Question about Maytag MGS5770 Gas Kitchen Range
Oven flash f-3.
F-3
    Top Expert:
  • Maytag Master
  • 9,472 Answers
F3 is a failure in the oven sensor circuit. That circuit being from the ERC outlet pin to the harness, to the sensor and back to the ERC return pin. Could be a bad sensor that is failing under heat conditions, or possibly a connection that is failing as the unit heats and it expands. The temp of the sensor at room temp is 1050-1100 0hms and goes up 100 ohms for every 50 degrees from there. If you can get it to fail, and ohm it out, you will know for sure. I will tell you a sensor is a heck of a lot cheaper then an ERC and is more likely the culprit. Here is the sensor to order.
Posted on Dec 01, 2012
Ge microwave f3 flashing
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Jul 14, 2010 | GE JVM1650 1000 Watts Microwave Oven
Keeps shutting off, flashing S3-Magcurr
replace 20 amp fuse and test oven with amp probe around brown wire on the right side of oven. should have +-14amps.
Apr 15, 2010 | TurboChef C3 Single Oven
Flashes f-3
you have a bad oven temp sensor probe
Jun 19, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
F3 code flashing
Replace your oven temperature sensor.
F-3 bad sensor.
Feb 02, 2009 | GE Profile JTP18 Electric Single Oven
Get f-3 code after oven on for awhile
F3 is Open oven temperature sensor circuit, to fix this you need to read oven temperature sensor circuit at oven temperature sensor ( approx 1000 ohms at room temp); check for cut or pinched wire or loss of contact, if wirings are ok, then replace the probe.
Jan 02, 2009 | GE JRP15 Electric Single Oven
My oven is in lock mode after i had cleaned it. I can't open it now and the lock light is on.
Control panel and oven door lock
The oven door and controls can be locked to avoid unintended use of the oven. The oven doors and controls cannot be locked if the oven is in use, or the oven temperature is 400°F (205°C) or above. The current time of day will remain in the display when the controls and oven doors are locked.
To lock the control panel and both oven doors:
  1. Press and release Cancel.
  2. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” appears in the display and “Lock” flashes while the controls and oven doors lock. Both oven doors lock. “Lock” remains lit in the display.
To unlock the control panel and both oven doors:
  1. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” disappears from the display and “Lock” flashes while the controls and oven doors unlock.
Dec 22, 2008 | Jenn-Air Electric Double Oven
Flashing F2 while the oven is on
f2 is a faulty oven temp sensor. need to replace the sensor. located in the oven cavity 2 screws hoding in protrudes 3-5 inches out thin metal cylinder
Mar 16, 2008 | Hotpoint RGB745 Gas Kitchen Range
Self cleaning oven
Turn off the power to your stove and then back on. It ought to clear it.
Mar 07, 2008 | Ovens
Maytag MGS5770 Gas Kitchen Range Logo
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
