Question about Acer Aspire M1202U1850A PC Desktop
Acer aspire long ans short beep error
When I turn on my computer, there a long ans short beep and then short beep like every 10 sec. The fan an led are working but not my keyboard and screen. I wonder if someone knows what this beep refers too thk for ur help.
  • Acer Master
  • 27,725 Answers
1 long, 1 short beep : System board problem
1 long, 2 short beeps: Display adapter problem (MDA, CGA)
1 long, 3 short beeps: Enhanced Graphics Adapter (EGA)
3 long beeps : keyboard card
The beeps are post during post the very first work is done by the RAM , all the memory in the RAM is first transferred to the hard disk,and remains active untill turned off.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Make sure that your RAM modules and Cmos battery are securely seated
on some motherboards Cmos batteries are soldered in.
Test all power and data leads that attach from Motherboard to your Hard Drive IDE SATA
Make sure they have a secure dust free connections if its a flat 40 pin ide it will be the first to fail
Check the graphics card is seated properly with no dust in the socket you might have to remove it to check for dust reinstall it.
Restart your computer the found new hardware wizard should activate
A computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function.
Make sure all leads that are attached to your drives dvd\cd and floppy drive have secure Make sure the connections and are not faulty or just replace them they could be faulty
A computer needs all electric current and computer data to travel to and through every working device and have an end to work properly so any faulty leads will end up with a computer error.
Also check the Keyboard for secure dust free connection ps2 and or usb.
Click start control panel administrative tools computer management device manager scroll through devices if you see a yellow Question / Exclamation ? ! or a Red X a new driver will need to be installed / updated.
Right click to update driver.
If you computer came with a motherboard disk the drivers could be on it.
Rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
This is a free driver solutions.
This will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Hope this helps.
Posted on Dec 01, 2012
  • 3 Answers
SOURCE: computer wont boot hear one beep from motherboard over and over
If your power supply is bad, there is typically a much cheaper way to fix it rather than purchasing a new one.
If you know a little about electronics or know someone who does have them open up the power supply and check the capacitors. Often times when a power supply goes bad its the result of capacitors going bad.
If you notice on the ends of any capacitors a brownish/whitish discharge or "bulging" then the capacitor has gone bad.
A new one typically cost less than a dollar and replacing it is fairly easy if you know how to solder.
Let me know if you have anymore questions and hopefully if this is the case you can save some money.
Posted on Feb 23, 2009
  • 131 Answers
SOURCE: Acer Aspire desktop computer that won't turn on.
This is most likely a power supply problem. sometimes a power surge will cause failure, even when the computer is not turned on. You can replace the whole power supply, or you could check the fuse that is inside the power supply first. on rare occasions the fuse will be the only thing blown, but that doesn't happen often.
Posted on Mar 13, 2009
byteguy
  • 2229 Answers
SOURCE: Acer desktop mouse,keyboard not functioning, monitor also not wor
If there is no display on the monitor, then your computer is not sending a video signal to the monitor.
This could be caused by a bad video card or some other hardware problem. I would open the case and disconnect all the devices (hard drive, CD, etc. Leave only the CPU, memory, and video connected. You could leave the keyboard and mouse connected too.
If your computer then starts, you can start to add devices (after turning the computer off) one at a time.
If this doesn't work, then you are looking at replacing the motherboard or just the video card if that is possible.
Posted on Nov 05, 2009
  • 145 Answers
SOURCE: A 14 month old Acer aspire M1640 wil not show any
YOU MAY HAVE A BAD MOTHER BOARD
Posted on Jan 08, 2010
SOURCE: Acer Aspire AM1640-U1401A has black screen-@ boot attempt.
Had this issue with two Acers of similar make. Replacing the Motherboard resolved the issue on both.
Posted on Mar 11, 2010
HP Pavilion Media Center m8200n upon turning on it only beeps, and led light blinks twice contiuously, with no signal to monitor?
Power On LED Carl?
I ask that because most Power Supply's that HP uses, have an LED on the back also.
(HiPro, Delta, and Bestec)
The LED is now working as a diagnostic LED.
(Light Emitting Diode, so stating LED light, is redundant)
The beeps you hear are BIOS Beep Codes.
The computer's way of telling you something is wrong, and an area to look into for it.
As stated, it's a Code.
One example;
3 Short beeps,...pause, 3 Short beeps,...pause, etc.
With the Power On LED blinking 2 times, then a pause; indicates,
A) Computer is dirty inside. To include Power Supply
Computer is unplugged from power, Anti-Static Procedures are FOLLOWED; and a can or two of compressed air for computers, is used to clean it out.
I have a procedure to follow if you are interested.
B) Processor (CPU) fan is not seated correctly, and/or is Not functioning, or functioning properly.
Case open, and computer on; see if the Processor fan is;
1) Spinning
2) Looks to be spinning the proper speed.
No, I don't expect you to count the Revolutions per Minute, lol!
My reference is a general one. If the Processor fan looks to be turning slowly, you'll know it
3) Processor fan spins intermittently. Spin, slow down, stop....spin, etc.
C) Thermal Paste in-between Processor, and the finned Heatsink that sits on it, has dried up.
Lost it's thermal conductivity properties.
Top of Processor, and Bottom of Heatsink; MUST be THOROUGHLY cleaned, and fresh, new Thermal Paste applied.
I have a procedure for this too.
I can guide you step by step.
Post back in a Comment.
Regards,
joecoolvette
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=3548185
How to > Adding/Replacing Hardware > Opening the PC Case,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00583783&tmp_task=useCategory&cc=us&dlc=en&lc=en&product=3548185
http://www.hardwaresecrets.com/article/274
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3071621&CatId=503
Apr 03, 2013 | Computers & Internet
Dead
Hi
THe most common beeps that you will encounter 95% of the time in repairing PC's are:
1 beep - computer ok
continous beeps / long beeps - memory error
continous short beeps - bios boot block/corrupted bios
1 long beep followed by 3 short beeps - video card error
or this might help
you can check out this list
AMI BIOS
1 short - Computer ok
2 short - RAM failure
3 short - Parity RAM failure
4 short - System timer failure
5 short - Motherboard failure
6 short - Keyboard controller error
7 short - CPU failure
8 short - Video RAM failure
9 short - ROM BIOS error
10 short - CMOS read/write error
11 short - Cache RAM error
1 short, 3 long - Memory failure
1 short, 8 long - Video adapter failure
Check board/chipset makers website for more infomation.
AWARD BIOS
1 long - Memory error
1 long, 2 short - Video error
1 long, 3 short - Video failure
Continuous beeps - Memory or video failure
note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
Standard IBM beep codes.
No beep - Power supply or motherboard failure
1 short - System is ok
2 short - POST error (code displayed on screen)
Repeating short - Motherboard failure
1 long, 1 short - Motherboard failure
1 long, 2 short - Video display adapter failure
1 long, 3 short - Video display adapter error
3 long - Keyboard error
Pheonix beep codes
1-1-3 CMOS memory failure
1-1-4 BIOS failure
1-2-1 System timer error
1-2-2 Motherboard error
1-2-3 Motherboard error
1-3-1 Motherboard error
1-4-1 Motherboard error
1-4-2 Memory error
2-x-x Memory failure (any number of other beeps)
3-1-x Chipset error (any number of other beeps)
3-2-4 Keyboard controller error
3-3-4 Video adapter failure
4-2-4 Expansion card failure
4-3-4 Time of day clock failure
4-4-1 Serial port error
4-4-2 Parallel port error
4-4-3 Math co-processor error
pls rate as fixya if it helps. thanks
Jul 04, 2008 | Acer Aspire 5100 Notebook
Long and short beeps error?
That's called a "POST" (Power On Self Test) code. I can't find a list of those codes, so I'm guessing based on the symptoms here that you have a dead CPU. Did you have a power surge or something just before it started doing this? One thing you try is taking the cover off, unplugging it from the wall outlet, push the power button to drain the capacitors, then remove and re-seat the memory, then put the cover back on and plug it back up and try that. There's a small chance that something has happened to make the memory come loose or something, but that's not likely considering the problem you are describing. Most likely is that your CPU is dead, which means it's time to get a new computer. A good computer shop can transfer your files from your dead computer to your new computer using a USB hard drive adapter.
Dec 01, 2012 | Acer Aspire M1202U1850A PC Desktop
Computer wont start
The Beeps you are referring to are 'POST' beeps ( Power On Self Test ). In this case one long and one short is indicating a Board Problem. Depending on the Age and Spec of your machine this will be borderline to repair or replace. If you had further specs i'd be happy to advise
Apr 03, 2012 | Computers & Internet
Computer wont boot, the fans keep running
Does it come with any beep sound, because beep sound clarify the fault. Check it by the way.
The list is given below.
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine
Two Beeps POST/CMOS Error
One Long Beep, One Short Beep Motherboard Problem
One Long Beep, Two Short Beeps Video Problem
One Long Beep, Three Short Beeps Video Problem
Three Long Beeps Keyboard Error
Repeated Long Beeps Memory Error
Continuous Hi-Lo Beeps CPU Overheating
best of luck!
Mar 07, 2012 | Compaq Presario S4040SE - (refurbished)...
PC power on but doesn't display anything on the monitor and has a beep code of different intervals of time. Here are the beep codes: 2 beeps, after 1 sec, 8beeps, after how many seconds 2 beeps after how...
AMI BIOS beep codes
Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code Descriptions Document
1 short DRAM refresh failure CH000996
2 short Parity circuit failure CH000607
3 short Base 64K RAM failure CH000996
4 short System timer failure CH000607
5 short Process failure CH000607
6 short Keyboard controller Gate A20 error CH000383
7 short Virtual mode exception error CH000607
8 short Display memory Read/Write test failure CH000607
9 short ROM BIOS checksum failure CH000607
10 short CMOS shutdown Read/Write error CH000239
11 short Cache Memory error CH000607
1 long, 3 short Conventional/Extended memory failure CH000996
1 long, 8 short Display/Retrace test failed CH000607
For more information go to: http://www.computerhope.com/beep.htm#04
Jan 09, 2011 | EliteGroup P4VXASD2 Motherboard
My compaq presario laptop keeps getting an error: 0211 keyboard error it says press F1 to resume or F10 to setup but neither one of them does anything when I push them. Can this be fixed?
1. Turn off computer and unplug power cord.
2. Disconnect all external devices(open up the computer tower and then )
3. remove battery
4. press power button and hold for 10-15 seconds
5. plug power cord back into computer and press power button.
6. Check LED’s and listen for power supply fan.
7. If LED’s are on or power supply fan starts spinning, watch for boot screen
8. If coputer begins to turn on, turn it off.
9. Reconnect battery and external devices.
10. Press power button and make sure computer starts.
This should work....all the best
May 19, 2010 | Computers & Internet
Green light next to power button stays on - no response from computer, totally frozen for up to 12 hrs, then green light goes off, computer suddenly comes on for 5-10 min then freezes again.
Good day sir, hi, You need a thorough check on your PC.
But first try testing the Motherboard, Processor and Memory module.
As this point you need a friend, that knows how to tinker with your PC
Or you may need to do this.
1. memory testing:
Try replacing a new memory ram module on your PC, get the modules out of the memory slot, and let it be tested on another PC. if good,
2. power supply
Test for the power supply box, remove the 20/24 pin power connector from the mainboard and short the green and any black wire, your fan should blow out air.
3. Test for motherboard.
remove all coonections from the motherboard, except the 20/24 pin power connector, and the 12v 4-pin molex power connector, connect the pc speaker or the thumb speaker on the speaker port, connect a keyboard, clear the CMOS, (or remove the battery temporarily), connect the header panel (power switch, reset, power led) place the processor and memory (the tested good one). power on.
You should hear a beep (good) The keyboard will light up the three leds, then a few seconds, the numlock led.
If you hear 1 long and 2 or 3 short beeps, problem with the display section. Reseat any graphics card. test again.
If you hear continous beeps, reseat the memory, if the beeping persist, replace your motherboard.
If you hear nothing? only fan blowing, replace your motherboard.
I can only give you instructions, you need a someone who knows how to service a PC.
Dec 17, 2009 | Compaq Presario 5000 PC Desktop
When i turn the computer on it starts then
SOS beeps are post codes the computer sends to alert you of problems detected during start up.
The beeps can mean anything from over heating to bad memory detected. Find out what your Motherboard bio is and check Here. This has a handy beep code listing for many of the common mother boards.
Hope this helps!
Nov 17, 2009 | E-Machines (BFB0505HA) Cooling Fan, Laptop...
System not booting, k8n
Have you tried resetting the bios? turn off the computer and remove the power cable connected to the power ATX power supply, look for the "clr_cmos" jumper and change the settings from 1-2 to 2-3 for approx. 10 secs, then return the jumpers to original settings and reconnnect the power cable and turn on the computer. This was the solution when i had the same problem before. Hope this helps you too.
Oct 01, 2009 | ASUS K8N-E Motherboard
Acer Aspire M1202U1850A PC Desktop Logo
67 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
