cables to the monitor and computer. Only use the one. Digital gives you a better picture if your computer has that function. Hope this is helpful. Bud
Posted on Jan 09, 2009
Kuwagata
  • 181 Answers
SOURCE: My syncmaster 245 bw will only display a blank
You need to adjust the monitor refresh rate to 60 Hertz or 70 Hertz.
Use the CRT first to adjust it, then after adjust,plug in your Sync Master to see is it perfect or not,find the best frequency that work best.
To adjust it,right click on the screen,enter properties, then click setting tab.
Then in advanced tab, click it then you see the monitor tab, find the perfect screen refresh rate.
Posted on Dec 10, 2009
Resolution issues with samsung b2230
did you installed your graphics driver if not install it first and you can change your resolution may be your system don't have that capacity you have to buy a graphics card that will fit to your system config and instal drivers it will work. hope that it will help you thanks
Feb 14, 2014 | Samsung B2230 LCD Monitor
Audio card fro samsung model b2230
Not sure what you are asking for here, but this monitor does not have speakers/sound capabilities.
Aug 06, 2013 | Samsung SyncMaster B2230 22 inch LCD...
Blue stripe across the monitor syncmaster b2230
Your monitor has a 3 year warranty through Samsung. The issues you are having indicate that your video control board in the monitor is beginning to have issues. You need to get an RMA to have it serviced before the warranty runs out.
Jul 20, 2012 | Samsung SyncMaster 204B 20.1" LCD Monitor
I am not getting any sound from my new monitor
Check if the driver is working properly and if you have selected the specific device in your audio settings in control panel.
Sep 02, 2017 | Samsung B2230 LCD Monitor
I have no sound on my new monitor
Hello John Kath624,
The Samsung B2230 LCD Monitor does not seem to have any speakers.
At Samsungs website the specifications state that there are no speakers:
link
Sincerly,
Tim Jansen
May 15, 2011 | Samsung B2230 LCD Monitor
My New Samsung B2230 LCD monitor is causing me so much headache and also hurts my eyes
Turn down the brightness of your monitor. There are touch sensitive buttons beneath the Samsung logo that will adjust things accordingly.
Feb 27, 2011 | Samsung B2230 LCD Monitor
Samsung SyncMaster 730B monitor green color problem
video controller card has gone bad need new video controller card.
Mar 16, 2009 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Samsung SyncMaster 17" LCD Blacks out
If you have a second monitor, you could use your computer until the monitor goes black... then plug in a replacement monitor. My guess is that one will display black too...
My gut feeling is that your VGA card is on the fritz... I'm not convinced it's your monitor. Do you have a replacement VGA card you can try? I'll bet that'll take care of the problem.
Apr 22, 2008 | Samsung SyncMaster 17" LCD Monitor
Computers & Internet Logo
73 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
