Question about Acer Aspire M1202U1850A PC Desktop
Long and short beeps error?
When i turn on my computer there is a long and short beep then a short beeb like every 10 seconds. My fan and led are working but not screen and keyboard. I wonder what this long and short beep error refers too? Thk for the help!
  • 22 Answers
That's called a "POST" (Power On Self Test) code. I can't find a list of those codes, so I'm guessing based on the symptoms here that you have a dead CPU. Did you have a power surge or something just before it started doing this? One thing you try is taking the cover off, unplugging it from the wall outlet, push the power button to drain the capacitors, then remove and re-seat the memory, then put the cover back on and plug it back up and try that. There's a small chance that something has happened to make the memory come loose or something, but that's not likely considering the problem you are describing. Most likely is that your CPU is dead, which means it's time to get a new computer. A good computer shop can transfer your files from your dead computer to your new computer using a USB hard drive adapter.
Posted on Dec 01, 2012
  • 171 Answers
SOURCE: computer beeping on startup
One long, two short is the POST beep code that indicates something is wrong with your display adapter (e.g. your video card).
Make sure your video card is plugged into your computer firmly. If it is an onboard card, you may need to get an external video card and plug that in to test if that is your problem.
Posted on Feb 01, 2008
  • 3 Answers
SOURCE: computer wont boot hear one beep from motherboard over and over
If your power supply is bad, there is typically a much cheaper way to fix it rather than purchasing a new one.
If you know a little about electronics or know someone who does have them open up the power supply and check the capacitors. Often times when a power supply goes bad its the result of capacitors going bad.
If you notice on the ends of any capacitors a brownish/whitish discharge or "bulging" then the capacitor has gone bad.
A new one typically cost less than a dollar and replacing it is fairly easy if you know how to solder.
Let me know if you have anymore questions and hopefully if this is the case you can save some money.
Posted on Feb 23, 2009
  • 142 Answers
SOURCE: My Acer turns on but the screen and keyboard
If there is no beep code when starting the PC than there is an issue with your motherboard. You will most likely have to replace your motherboard.
Posted on Aug 26, 2010
Ninpomania
  • 64 Answers
SOURCE: I have an acer aspire M5100 and when you turn on
it sounds like the ram is not being detected.
what you can do is power the unit down and remove your ram module,
**static is a big issue so make sure you are not on carpets or in static clothing and always remember to be touching the compurer case when ever you venture inside to discharge any stray static **** in you**
the best way to clean the memory module is with a pen eraser, what you clean is the little copper pins at the base of the module
if you need a visual guide please email ne
dragontech1999@gmail.com
hope this helps
Posted on Feb 08, 2011
samaddar07
  • 639 Answers
SOURCE: acer aspire T180 wont start
Remove the side panel and remove the RAM.
Clean the RAM slot with dry brush or cloth.
Clean the RAM.
Fix the RAM back in the slot.
Close the cover and Start the PC
If you feel that my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Posted on Jul 13, 2011
Mobo beep
http://www.pcmag.com/encyclopedia/term/38515/beep-codes
HERE YOU CAN READ ABOUT THE BEEBING-CODES.
IF IT IS MEMORY OR VIDEO OR MOTHERBOARD.
Jul 04, 2013 | ASUS P6X58DE Desktop Board Intel Chipset...
Dead
Hi
THe most common beeps that you will encounter 95% of the time in repairing PC's are:
1 beep - computer ok
continous beeps / long beeps - memory error
continous short beeps - bios boot block/corrupted bios
1 long beep followed by 3 short beeps - video card error
or this might help
you can check out this list
AMI BIOS
1 short - Computer ok
2 short - RAM failure
3 short - Parity RAM failure
4 short - System timer failure
5 short - Motherboard failure
6 short - Keyboard controller error
7 short - CPU failure
8 short - Video RAM failure
9 short - ROM BIOS error
10 short - CMOS read/write error
11 short - Cache RAM error
1 short, 3 long - Memory failure
1 short, 8 long - Video adapter failure
Check board/chipset makers website for more infomation.
AWARD BIOS
1 long - Memory error
1 long, 2 short - Video error
1 long, 3 short - Video failure
Continuous beeps - Memory or video failure
note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
Standard IBM beep codes.
No beep - Power supply or motherboard failure
1 short - System is ok
2 short - POST error (code displayed on screen)
Repeating short - Motherboard failure
1 long, 1 short - Motherboard failure
1 long, 2 short - Video display adapter failure
1 long, 3 short - Video display adapter error
3 long - Keyboard error
Pheonix beep codes
1-1-3 CMOS memory failure
1-1-4 BIOS failure
1-2-1 System timer error
1-2-2 Motherboard error
1-2-3 Motherboard error
1-3-1 Motherboard error
1-4-1 Motherboard error
1-4-2 Memory error
2-x-x Memory failure (any number of other beeps)
3-1-x Chipset error (any number of other beeps)
3-2-4 Keyboard controller error
3-3-4 Video adapter failure
4-2-4 Expansion card failure
4-3-4 Time of day clock failure
4-4-1 Serial port error
4-4-2 Parallel port error
4-4-3 Math co-processor error
pls rate as fixya if it helps. thanks
Jul 04, 2008 | Acer Aspire 5100 Notebook
Aspire 9412awsmi wont start
2 Short Beeps Your computer has memory problems. First check video. If video is working, you'll see an error message. If not, you have a parity error in your first 64K of memory. First check your SIMM's. Reseat them and reboot. If this doesn't do it, the memory chips may be bad. You can try switching the first and second banks memory chips. First banks are the memory banks that your CPU finds its first 64K of base memory in. You'll need to consult your manual to see which bank is first. If all your memory tests good, you probably need to buy another motherboard. 3 Short Beeps Basically the same thing as 2 beeps. Follow that diagnosis above. 4 Short Beeps Basically the same thing as 2 beeps. Follow that diagnosis above. It could also be a bad timer
Apr 07, 2013 | Acer Aspire One PC Notebook
Dell XPS PC Desktops Beep 2 short beeps then turns off
Here is a link to your computer's service manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_xps_desktop/xps-400_Service%20Manual_en-us.pdf
There is a section on Advanced trouble shooting which details Beep codes and LED diagnostic codes.
Feb 13, 2013 | Dell XPS Computers & Internet
I have a brand new SAM4S ER-180 cash register. If I plug in the power it immediately goes to error mode & beeps at me. The LED screen is reading E Lo0000 or E Lo0.00. I have tried everything & dont...
A beeb normally means defective (hardware failure) DOA. Go back to your store for a warranty replacement.
Does it start without the scanner?
http://tinyurl.com/69hd8kf
Does computer beep when you turn it on? Information on beep codes bleeps on booting, boot codes led flashing flashes 1 2 3 4 5 once twice three times on and off times on boot. power on self test fail, boot failure.
Quick help guides and LED flashing errors codes search for error codes using your
Service manual.
Maybe more info here
http://www.goodson.com.au/service/FrmService.htm
Feb 13, 2011 | Computers & Internet
PC power on but doesn't display anything on the monitor and has a beep code of different intervals of time. Here are the beep codes: 2 beeps, after 1 sec, 8beeps, after how many seconds 2 beeps after how...
AMI BIOS beep codes
Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code Descriptions Document
1 short DRAM refresh failure CH000996
2 short Parity circuit failure CH000607
3 short Base 64K RAM failure CH000996
4 short System timer failure CH000607
5 short Process failure CH000607
6 short Keyboard controller Gate A20 error CH000383
7 short Virtual mode exception error CH000607
8 short Display memory Read/Write test failure CH000607
9 short ROM BIOS checksum failure CH000607
10 short CMOS shutdown Read/Write error CH000239
11 short Cache Memory error CH000607
1 long, 3 short Conventional/Extended memory failure CH000996
1 long, 8 short Display/Retrace test failed CH000607
For more information go to: http://www.computerhope.com/beep.htm#04
Jan 09, 2011 | EliteGroup P4VXASD2 Motherboard
I get 1 beeb followed by 3 beebs followed by 2 beebs then nothng happens dell diemension 8400
Your computer might emit a series of beeps during start-up if the monitor cannot display errors or problems. This series of beeps, called a beep code, identifies a problem. One possible beep code (code 1-3) consists of one beep, a burst of three beeps. This beep code tells you that the computer encountered a memory problem
you need to reseat your memmry modules just remove them and place them back in the same or a diffrant slot this cold be loose connection by connecting them again you fix it
------------------------------------------------------------ if you dnt know abt it see this it will help you
http://support.dell.com/support/edocs/systems/dim8400/sm/parts.htm#wp1052406
Apr 10, 2010 | Dell Dimension 8400 PC Desktop
My dv6000 dont start . i have black screen with one long beeb and two short beebs
HI friend,
one long beeb and two short beebs Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information,some couse of that issue is New hardware conflicting with old hardware or New hardware conflicting with old hardware or Connections not connected or connected properly or other hardware issue.Best solution is
If any new hardware has been recently added to the computer, remove that hardware to make sure it is not the cause of your issue. If after removing the new hardware your computer works it's likely the computer is either not compatible with the new hardware or a system setting needs to be changed to work with the new hardware device.Remove any disks, CD's, DVD's that are in the computer and if any USB devices (ipods, drives, phones, etc)
before all that please
Make sure all fans are running in the computer. If a fan has failed (especially the fan for the CPU) your computer could be overheating and/or detecting the fan failure causing the computer not to boot.
If you continue to to receive the same problem with all the above hardware removed attempt to disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions. Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue.
  1. Re-insert the memory into the same slot.
  2. If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick.
  3. Try one stick of memory in each slot.
Thanks,
Please rate me.......
Apr 04, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
I formated my computer....a asus p4b 1.5 mhg....turn it on and off while re-installing all of my software. once done i turned the puter off to clean the cpu fan... since the puter would not turn itself...
hi hope this helps.
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Oct 18, 2008 | ASUS Computers & Internet
Acer Aspire M1202U1850A PC Desktop Logo
57 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
