Question about Brother CS6000i Computerized Sewing Machine
My foot control on my CS6000 is not working. Just used it 5 weeks ago and it worked fine.
Have took the plug out and replugged it in and still did not work. Could I need a new plug?
  • Brother Master
  • 7,365 Answers
The foot pedal may need to be checked to see if there is a electronic
board in it and it may need to be replaced.
Posted on Dec 01, 2012
Bernina activa 220 won't stop running - sometimes
I've seen other remarks about this problem and one of the suggestions was a bad capacitor. I had problems with my 930 having intermittent starts & stops and we replaced the bushings in the foot control which took care of it.
https://www.instructables.com/answers/How-do-you-fix-a-sewing-machine-that-wont-stop-ru
Dec 20, 2017 | Bernina Sewing Machines
CS6000-i E5 showed on screen, now my backstitch doesnt work. Is this an adjustment I can make?
The start/stop button was pressed while the foot controller
was connected.
Disconnect the foot controller,
and then press the start/
stop button. Otherwise,
operate the machine by
using the foot controller.
Hope this helps.
Feb 13, 2014 | Brother CS6000i Computerized Sewing...
Took my foot pedal apart, now it wont work at all, just makes a clicking sound when trying to put my foot down on it..
Hello
Unplug the machine plug and wall plug on the sewing machine.
Check the power cord for cracks, burns, or faulty contacts as this could be a possible reason for the foot control not working.
Open the foot control by using a knife or flat surface tool, such as a flathead screwdriver, to pry open the corner of the foot control.
Check the wires to see if they are disconnected; this can happen if the foot control drops to the ground. To check wires, remove the circuit board using a flat knife. Inspect the wires inside the foot control. You will see some wires that are soldered together. Check to see if there are any broken wires, as this could be the problem. If the wire is broken, clean the area to remove any debris or dirt. Remove a small amount of the insulation before soldering. Solder wires together.
When you are done, reassemble the foot control and make sure it's working again.
Jul 12, 2011 | PfaFF Creative 7570
Presser foot stopped working I turned
Did you connect your machine then press the foot control before you lowered you presser foot? I have a CS6000 and that is what E1 means on my machine. You did not put your model number in so I don't know. You can look in your manual or go online to www.brother-usa.com and look it up for your machine. Try unplugging and plugging it in again, but put your presser foot down then step on your foot pedal.
Oct 04, 2010 | Brother Sewing Machines
What does E3 mean on a Cs6000 Brothr machine? I do not have my manuel
Hi
Here's a copy of the manual from the Brother site.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CS_6000_ES_2000_EN_185.PDF
Look on page 64 of the PDF file for the error codes.
I think E3 means:
Problem: The buttonhole or bar tack stitch was selected and
the foot controller was pressed (or the start/stop button
was pressed if the foot controller is not connected)
while the buttonhole lever is raised.
Solution: Lower the buttonhole lever
before continuing the operation
Sep 24, 2010 | Brother CS-6000
What should I do when error message E1 hapend
An "E1" message appears on the panel. Description: The foot controller was pressed (or the start/stop button was pressed if the foot controller is not connected) and the reverse/reinforcement stitch button was pressed while the presser foot is raised.
Lower the presser foot lever before continuing the operation.
Mar 02, 2010 | Brother CS-6000
Knee pedal does not work
I think what you mean is that it lifts the foot. That is what its supposed to do. Some of the older ones it could be used for a speed control (30-40 years ago).The knee BAR is there to lift the foot for you so you can turn fabric etc. without having to reach behind and lift it. It acts as a third hand. You must have a foot control which plugs into the small hole on the right side of the machine.
Hope I helped.
Feb 07, 2009 | Bernina Virtuosa 150
Power won't stop - Husqvarna/Viking 3600
your foot controller is damaged and should be replaced.
Jun 02, 2008 | Husqvarna Viking 1
Brother CS6000i Computerized Sewing Machine Logo
151 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
