Sound problem my laptop indicate sound but its not bringing out sound
    Sergeant:
  • 431 Answers
Reinstall the sound driver or do formatting
Posted on Jan 11, 2009
No operating system found
This indicates the hard drive has stopped working, remove hardware and reseat back in place this will sometimes restart it, the next step is to have the hard drive tested for possible replacement if the reseating failed.
Jun 26, 2012 | Acer Aspire Computers & Internet
I have got problem in my laptop, the battery is not charging, it indicates plugin not charging. i need your help
Hi
Your laptop in warranty then go to the seller and replace the battery, otherwise go to the dell vostro and bring the new battery.
Jun 22, 2011 | Dell Vostro 1220 Laptop Computer PC...
Start up screen is balck,held down power button 60 seconds,no help
Is there any fan/cooler sound or some light flashing after you press ON button? If nothing indicates that power comes to the computer - make sure the AC adapter cable is not damaged and battery isn't completely dead. If you don't have an indicator lamp for testing electricity in the AC adapter cable - bring it to the computer repair service.
If not even the manufacturer's/motherboard screen appears, nor BIOS starts to load, and if there is no sound, nor flashing hard disk indicator that the computer load something from the hard disk - then the problem has occured in your motherboard, and you can't fix it yourself. If 3 beeps occur (unless motherboard sounds have been turned off), then your motherboard is most probably dead.
In any case bring it to the repair service, or to the warranty service if the warranty is still working (within the European Union the warranty is minimum 2 years, in USA should be something similar). But if your warranty period isn't over yet I strongly recommend to ask for a new laptop, don't accept the old one to be repaired.
P.S. Don't worry about your data on the hard disk - they are most probably intact. Just remove the hard drive, plug it to another computer and almost all the data without problems. ----------------------------- P.S. If this helped you to solve the problem (or at least brought some clarification) - rate this solution with 4 thumbs up! But before you would give a negative rating - post a comment, so I could improve my solution to satisfy your needs. Thank you!
Mar 07, 2011 | HP Compaq Presario C500t Notebook
My external microphone for my laptop keeps carckling when I go to record, how can I fix this. I tried cleaning the input and installing a driver but this was unsuccessful.
This would either indicate a problem with the cable connecting the microphone to the computer, or it could indicate a problem with your sound card. My suggestion is to try the microphone on a different computer. If the crackling stops then your sound card needs to be serviced or replaced. (Pending reinstalling the drivers doesn't work.)
If you still hear crackling on another computer, you can either bring the microphone to a store which specialized in audio products, or replace it.
Jan 24, 2011 | Computers & Internet
My laptop brings out no sound
Go to the Control Panel - click on Sounds and Audio Devices - click on the Sounds tab - click on any of the Program events and click the play button. If you hear a sound from the speakers the audio driver is correctly installed. Also connect a headphone to the laptop and repeat this test.
If you don't hear any sounds and the play button is greyed out, it means the correct version of the audio driver wasn't installed.
You can check if this is true - go to Control Panel - System - Hardware tab - Device Manager and look for any devices that have a yellow ? against the device. This indicates a device driver is required to make this device work.
You need to download the correct device driver for your model laptop, and it must be a XP or Vista version that matches the Windows version that is installed on your laptop.
Jun 03, 2009 | Acer Aspire 1642ZWLMi Notebook
Compaq presario v3000 (v3322tu) turns on but appears dead
According to your question ,there is a problem with RAM of laptop ,bring it out again install it properly.
if it not work you to replace it with new one.
Apr 06, 2009 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
