My swan sw2010w washing machine, is getting power, but won't light up, or start.
Power getting to machine, on -off button will not light -up,therefore machine not starting, was working but since being moved from one house to other ,it's stopped.
SOURCE: Washing machine will not start
It is your central control unit...........try ing hitting the top with hand toward the back of machine sometimes there is a short in the CCU and a little shake will correct
Posted on Jun 10, 2009
  • 97 Answers
SOURCE: I've just moved house and my machine is not
Hello Friend, I think your machine will work properly if you add a water line splitter. You would connect to the single cold water tap and on the other end you would have two water hoses . Connect one hose to the cold water inlet of your washer and then connect the other hose to the hot water inlet. You can get these at Home Depot. Happy to help, Tim.
Posted on Jun 29, 2009
  • 6277 Answers
SOURCE: Bosch logixx 7 (2.5 years
Removing cap first BUT READ THE SECOND SECTION BEFORE CARRYING OUT!!!
Had the same problem with our Bosch, cap would not even turn!
Suggestions-
pour anticalc/limescale fluid into any gap there is around the cap. Empty the machine and you can switch it off providing the door is open! Then pour the contents of at least 2 sachets of proprietary anticalc powder/liquid into the drum direct together with a kettle full of boiling water. Leave overnight at the very
least. The following day run just a spin cycle as then there will be no water diluting the mix. This mix will go through the filter and motor and is likely to help release the filter/cap. If you feel like it, do the overnight again. If nothing else it will ensure that the heater element is clean!
I had to spend a couple of hours gently turning the cap back and forth until it finally released its hold- but the filter did not remain attached to the cap by its rubber ring. More patience, anticalc fluid and all was revealed!
I now run an anticalc clean regularly............which reminds me..............!
SECOND SECTION!
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 03, 2011
Testimonial: "Hi. We followed your instructions and it worked. Took a bit of time to move but eventually got the filter plug out. Found 3 collar stiffners!Thanks"
  • 6277 Answers
SOURCE: Lamona Washing Machine HJA 8514 Half way through a
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
John C
Posted on Jul 27, 2011
  • 360 Answers
SOURCE: My mother accidentally pulled the
Due pulling of the door forcibly the door interlock switch has damaged. So the door cannot lock properly &r the door lock switch is not functioning. Replace the door interlock switch.
Posted on Aug 07, 2011
Start Lights keep flashing on my swan sw2010w half way through was tried to get filter out but it won't come out HELP
Sounds like time and temperature inversion have stuck your filter down. Work with it gently and it will eventually come loose. If it won't come out by gently working it then get rough with it and make it come out. Got to be fixed, no good as it is.
Col. Dana Gillespie
Jan 02, 2015 | Washing Machines
My swan sw2010w washer takes on a little water then stops and lights start flashing red.
it could be a water valve fault. is it set to cold only or hot only or warm?
if warm try cold only or hot only to see if it is a valve fault.
Jun 15, 2013 | Washing Machines
No manual for swan sw2010w washing machine
Ask here, they are specialized on finding washing machine manuals.
Jul 04, 2012 | Washing Machines
Does n e one swan Sw2010w manual please
Ask here, they are specialized on finding Swan washing machine manuals.
Jun 21, 2012 | Washing Machines
Swan Essentials SW2010W The middle button will not go off and the washing machine will not work
SW2010W Hi the on / off button has pushed right in and wont come up can you help please ?
Sep 16, 2011 | Washing Machines
Washing Machines Logo
117 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
