Question about Acer Aspire T180 PC Desktop
Where can I purchase timex message mate alarm clock
AC 110 120v 60Hz-8W service no. T151-A-B(3)
Timex number t235 clock radio, how do I set the time
easiest way to set clock time. Remove AA battery's if installed.
Unplug Clock from AC. Wait a few seconds. Then replug clock into AC power. Clock will now flash 12:00. Press hours button until correct time is set PM has led on AM has Led off. Set minutes to correct minutes. Then press alarm reset / power/mode button. Wait a few seconds and display will show correct time. Now you can put the AA batteries back in.
Apr 30, 2014 | Timex T065s Solar Powered- Radio...
Timex Indiglo night light clock's stem for setting the alarm is missing
I'm afraid you can't because this is not a workshop, but have you tried a watch/clock repairer or jeweller who may have a part which will fit it, or look on ebay for one, either new or for spares. Also you don't state your location (e.g U.K. or USA) so hard to advise further. You could also contact timex directly (google timex contact us) but the address depends on your location.
Apr 06, 2014 | Timex t105w indiglo 7-color night light...
I need instructions for my timex clock
Hello
Here are the instructions for your clock-radio.
Installation
1* Remove unit and all packing materials from the carton. You should save packing
materials in case unit needs to be returned for service. If you do not wish to save the
materials, please dispose of them properly.
2* Place the unit on a stable, level surface, close to an AC outlet, out of direct sunlight,
and away from sources of dust, dirt, heat, water, moisture, vibration, or magnetic fields.
3* After installing the batteries (see below) and reading the Maintenance notes, plug the
AC cord into an outlet.
"Sure Alarm" Battery Backup Installation
It is strongly recommended that 2 "AA" batteries be installed into the unit, as directed below,
in order to activate this product's "Sure Alarm" Battery Backup feature. (The model should
come with two batteries already installed.) In the event that the AC power cord is disconnected
or a power failure or other interruption occurs, the "Sure Alarm" Battery Backup will maintain
clock and alarm settings for the life of the battery, ensuring that the alarm (buzzer only) will
sound at the set time. During any interruptions the time and alarm settings will be saved
and automatically restored when AC power is again active.
1* Gently turn the unit over and remove the battery
compartment door.
2. Install 2 "AA" batteries (alkaline is recommended for
longer life), while making sure that the + and - ends
match up with those inside the battery compartment.
3* Slide the battery compartment door back on, making
sure the door locks into place, and gently return the
unit to its upright position.
Aug 19, 2011 | Timex Auto-Set Dual Alarm Digital Clock...
I need a manual for the Timex T229B clock radio. I can't even figure out how to turn off the alarm. Please tell me how I can find one - preferably free. Thanks, Patty.
I can't find the Timex T229B on the Timex support site. However, the T228B may be similar. To turn off the alarm completely, there is a switch on the left side that must be set to Off. The switch is labeled Alarm on one side and Radio on the other. In between are 4 positions - from front to back, Radio, Buzz, Off and On. When in the Off position the alarm indicator symbol will not be lit at the top left of the display (it looks a bit like a bell). The dimmer switch is in front of this Alarm/Radio switch on this side of the clock.
To turn off the alarm and reset it for the next day, press the Alarm Set/Reset button to the right of the hour and minute buttons. The Snooze button is the large button to the left of the hour and minute buttons.
Timex alarm clock and clock radio manuals are available here: http://www.timexaudio.com/product_manuals.asp .
I hope this helps.
Dec 23, 2010 | Timex T229B Clock Radio
Timex Indiglo T436B alarm clock
my timex t436b's radio stoped working on f.m. but a.m., audo in works the sounds work so if you have any clue how to fix it please tell me
Sep 23, 2009 | Audio Players & Recorders
Timex Indiglo Clock/Radio/CD alarm clock
whats the brand and the informations about it ?
Mar 03, 2008 | Audio Players & Recorders
RCA alarm clock - RP3721 - crystal or AC for time?
They used to use crystals to help the timer ics to keep time but since the development of Micropros. all this is built in to one chip. Now they will use a resonator or a small crystal for the timing clock of the micro but nowdays the manufacture uses that clock to keep all in check. If your gaining time you probably are having problems with your ac duty cycle as this also keeps clocks in check.. This would not affect most devices but could be a problem. But of course a defective Micro could also cause this gain in time And probably is?? Now a battery backup is nothing more then a battery in line with the Microproccesors B+ terminal through of course a diode as well as a voltage limiter resistor to take over the B+ when the units ac supply is absent..
Mar 03, 2006 | RCA RP3721 Clock Radio
Acer Aspire T180 PC Desktop Logo
135 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
